Old 10-14-2005, 06:26 PM
Dealer : Nye Frontier Toyota/Scion
Last Online: 11-16-2009 01:30 AM
alaska04 is on a distinguished road.
alaska04's Photo Albums
Default Gas Mileage In Cold Weather
Just curious what other Tundra owners are getting for gas mileage in temps below 40 degrees. I typically get pretty decent gas mileage in the summer with 18-20 mpg with my 00 V8 4 X 4.
Living in Anchorage, AK we typically don't have to use are AC much so that certainly helps with the gas mileage. But as the temps. have dropped I've already noticed that my gas mileage has slipped to about 14-16 mpg with no change in the way I drive. I know that gas mileage typically drops as the temp. drops.
Any other fed back from other people's experience would be great!!
Old 10-14-2005, 08:58 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Today 03:54 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
I'd consider myself very fortunate to see 18-20 mpg in the summer. My highest summer mileage ever was 18 and it's usually around 16.5 to 17.3. Winter runs 14-16 here in Minnesota. Our fuel is 10% ethanol to support the local farmers which knocks the mileage down.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 10-15-2005, 12:42 AM
Dealer : Funk's Toyota
2005 Toyota Tundra
Last Online: 11-23-2009 07:52 PM
Diego is on a distinguished road.
Diego's Photo Albums
With my 05 Tundra 4x4 I was getting 10 mpg city and about 17 highway last winter. In summer it went up to about 13 city and 20 highway. This is in Imperial gallons.
Old 10-15-2005, 04:24 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Unless you've disconnected the wire, your AC runs when you have the ventilation set to defrost or combination heat & defrost.
Ken
Old 10-15-2005, 11:50 PM
I thought that the compressor only turned on when you turned the AC on. So basically I don't need to turn the AC on when I select defrost?
I guess maybe that's why my gas mileage drops so much. Are maybe I'm just greedy when I get 20 mpg in the summer.
Old 10-16-2005, 11:09 AM
Dealer : Heffner Lexus Toyota
2005 Toyota Tundra
Last Online: 06-28-2009 09:55 PM
4.7 vvt-i is on a distinguished road.
4.7 vvt-i's Photo Albums
I notice my gas milage drops as the temperature drops.Partly to blame for this is the gasoline itself.Before the winter the oil refineries change the formulation of gasoline to a winter blend.Basically the winter gas is a lighter more volatile fuel and it contains less energy per volume and therefore worst milage.
Old 10-16-2005, 01:36 PM
dephelps's Avatar
Lifetime Member
2001 Toyota Tundra,
2005 Lexus RX330,
- Other - 1993 Toyota Corolla
Last Online: 10-29-2007 02:18 PM
dephelps is on a distinguished road.
dephelps's Photo Albums
I also live in Alaska. Although I am out in Eagle River. I imagine we buy gas from a lot of the same sources. I have a 2001 with 33 inch tires tires so I have never seen 18 MPG, I normally get 16.5 in the summer and drop to 12-14 in the winters. Most of my driving is between ER and Anchorage or Elmendorf. I normally drive around 70 MPH and know I could improve the milage by dropping down to 60-65 but would prefer to stay with the flow of traffic. Besides, in the winter I drive much slower and my gas mileage is worse yet.
My personal opinion is you are doing about normal for a Tundra.
Dan
Aftermarket Gas Mileage Computer? USMC_Family04 Aftermarket Products 21 08-11-2009 09:18 PM
Gas Grade and Mileage?? fly_trekker Highlander 6 09-08-2005 08:08 PM
Best Gas Mileage autobus83 Engine & Drivetrain 1 12-20-2003 04:21 PM
Cold Weather Package (heater) LGL002 Interior & Exterior 3 01-24-2003 10:30 PM
Poor gas mileage in cold climate v8Toilet Engine & Drivetrain 23 12-15-2002 03:39 PM
