Annoying -- Parking Brake light stays on.
+ Reply to Thread
Results 1 to 11 of 11
Thread: Annoying -- Parking Brake light stays on.
  1. #1
    Join Date
    Feb 2005
    Location
    raleigh
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Annoying -- Parking Brake light stays on.
    2001 Toyota Tundra SR5 Access Cab
    I changed front disk brake pads. Then took off rear tire, then rotor, to see if brake pads need replacing....they did not, so put back.
    Ever since the Parking Break Light stays on......at one point it went off on occasion. Its more annoying then functional, but I occasionally forget parking break is really on.
    Anyone have any ideas...........I have tried to adjust the break cable in the rear to make sure cable had enough slack.....no effect.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter TMS2U's Avatar
    Join Date
    Sep 2001
    Location
    over yonder
    Posts
    1,849
    Liked
    16 times
    Images
    10
    Rep Power
    19
    The parking brake light also serves as a low brake fluid warning- check the fluid level and you'll likely find the culprit!
  4. #3
    Join Date
    Mar 2008
    Location
    Atlanta
    Posts
    20
    Liked
    0 times
    Images
    3
    Rep Power
    8
    Default Re: Annoying -- Parking Brake light stays on.
    Resurrecting this thread:
    My son's 00 4WD Access Cab has the parking break light always on. We have checked the fluid and it is at the max level. The wheels have not been off the truck in the past 4k miles and it has not been off road. My son carried it to Mall Of Georgia Toyota and the high speed tech there said it is a "vibration in the reed switch on the fluid level, they all do it". Any ideas on what to do or check (besides never going back to Mall of GA Toy)?
  5. #4
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,680
    Liked
    2796 times
    Rep Power
    238684
    Quote Originally Posted by TMS2U View Post
    Ditto on that. My 2000 Tacoma had a parking brake light on all the time. A friend of mine was helping me to replace the front pads and adjust the parking brake when I happened to mention it to him. He said "pop the hood" and sure enough my fluid was low. A few minutes later the parking brake light never came on again unless the brake was engaged.
    Easy fix and great feeling not seeing that light on all the time.
    290,343 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, used and abused volant intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    Highwaylizard needs a new front bumper
  6. #5
    Join Date
    Mar 2008
    Location
    Atlanta
    Posts
    20
    Liked
    0 times
    Images
    3
    Rep Power
    8
    Quote Originally Posted by Tsquare79 View Post
    The fluid level is not the problem...
  7. #6
    Supporter MEvang's Avatar
    Join Date
    Jul 2005
    Location
    Colerain
    Age
    55
    Posts
    1,217
    Liked
    14 times
    Rep Power
    604
    Have you tried unplugging the brake fluid sensor on the master?
    Mike
    “The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
    Moderator Brake Forum
  8. #7
    Professional Driver tundra05_trd's Avatar
    Join Date
    Feb 2006
    Location
    Templeton, MA
    Age
    31
    Posts
    501
    Liked
    0 times
    Images
    10
    Rep Power
    11
    You could check the actual switch for the light. It should be under the dash by the top of the parking brake pedal (I believe, but not sure). Something could be sticking or the switch itself could be bad. Also look at the wires and connection. I would go look at my truck to find the switch but its pouring right now. Hope this helps!
    2005 Stepside TRD AC- phantom grey pearl, Toytec Coilovers set at 2.5", 285/65/18 Nitto Terra Grapplers on Pro Comp 18x9 9089's, Magnaflow 15820 cat back, K+N fipk, Pioneer in dash dvd, 2 Infinity Kappa 8's under rear seat w/Directed 600d amp, all Infinity Kappa components in doors, Escort Passport 8500 radar hardwired, Scangauge II w/ blendmount, clear corners, 35% tint, Tonneaumasters tonneau cover, fog light mod, Silverstars, Optima Red Top, Wet Okole seat covers w/TRD logo, Hellwig 7700 sway bar, LED Bed lighting(awesome mod!) Next: do something about the ugly stepside taillights
  9. #8
    Junior Member v6er's Avatar
    Join Date
    Nov 2004
    Location
    c-ville virginia
    Posts
    276
    Liked
    0 times
    Rep Power
    11
    It's possible the sensor is faulty, like the tech said. Also did you try adjusting the parking brake? I actually had the exact same problem a long time ago, I just wish I could remeber what the problem and fix ended up being. It was not exactly the top concern when my transmission grenaded.
    "The glass isnt half empty or half full...
    its twice as tall as it needs to be"
    ~How an engineer views life
  10. #9
    Join Date
    Mar 2008
    Location
    Atlanta
    Posts
    20
    Liked
    0 times
    Images
    3
    Rep Power
    8
    I pulled the plug off of the sensor on the reservoir and the light goes out. The light still works for the parking break so it will stay off until I get around to replacing the sensor.
    Thanks for the assist...
    TT
  11. #10
    Join Date
    Jan 2011
    Location
    Orono Maine
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    I have the same problem on my 2000 tundra. I need it to be inspected very soon and want to figure out how to shut the brake light off.
  12. #11
    Rookie FirstGenTundra's Avatar
    Join Date
    Mar 2011
    Location
    Winchester, VA
    Posts
    14
    Liked
    3 times
    Rep Power
    0
    Thats great info guys! My brake light has been on for the last 8 to 10 months till today, would have never guessed I needed to add brake fluid to turn that off. I though my sensor had gone bad. You all rock!
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Parking brake light comes on?
    By X-runner in forum 4Runner
    Last Post: 08-30-2005, 02:01 PM
  2. parking brake light stuck on
    By chrislloyd in forum 1Gen-Brakes
    Last Post: 01-13-2005, 11:23 AM
  3. Replies: 7
    Last Post: 08-27-2004, 01:41 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
