60,000 mile tune up/maintenance
+ Reply to Thread
Results 1 to 5 of 5
Thread: 60,000 mile tune up/maintenance
  1. #1
    Join Date
    Feb 2004
    Location
    Los Angeles
    Posts
    10
    Liked
    1 times
    Rep Power
    0
    Default 60,000 mile tune up/maintenance
    Hi all,
    I have received so much contradictory information between the maintenance manual, Toyota mechanics, friends that are mechanics, and the dealerships And invariably when I have a question about my truck, I find this forum to be more knowledgeable and helpful than anywhere else...
    So...what EXACTLY should I do maintenance wise at the 60G mile mark? Anything particular I should be aware of? Any suggestions?
    Thanks, all
    Randal Scott
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter MtTrout's Avatar
    Join Date
    May 2005
    Location
    MT
    Posts
    422
    Liked
    0 times
    Rep Power
    10
    I did the following after a pretty thorough search on this site:
    Rotate Tires
    Oil & Filter Change (Mobil 1 Synthetic 5w-30)
    Transmission Oil Flush (Mobil 1 Synthetic ATF)
    Brake Fluid Flush (any standard brake fluid)
    Power Steering Fluid Flush (Mobil 1 Synthetic ATF)
    New PCV Valve (Toyota)
    Complete Coolant Flush (Toyota)
    New Fuel Filter (Toyota)
    New Spark Plugs (NGK)
    New Air Filter (Toyota)
    New Serpentine Belt (Toyota)
    Clean Throttle Body
    Drain & Refill F/R Differentials and Transfer Case (Amzoil Synthetic)
    Instructions are available here and/or by purchasing a Haynes Manual for $15. I used both.
    A couple suggestions: The fuel filter was the hardest part, so be patient in working it off. Purchase a pump for the differential/transfer case oil...you will save a ton of time over a turkey baster. The turkey baster works well for sucking up power steering fluid. You can also buy a simple brake bleeder, which is essentially a piece of tubing with a stop-valve to prevent air from getting into the lines while you pump the new fluid through.
  4. #3
    Join Date
    Feb 2004
    Location
    Los Angeles
    Posts
    10
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Default Thanks
    MtTrout,
    Thanks very much for your help!
    R.S.
  5. #4
    Join Date
    Sep 2005
    Location
    Seattle, WA
    Posts
    195
    Liked
    0 times
    Rep Power
    10
    Quote Originally Posted by MtTrout
    Rotate Tires
    Clean Throttle Body
    Nicely done MtTrout, as an owner of a Land Cruiser with 210k miles, I'd suggest looking at your hoses and any rubber parts that can either harden or wear over time. Depending on how much you sit in traffic or geography of location, the engine bay can cause a lot of damage just from the temps. Changing out rubber grommet items such as the PCV valve is always easier when the rubber isn't rock hard. Most of those parts are about $10-20 and should easily pay for itself over the long run. Just my thoughts, being a very new owner I'm not looking at doing anything for a year or two... Take care.
    Robert
  6. #5
    Join Date
    May 2005
    Location
    MT
    Posts
    422
    Liked
    0 times
    Rep Power
    10
    I bought hoses, but ended up taking them back because the current hoses are in great shape. The car is mostly driven to and from the ski hill and travelling around western Montana, so it has very few hard miles. It isn't driven around town, as we have a more fuel efficient toyota car for that. Let us know how your project goes, Robert.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Need 60,000 mile service advice
    By tguil in forum 1Gen-Tacoma
    Last Post: 09-02-2005, 02:56 PM
  2. 60,000 Mile Maintenance (Sequoia)
    By PagalDesi4Life in forum 1Gen-Sequoia
    Last Post: 02-22-2005, 11:56 AM
  3. 60,000 Mile Service for Civic
    By 03SilverSky in forum Off-Topic
    Last Post: 02-06-2004, 08:28 AM
  4. 60,000 mile "scheduled" service
    By ace57 in forum Engine, Intake, Exhaust, Induction
    Last Post: 05-29-2003, 11:17 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
