Originally Posted by iamiles
it's a 4WD TRD. the front springs are pretty stiff. i did tried using a couple cheap spring compressors loaned from pepboys, they weren't able to compress the front springs. the spring compressor shaft curve, didn't want it to fail, and pay for broken spring compressor. so i stopped trying...
yeah, i like to work on it myself. i replaced the rear struts already and were very easy.
Hey iamiles,
BELIEVE ME! You
CAN compress the stock springs with the "rented" spring commpressor you had from Pepboys... I PROMISE. I just recently switched out my stock OEM TRD coils, for a set of
Wheeler's coils. Truth is... I knew ABSOLUTELY NOTHING... about a spring compressor when I decided to do this mod myself, with the help of another TS.com member. If you think the "stock" coils are a bitch to compress... try compressing a set of those
Wheeler's coils!
The
MAIN THING IS... BE CAREFUL!!!
Let me ask you 2 quick questions, regarding your attempt at using the rented spring compressor, before I go any further.
1st. Did you get the correct "model" of spring compressor? There are 2 different types. Just a thought...
. O.K., assuming that you did get the "right" one, my
2nd question is...
DID YOU REMEMBER TO "LUBE" THE THREADS ON THE SPRING COMPRESSOR? I
didn't and had one HELL OF A TIME getting the driver's side coil compressed! ESPECAILLY considering that the driver's side
Wheeler's coil, is stiffer and taller than the
Wheeler's passenger side coil! Not to mention the obvious... that both
Wheeler's coils are stiffer and taller than the OEM stock coils! Thank God, I remembered the lube before we started on the passenger side! Take a look at my
WRITE-UP. Hopefully it may help you, even though you're not planning on changing out the stock coils with something stiffer and taller as I did. The stock coils are actually... a "breeze"... to compress in comparison!
So if a "rented" spring compressor from Advance Auto can do the job, I'm fairly CERTAIN the one you used from Pepboys, is just as capable!
And "yes" the thread bolts of the compressor WILL bow as did the one I used...
Keep in mind... that's the
Wheeler's coil the compressor is attached too. And TRUST ME... these coils are a LOT harder to compress than the stock coils are!
I actually spoke with a TS.com member, who's been a Toyota Master Tech for 25 years before I began my project and he acutally
recommended the manual spring compressor (like you were using) over a pneumatic one. He actually said they were a little "safer" too.
I certainly can understand your apprehensiveness in watching that bolt bow, but that's how these spring compressors are designed. In my case, hind sight being 20/20, I probably would have taken my coils to a shop and had them "swtiched" out, but PRIMARILY because... of just how
bad I buggered-up the powder-coated finish on the
Wheeler's coils!
I was also trying to save a little money as well...
The
BOTTOM LINE is... just as (dyogim) said...
Originally Posted by dyogim
If you don't feel comfortable, take them to a shop and have them compress the spring and replace the shock.
I just wanted you to know that another "novice" like yourself, was able to tackled the job himself and to offer you a few words of encouragement.
Dave
