This is a discussion thread titled "fix for sliding window", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 05-13-2005, 06:41 AM
07 firecrew's Avatar
Dealer : Cowboy Toyota
2007 Toyota Tundra superwhite crewmax
07 firecrew's Photo Albums
Last Online: 10-02-2008 05:46 PM
07 firecrew is on a distinguished road.
Wink fix for sliding window
for those of you, who have the 04-05 tundra, that has the rattle when partially down, here is a fix. first of all, if you have the factory bed liner, it is part of the problem. because it does not fit snug against the front of the bed, it rattles quit a bit. my solutions, was to take the bed liner out, and put some foam padding in that space ( the verticle space between the bed, and bed liner, below the rear window) some of these were poorly molded. that part of the problem, solved. the next step, was to shore up the rear window. if you will notice, on the bed side of the window, there is a small grove, running from side to side, at the bottom of the window( between the window frame, and the rubber seal) the problem is, the bottom seal is not making enough contact against the window, to stablize it. in that grove, i wedged a piece of ( .160" screening spline) in that space. once you install it, it's barely noticeable( i could only find gray, black would make it invisible) for those of you who don't know what, sreen spline is, this is the round seal that holds the window screen in the frame. to reinerate, if you have the liner, you have two jobs. one final thing, when i took out the liner, there were several chafing points, covered them with electrical tape. no more rattling window. hope you guys can use this.
2007 SR5 crewmax Texas Edition 4x2
light gray leather interior
xm radio, bed liner
fog lights
swaybar
woodgrain interior
carriageworks grille
corsa exhaust
ARE LSll cover
chrome accent covers
Old 05-13-2005, 10:33 AM
Dealer : Toyota of Cincinnati Co.
2007 Toyota Camry SE V6,
2008 Toyota Tundra 5.7 Limited Slate
wleslie's Photo Albums
Last Online: 11-18-2008 06:05 PM
wleslie is on a distinguished road.
Great tip. Thanks! Although mine doesn't rattle now, you never know what will happen in the future. I'll file this tip away for possible future use.
Similar Threads for: fix for sliding window
Broken window latch in Access Cab Tundra, DIY fix? Agent WD-40 Interior & Exterior 29 01-19-2008 03:39 PM
Wing window lock broke...Part not so easy to replace, anyone try to fix this? FootballFreak Interior & Exterior 11 05-03-2005 10:55 AM
Window Motor Bad mikesill 1Gen-Sequoia 1 12-04-2004 06:54 AM
Rear Window Fix Swift 4Runner 2 03-19-2004 07:33 PM
Power sliding back window nhparrot Electrical & Computer Systems 0 03-28-2002 01:17 PM
