Longer Oil Filter 4.7 & Quickdrain Valve
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Like Tree20Likes
Thread: Longer Oil Filter 4.7 & Quickdrain Valve
  1. #1
    Join Date
    Feb 2002
    Location
    Rancho Mirage, CA
    Age
    54
    Posts
    189
    Liked
    61 times
    Images
    5
    Rep Power
    3158
    Lightbulb Longer Oil Filter 4.7 & Quickdrain Valve
    I emailed Fram for a longer oil filter ( Extended Service Type ) same specs as OEM
    I wanted extended life for use with synthetic...
    XG3600 is longer and still plenty of room
    fitment is perfect
    I have a quick drain installed with a nipple on the drain, I just slip on a hose and turn the lever and I dont have to remove the skidplate...
    Search results :: Qwik Valve
    GB
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3133 times
    Images
    47
    Rep Power
    162921
    Default Re: Longer Oil Filter 4.7 & Quickdrain Valve
    You haven't done your homework. Fram is absolute crap. If you want a larger quality filter, go with the Purolator PureONE #PL30001 or the synthetic media #PSL30001. I've been running the #PL30001 for a couple of years; just switched to the newer #PSL30001. I get em from Amazon.
    CCARR and Bradthetech like this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Feb 2002
    Location
    Rancho Mirage, CA
    Age
    54
    Posts
    189
    Liked
    61 times
    Images
    5
    Rep Power
    3158
    Thread Starter
    there are 3 models of Fram
    cheap orange model
    extra gaurd
    extended
    The Purolator has no back flow valve
    Use what you want & change your oil often..
  5. #4
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3133 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by GEE-BEE View Post
    cheap orange model
    extra gaurd
    extended
    The PSL30001 has a silicone ADB valve.
    It also utilizes 100% synthetic media, wire-backed pleat supports, a nitrile sealing gasket, a steel base plate, spiral-wound center tube, all metallic end caps and filters down to 27 microns at 99% efficiency. That's better than Amsoil's line (they recently downgraded their quote to 98%).
    Do your research and get it right.
  6. #5
    Join Date
    Feb 2002
    Location
    Rancho Mirage, CA
    Age
    54
    Posts
    189
    Liked
    61 times
    Images
    5
    Rep Power
    3158
    Thread Starter
    Is the PSL30001 A longer version ?
    I dont drive it much....
    But I will give it a shot next go round..
    I send oil samples in every change so I will compare , I change my aircraft oil every 50 hours
  7. #6
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3133 times
    Images
    47
    Rep Power
    162921
    The difference between the PL30001 and the PSL30001 is the filtering media, efficiency rating and OCI interval. They are larger than the OEM Toyota/Denso filter, so you can get almost another 1/2 quart of oil in there for a full 7 quart capacity.
    To be fair, with the Extended Guard, FRAM has stepped it up in quality. It's heads above the rest of its consumer product filter line.
    In the real world -- especially with the Toyota 2UZ-FE -- the oil filter isn't a critical component to engine function. It's mainly there to catch dirt from a dirty funnel, capture loose ferrous particles, or when somebody forgets to put on the oil cap. Don't use a dirty funnel and don't lose the oil cap and you'll be fine. (Remember the old Volkswagon air cooled engines? They used a simple, coarse screen for oil cleaning.)
    The air filter and its filtration capability is far more important than the oil filter. FRAM's air filters are actually very well made.
  8. #7
    Join Date
    Feb 2002
    Location
    Rancho Mirage, CA
    Age
    54
    Posts
    189
    Liked
    61 times
    Images
    5
    Rep Power
    3158
    Thread Starter
    The non s has no valve
    the S is for synthetic
    I will have to find the distrbutor or amazon I guess...
    Thanx as I was looking for a longer assy to hold all of the oil ( 7 qt )
  9. #8
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,351
    Liked
    2783 times
    Images
    216
    Rep Power
    255670
    Come on now guys, it's a damn oil filter. They're disposable. This is like fighting over what toilet paper you wipe with... although my vote is for Angel Soft®.
    rotty and Rrumbler like this.
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  10. #9
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,351
    Liked
    3133 times
    Images
    47
    Rep Power
    162921
    Yes, it does. http://www.purolatorautofilters.net/...ilfilters.aspx
  11. #10
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,565
    Liked
    2636 times
    Rep Power
    235827
    Quote Originally Posted by tundrunk View Post
    Quote Originally Posted by Remmy700P View Post
    Another important question!!!
    I just use the toothbrush of whoever's bathroom I am in
    kerryman71 likes this.
    280,318 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Fitch Fuel Catalyst, Long Tubes with x-pipe and true duals, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the frontand rear differentials, Cooper Discoveer ATP tires
  12. #11
    Join Date
    Sep 2009
    Location
    Wisconsin
    Posts
    375
    Liked
    94 times
    Rep Power
    6228
    Charmin Ultra Soft son!
    SuckersWalk likes this.
  13. #12
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,433
    Liked
    2021 times
    Images
    26
    Rep Power
    67158
    When your truck gets muddy, do you wipe it clean? Well I don't. I prefer to wash it instead of just smearing the mud around. While some may prefer to smear their crap around, there is a better way.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer.
    http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  14. #13
    Join Date
    Jan 2009
    Location
    Plymouth, WI
    Posts
    99
    Liked
    5 times
    Rep Power
    430
    Thank you very much for NOT demonstrating the Japanese Toilet!!!!! LOL
  15. #14
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,194
    Liked
    402 times
    Images
    25
    Rep Power
    24544
    I'm with Remmy. There are BIG differences between filters. Fram quality has improved a lot but they're still dealing with the fallout from the days when they figured no-one would figure out they were selling junk in a can.
    My preferred filter is Donaldson P169071, 22 microns at 99%. Really amazingly good. $10.34 each last time I bought them from filterspro.com. Baldwin B2-HPG is basically the same - 23 microns at 99% - and slightly cheaper.
  16. #15
    Forum Admin Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Age
    36
    Posts
    8,128
    Liked
    419 times
    Images
    240
    Rep Power
    5011308
    How about buying a case of the least expensive filter and changing it every month? Like I do with my furnace filters. They stay clean and it requires less force to circulate the oil through your system. I doubt my engine notices if I'm filtering out pollen and bacteria.
    Crazy Ivan likes this.
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
