  #361 (permalink)
Old 10-19-2006, 11:15 AM
Dealer : Toyota Scion of El Cajon
2002 Toyota Tundra
Last Online: 11-01-2006 05:40 PM
4x4bigd is on a distinguished road.
4x4bigd's Photo Albums
Default Re: Safety Recall!
Morning,
This is my first post, do I give my VIN # to the dealership and see what recalls are on my 2002 Tundra 4x4?
Thanks
  #362 (permalink)
Old 10-20-2006, 12:35 AM
pearldrums287's Avatar
Dealer : Haley Toyota. Of Richmond
2002 Toyota Tundra Tundrinator
Last Online: 10-11-2009 02:40 AM
pearldrums287 is on a distinguished road.
pearldrums287's Photo Albums
I have a 2002 tundra and i even called toyota to check about the recall. They ran my VIN number and said that my truck wasn't affected by this.
well....about a month later I'm going down the road and my wheel...well, it fell off. IT FELL THE F*&K OFF. I was fine, but I was going about 40 around a turn and slid down the road with oncoming traffic. Since I had no front brakes (brake line snapped) I just skidded until I stopped several feet from where there was a cross where someone was killed and a bunch of trees (kinda scary). Apparently my lower ball joints snapped, just like in the recall. Third party inspector checked it out, and stated that it was clearly a manufacture defect. My truck was almost totalled...it screwed up a bunch of stuff underneath and part of the body... but I actually ended up getting it back. Insurance covered all but a small deductible, but now my insurance company is trying to sue Toyota and all this stuff. This all happened about 3 months ago.
2002 Toyota Tundra SR5 V8
flowmaster, rims, clear corners, euros, hids, K&N air filter, Optima Deepcycle battery,kicker subs, pioneer headunit, infinity speakers, CB, GPS, green neon inside, dump truck airhorn, scangauge II, bunch more
  #363 (permalink)
Old 11-16-2006, 06:27 PM
socalifgirlie's Avatar
Dealer : Toyota Carlsbad
2004 Toyota Tundra
Last Online: 02-05-2007 05:36 PM
socalifgirlie is on a distinguished road.
socalifgirlie's Photo Albums
Hi everyone. I am new to this forum and I live in Orange County California and just took my '04 Tundra in for its 30K major mileage. They called and said my pads are worn down to 2 1/2 mm, I was like ok replace them. Then a friend of mine called and said something about a recall that I never received a notice for and on here its about the lower ball joint. I asked the service guy and he asked if I had the recall letter and I said I was told to have him cross reference my vin number and he called back saying that there was no OPEN recalls. So now I am a little freaked out. My question is, was there once a recall on my truck that I was never informed of and now its to late and second, what can I do about it now? I know that after 30K I def need new brakes but did they wear down like that on there own or from help with the lower ball joint causing my front end to shake and cause the brakes to be affected. I need some help please. I want to march in there and be like look. I never received a notice. Nobody called me and if something goes wrong I am hiring a lawyer. What should or even can I do. Thanks...Amber
  #364 (permalink)
Old 11-16-2006, 06:53 PM
Dealer : Michael Toyota
TS Support is on a distinguished road.
TS Support's Photo Albums
Campaigns applicable to the 2004 Tundra
LSC 40J NAVIGATION SYSTEM DVD SOFTWARE UPDATE
In November, 2004, Toyota will initiate a Limited Service Campaign (LSC) to replace the Map Database DVD (DVD) on certain 2004 and early 2005 vehicles equipped with the optional Generation 4 Navigation System.
In recent months, Toyota has received reports of localized anomalies in the map details of the vehicle’s Navigation System. Although by nature map databases may contain a certain degree of inaccuracy, a noticeable decline in the precision of the map data was observed when directly compared to the 2003 model year (Generation 3) Toyota Navigation system. In addition, these anomalies tended to be concentrated in particular areas.
The owner notification will commence in mid-November, 2004, consistent with DVD availability. This Limited Service Campaign will be available at no cost to the vehicle owners until December 31, 2005.
SSC 50E CERTAIN 2004 THROUGH EARLY 2005 MODEL YEAR TUNDRA WITH BOTH VSC AND TRD DUAL EXHAUST SYSTEM
Toyota will initiate a Special Service Campaign to replace the TRD Dual Exhaust System, on certain 2004 through early 2005 model year Tundra vehicles equipped with both Vehicle Stability Control (VSC) and a TRD Dual Exhaust System.
The Accessory TRD Dual Exhaust System was added as an available option for all model Tundra’s. The TRD Dual Exhaust System met all clearance specifications on models with the standard equipment package. The 2004 through 2005 models offered VSC as an available factory option, which includes an additional brake line which was not previously present. When the TRD Dual Exhaust System was added to vehicles with the VSC option, the driver’s side exhaust pipe no longer met the clearance specifications with the additional brake hose. Vehicles not equipped with VSC do not have this extra brake hose. The location of the TRD driver’s side exhaust pipe placed it in a position where in rare cases contact between the brake line and the exhaust pipe might occur. In this condition, the exhaust pipe flange may rub against the right rear brake hose which could cause brake fluid leakage. This may lead to an increase of vehicle stopping distance and thus raise the possibility of an accident.
The owner notification will commence in late April, 2005.
Please note that not all vehicles in the VIN range are affected by this SSC. If you are contacted by an owner of an involved vehicle, who has not yet received a notification, please verify eligibility by confirming through Dealer Daily/TIS prior to performing repairs. Dealers should perform the inspection and if necessary repairs as outlined in the attached Technical Instructions.
SSC 50J FRONT SUSPENSION LOWER BALL JOINT
As announced in May, 2005, Toyota will initiate a Special Service Campaign in several phases to replace the Front Suspension Lower Ball Joints on certain 2001 – 2002 4Runner, 2001 – mid-2004 Tacoma 4WD and PreRunner, 2002 – early 2004 Sequoia and Tundra vehicles. This notification is being sent to advise you of the launch of Phase 1 of this campaign. Each subsequent phase will be launched consistent with parts availability.
On certain 2001 – 2002 Model Year 4Runner, 2001 – mid-2004 Model Year Tacoma 4WD and PreRunner, and 2002 – early 2004 Model Year Sequoia and Tundra vehicles, there is a possibility that the Front Suspension Lower Ball Joint may experience excessive wear and looseness causing increased steering effort, reduced vehicle self-centering, and noise in the front suspension. If the vehicle is continued to be operated in this condition, in extreme cases, the lower ball joint may separate from the knuckle causing a loss of vehicle steering control.
The owner notification (Phase 1) will commence in mid-July, 2005. Owner letters will be mailed based upon part number and production date, starting with earlier production vehicles.
Please note that not all vehicles in the VIN range are affected by this SSC. Please verify eligibility by confirming through Dealer Daily/TIS prior to performing repairs.
You can contact the Toyota Customer Experience Center at 1-888-270-9371 Monday through Friday, 5:00 am to 9:30 pm, Saturday and Sunday 7:00 am through 3:00 pm Pacific Standard Time, with your VIN to see if these are applicable to your vehicle.
  #365 (permalink)
Old 11-16-2006, 07:45 PM
ToyzOnly's Avatar
Dealer : Folsom Lake Toyota Scion
1998 Toyota Avalon XLS
Last Online: 09-01-2008 01:04 AM
ToyzOnly is on a distinguished road.
ToyzOnly's Photo Albums
Welcome to the site Amber, this is an AWESOME site with LOTS of GREAT people. You'll see....
I also have an '04 Tundra. See pic below the "attatched thumbnail" pix"
and it was manufactured in May of '04, which means I have a high vin# ,
so my truck is not affected. I believe the early '04's,and older, had the lower ball-joint recall. You can see when your truck was manufactured, and of coarse, the vin#, on the inside of your drivers door.
See attatched photo's.
  #366 (permalink)
Old 01-09-2007, 05:57 PM
Dealer : Hawkesbury Toyota
2005 Toyota Tundra
Last Online: 03-27-2008 11:22 PM
Gkozak is on a distinguished road.
Gkozak's Photo Albums
I have another thread issued called Ball Joint Failures - Very Serious Matter, this is related to a 2005 Tundra.
If you think the problem was restricted to the vehicles in that recall, you should be forwarned that the problem may be more widespead affecting your own vehicle. The was an engineering investigation launched Aug 2006 by a US Highway group as an deeper probe to the 2005 recall and that study from what I know is not yet completed.
2000 Trailer Wiring Recall catdaddysam Towing 9 07-10-2007 01:33 PM
Toyota Announces Massive Recall khaug 4Runner 2 05-18-2005 11:34 PM
TRD Duals recall/ Service bulletin bob259 Engine & Drivetrain 1 05-13-2005 11:20 AM
