This is a discussion thread titled "Warranty questions.", within the 1Gen-Tundra forum, part of the Truck Forums category.
I have an 05 double cab tundra I am looking into adding a lift, new tires & wheels. Will I have any warranty problems that I may void. What kind of things should I look out for? Thanks.
MOSS ACT AS QUOTED FROM OTHERS STATES THAT THE AFTERMARKET PART MUST BE DIRECTLY RESPONSIBLE FOR THE FAILURE OF THE OEM PART. Otherwise they will hold up the warranty. However some dealers are more lenient than others.
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Thanks,
Drake
Legally, a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson Moss Warranty Act (15 U.S.C. 2302(C))
Forum Rules
Anything that you do to the truck that causes damage is your cost, not Toyotas. For example, if your lift causes u-joint failure, you pay. If you lift and the radio breaks, Toyota pays for the radio.
Some things are not that black & white. Bigger tires create an effective higher gear ratio, so more load is put on the transmission, u-joints, and differential. If those fail, who really knows if they would have failed without the big tires, or if the big tires caused the failure.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
