+ Reply to Thread
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By bobbygail@aol.com
Thread: Front wheel bearing replacement?
  1. #1
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    210
    Liked
    15 times
    Rep Power
    1274
    Default Front wheel bearing replacement?
    If I buy the complete hub assembly, does anyone know if it comes with a new bearing already pressed in? I'm trying to avoid having to take the truck to a shop to have them remove the old one and press a new one in. I'd rather just swap out the whole unit by myself. With that said, would it just be a matter of removing the brake components and unbolting the hub and installing the new one, or does the entire steering knuckle need to be removed?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Sep 2012
    Location
    North Carolina
    Posts
    358
    Liked
    194 times
    Rep Power
    16416
    Default Re: Front wheel bearing replacement?
    A 'complete hub assembly' typically includes the bearing. They usually are a bolt in affair but if you have 4wd, you will need to torque the half shaft nut correctly. Too tight, your bearings will fail soon, too loose and again your bearing will fail soon.
  4. #3
    Join Date
    Jun 2008
    Location
    New Orleans, LA
    Posts
    41
    Liked
    11 times
    Rep Power
    877
    Quote Originally Posted by yamatoy View Post
    If you are talking about replacing a front wheel bearing on a Tundra....you cannot buy a complete hub/bearing assembly. You can buy a new bearing and use your existing hub. You will have to remove the entire spindle and press out the hub and bearing with at least a 20 ton press. ***This is not an easy task*** One option is to purchase a used spindle with the hub and bearing included. If you want to do it yourself you will need to purchase new seals and bearings. Just a suggestion...take your old spindle to a machine shop with the new materials (bearing/seals) and let them press the old bearing/hub out and install the new bearing/seals. The bearing and hub fit very tight inside of the spindle. A 2-3 jaw puller will not be enough. When you press these puppies out with a shop press you will hear a very loud BANG cause they are so dam tight! The you may need a bearing separator or a cut off wheel to remove the inner bearing race from the hub. You may need to use some heat from a torch too...
    DevinSixtySeven likes this.
  5. #4
    Join Date
    May 2010
    Location
    Orlando, FL
    Posts
    210
    Liked
    15 times
    Rep Power
    1274
    Thread Starter
    Quote Originally Posted by bobbygail@aol.com View Post
    Damn, not what I wanted to hear! I guess I will be having a shop do this then. Any idea what the labor time would be for them to do the complete job including removing the spindle and R&R bearings and seals?
  6. #5
    Junior Member Tundra1Dan's Avatar
    Join Date
    Jun 2012
    Location
    Ontario
    Posts
    287
    Liked
    127 times
    Rep Power
    7881
    Click image for larger version.
Name:	wheel bearing.pdf
ID:	136098 maybe this will help
    04 Tundra DC / 270000 kms /Silver Sky / BFG AT ko summer / BFG Winter Slalom / Kenwood Excelon DNX691HD Nav hu / Volant CAI / Int LED's / Newly applied Line-x / A.R.E Z Series topper / Viper 5901 2way Alarm/starter / 5100's all around , fronts on center perch/ Hellwig 7700 rear swaybar / Scangauge 2 / Weather Tech liners front and rear / Heated seats.
  7. #6
    Join Date
    Jun 2008
    Location
    New Orleans, LA
    Posts
    41
    Liked
    11 times
    Rep Power
    877
    Not sure how much the labor would cost to remove the spindles. You can purchase the bearings and seals online much cheaper. A machine shop would probably charge around $30-$100 to do the press work. This is the easiest route to take unless you have a good shop press and the proper tools. Good Luck
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
