This is a discussion thread titled "Spark plug dillemma Help", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 09-30-2005, 10:40 AM
Inactive Account
00tundra426's Photo Albums
Last Online: 09-30-2005 05:54 PM
00tundra426 is on a distinguished road.
Default Spark plug dillemma Help
I want to change my plugs today and am wondering if a set of FR5/4876 NGK V-Power plugs are the right ones, as far as I can tell they are one heat range hotter than the V8 tundra plugs, They cross to the V6 plugs and the V8 plugs. I just wanna make sure they are safe to use. Any help is appreciated.
Old 09-30-2005, 01:11 PM
greasefingers's Avatar
Dealer : James Toyota
2003 Toyota 4Runner
greasefingers's Photo Albums
Last Online: 08-19-2008 07:48 AM
greasefingers is on a distinguished road.
The heat range of a spark plug is the plugs ability to get rid of heat. They typically do this by changing the length of the plug or the ceramic section. So a longer plug takes more time to dissipate heat and is called a Hot plug. A team of people have probably spent countless hours designing the combustion camber and related components. Having said that, I would not deviate from the Toyota specified heat range.
4Runner Sport V8
MAP Light MOD, Scion Stereo, replacement speakers, & Hella Horns 68,000 miles
Old 09-30-2005, 01:49 PM
Inactive Account
Dealer : Shore Toyota
2004 Toyota Tundra
madaneerg's Photo Albums
Last Online: 10-14-2005 07:53 AM
madaneerg is on a distinguished road.
what plugs should you use if you wanted to replace? make? model#?
Old 09-30-2005, 01:53 PM
fastmhz's Avatar
Dealer : Elmore Toyota Scion
2000 Toyota Tundra,
2005 Toyota 4Runner
fastmhz's Photo Albums
Last Online: Yesterday 09:48 PM
fastmhz is on a distinguished road.
Send a message via AIM to fastmhz
Originally Posted by madaneerg
what plugs should you buy if you wanted to replace? make? model#?
Head to the dealer and use OEM Denso plugs. Just let them know whatever year Tundra it is.
2000 Toyota Tundra V8 Ivan Stewart Edition
2.5" Shocks by Sway A Way (Camburg)
King Coil Springs 650lb x 14"
11pk Deavers w/ 5100 Bilsteins
LT285/75R16 Nitto Terra Grappler Load Range D 122Q
Weld Racing Renegade 16x8 3 5/8 BS
JBA Titanium Coated Headers
Eclipse AVN5435 Unit
'05 Tail Lights
Clear Corners
TRD LSD soon!
Old 09-30-2005, 02:20 PM
Inactive Account
there are no toyota dealers in my area so I called the closest one and service manager told me they will work. Put them in at dinner time and will be driving later tonight, he should know what he is talking about, I hope.
Old 09-30-2005, 03:04 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
RitcheyRch's Photo Albums
Last Online: Today 07:00 AM
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch
Denso's pr NGK's are both good. I use NGK's in all of my vehicles (both import and dometic)
Old 09-30-2005, 07:08 PM
Jack Burton's Avatar
Dealer : Carson Toyota Scion
2002 Toyota Tundra,
- Other - 1990 4-Runner
Jack Burton's Photo Albums
Jack Burton is on a distinguished road.
Default $2.00 locally.....
Here ya go.... NGK These should cover all years up to '04..... JB
Old 10-01-2005, 05:05 PM
JTs02Tundra's Avatar
Dealer : Hudson Toyota
2002 Toyota Tundra
JTs02Tundra's Photo Albums
Last Online: 10-02-2008 06:52 PM
JTs02Tundra is on a distinguished road.
SparkPlugs.com is a good source... That have both Denso and NKG.
SparkPlugs.com
I just changed mine today for the first time at 30,000 miles . These plugs are about two bucks each. Easy job. It took about 1/2 hour.
JT
2002 SR5, Thunder Grey, Access Cab, 4.7, Off Road pkg, 4WD, Toyota Bedliner, Bed Extender, Limited Slip Diff, ABS
Add Ons: Toyota Tube Steps, Leer 700 Lid, Curt Front Mounted Receiver Hitch, WeatherTech Window Vents, WeatherTech Front Floor Liners, Cabela's Aux Back Up Lights, Hellwig Rear Anti Sway Bar, Skid Row Front Skid Plate, Fumoto Valve, SP Rotors and Hawk Pads, SnowSport SnowPlow
Have on workbench: Total Chaos Steering Gear Bushing kit, Autoxray 6000
Old 10-02-2005, 05:23 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Last Online: 09-23-2006 09:21 AM
My local independent auto parts store had Denso or NGK plugs for $1.59, cheaper than sparkplugs.com, and no gouging S&H charg.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-02-2005, 05:44 PM
greener's Avatar
Dealer : Toyota of Des Moines
2003 Toyota Tundra
greener's Photo Albums
Last Online: 09-11-2008 02:37 PM
greener is on a distinguished road.
V8 recommended plugs are DENSO made K20R–U or NGK made BKR6EYA
Old 10-02-2005, 06:59 PM
turbohawk's Avatar
Dealer : San Marcos Toyota
2003 Toyota Tundra
turbohawk's Photo Albums
Last Online: 05-22-2008 05:18 AM
turbohawk is on a distinguished road.
Send a message via Yahoo to turbohawk
Why not use the platinum BKR6EGP? Anyone know what the difference between the "g" and "v" power designations?
Old 10-03-2005, 07:22 PM
Joe's Avatar
Joe Joe is offline
Dealer : Tim Corwin Toyota
Joe's Photo Albums
Last Online: 09-09-2008 11:55 AM
Joe is on a distinguished road.
The NGK numbers are as follows but just remember that each company has their own special meanings:
BKR6EIX-6418
B stands for the diameter, which is 14mm for this plug
K stands for 5/8 hex with projected tip
R stands for resistor
6 stands for the heat range
EIX stands for Iridium
6418 stands for the product stock number
V power means the plug has a 90*V-cut electrode
G power designates it as a single platinum plug
Old 10-03-2005, 07:28 PM
turbohawk's Avatar
2003 Toyota Tundra
BKR6EIX-6418
What does the Y stand for in the stock plug? Is there any reason to not use the "G" or "V" plugs?
Old 10-03-2005, 09:34 PM
Joe's Avatar
Joe Joe is offline
Joe's Photo Albums
The Y stands for the V-grooved center electrode with 2.5 mm insulator. Use whichever plug you desire - I'd recommend the cheapest, as the only advantage to the expensive plugs is they should get you more mileage between changes. There is no other advantage to a stock engine. Here's a site: http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
http://www.ngksparkplugs.com/index2....000&country=US
Old 09-25-2006, 08:52 PM
Dealer : Continental Toyota
2008 Toyota Tundra Black Crewmax SR5
figit's Photo Albums
Last Online: Yesterday 02:38 AM
figit is on a distinguished road.
Default Re: Spark plug dillemma Help
Would there be any advantage to putting Iridium plugs in 2001 4.7? I'm due for a plug replacement and would like to know if they would help with fuel economy or power. The Iridium plugs did make a big difference in my boat and I was curious if they'd help the truck.
Similar Threads for: Spark plug dillemma Help
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 04:25 PM
Best Spark Plug? tuffloud1 Engine & Drivetrain 20 07-28-2007 09:57 AM
New Plugs nhparrot Engine & Drivetrain 1 10-21-2006 12:14 AM
Spark Plug Gap Discrepancy MikeT Engine & Drivetrain 8 03-04-2006 07:16 PM
Corrosion in spark plug wells on the V8 Dude Boy Engine & Drivetrain 5 08-06-2002 07:17 AM
