This is a discussion thread titled "Brake Light Coming On?! Help?!", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 10-31-2005, 11:41 AM
HockeyFreak's Avatar
Dealer : Leith Toyota
HockeyFreak's Photo Albums
Last Online: 10-28-2008 04:12 PM
HockeyFreak is on a distinguished road.
Send a message via MSN to HockeyFreak
Default Brake Light Coming On?! Help?!
Okay, here is the deal....whenever I have to brake with moderate force the brake light on the dashboard comes on!?! This is the one that indicates that your parking brake is on. The parking brake is released and does not have any slop in it to make the light come on..
Any ideas would be helpful...thanks.
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD*
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
Shawn
Southeast Region Forum
Old 10-31-2005, 11:45 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Today 06:11 AM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
Check brake fluid - the light also comes on when fluid is low.
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 10-31-2005, 11:47 AM
Hmm....I'll check that out! Thanks Glenn.
Anyone else have a suggestion??
1946 John Deere A
Shawn
Old 10-31-2005, 12:21 PM
natelev's Avatar
Dealer : Madera Toyota
2004 Toyota Tundra
natelev's Photo Albums
Last Online: 04-21-2008 09:48 PM
natelev is on a distinguished road.
Yes, your brake fluid is low. As your pads and shoes wear down more fluid is required in each slave cylinder thus resulting in a low brake fluid resivoir. Also when you push on the brakes hard you are forcing more fluid to the slaves and away from the resivoir and low level switch.
Old 10-31-2005, 12:35 PM
krodad's Avatar
Dealer : Wilson Oldsmobile Cadillac Toyota
2005 Toyota Tundra
krodad's Photo Albums
Last Online: 07-22-2007 01:23 AM
krodad is on a distinguished road.
Low brake fluid and/or a differential in front-rear pressure...check the rear brake cylinders for a leak as well.
Old 10-31-2005, 12:44 PM
Okay, this may sound stupid....but....can I just add more fluid, or should I just take it to a shop? I have done a lot of mechanic work on trucks over the years, but I have never mess with the brake system.
PS. Krodad - It looks like we have a football game between our two schools this weekend! KSU vs. ISU...
1946 John Deere A
Shawn
Old 10-31-2005, 12:52 PM
tripleb's Avatar
Dealer : Quality Imports Toyota Scion
2005 Toyota Tundra,
2006 Toyota Avalon
tripleb's Photo Albums
Last Online: 08-16-2008 05:26 PM
tripleb is on a distinguished road.
Hello HockeyFreak,
Yes, you can add fluid, make sure that you add the proper fluid type.
However, there is no such thing as a "Brake Fluid Monster" , if you need to add a lot of fluid or add fluid frequently, chances are you have a leak somewhere in your brake system .
Good luck
Edited for clarification.
2005 Tundra A/C Stepside 4x2
Natural White/Light Charcoal Cloth
TRD Sport Package
Towing Package
Cloth Captains Chairs
JBL 6 Disk/6 Speaker CD
All Weather Guard Package
Carpet Mats
Toyoguard Plus Protection Group
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Buy a small bottle at any auto parts store. Add a few ounces to the reservoir. The reservoir has the full level marked.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 10-31-2005, 12:53 PM
Dealer : McGeorge Toyota
2001 Toyota Tundra,
2004 Toyota Sienna,
2007 Toyota Prius
userw5's Photo Albums
Last Online: Today 10:07 AM
userw5 is on a distinguished road.
HF,
Yes you can just add more fliud. But this may be an indicator that your pads are getting a little worn. Do a visual check of them, too.
Jeff
Old 10-31-2005, 01:05 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
LGL002's Photo Albums
Last Online: Yesterday 06:21 PM
LGL002 is on a distinguished road.
Originally Posted by tripleb
Hello HockeyFreak,
However, there is no such thing as a "Brake Fluid Monster" , if you need to add fluid, chances are you have a leak somewhere in your brake system .
Good luck
As brake material wears from the pads and shoes the caliper pistons and wheel cylinder seals move outward and additional brake fluid is used to fill the expanded volume behind them.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 10-31-2005, 01:09 PM
Well, I may just take it in to my mechanic and have them check the brake system over just to make sure everything is fine.
1946 John Deere A
Shawn
Old 10-31-2005, 02:21 PM
krodad's Avatar
2005 Toyota Tundra
HockeyFreak...two pretty closely matched teams if you look at the stats...almost identical rushing, passing, points, etc. We just kicked the crap out of A&M and we're on a roll and we're home. Good luck to the 'Cats but I gotta hope the Clones can keep it going...my wife promised me that If the Clones go to a bowl, I can go to.
Can anyone say "off-topic"?
Old 10-31-2005, 03:17 PM
tripleb's Avatar
2005 Toyota Tundra,
2006 Toyota Avalon
Larry
Hello LGL002,
I edited my post for clarification ..... actually said what I meant to say
TRD Sport Package
Towing Package
Carpet Mats
Old 10-31-2005, 03:20 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
After four years, it is past time to complete flush and renew the brake fluid. Brake fluid absorbs moisture from the atmosphere. The water in the brake fluid lowers the boiling point of the fluid. Very heavy braking can generate enough heat to cause the brake fluid to flash to vapor. Your brake pedal goes to the floor and you have no braking. I've know this to happen to a friend, and read about it happening in a nearby hilly state park...a death resulted.
http://www.raceshopper.com/brake_fluid_faq.shtml
I'd suggest that you have the shop do a brake fluid flush and replacement even if the brakes are good. My choice for front brakes would be Wagner Thermoquiet if you don't go to a high performance pad like Hawk or Performance Friction. http://www.federal-mogul.com/cda/con...6_7293,00.html
Ken
Old 11-01-2005, 07:57 AM
ibleedblue's Avatar
Dealer : Griffin Toyota
2005 Toyota Camry SE Indigo Ink,
2006 Toyota Tacoma DC TRD Sport
ibleedblue's Photo Albums
Last Online: 09-12-2008 07:46 AM
ibleedblue is on a distinguished road.
Larry
What he said! I highly doubt the system is leaking, cause you would have noticed drips on your nice, new concrete garage floor. If you take it to the mechanic, I'll bet good money that he tells you it's almost time for new brakes all the way around. Dumping in more brake fluid will keep the light from coming on, but when you do eventually add the new pads & shoes your going to have to siphon some of the brake fluid out of the resevoir so you don't have a major mess when you push the pistons back.
2006 Tacoma Double Cab, Indigo Ink Pearl, TRD Sport, 4WD, V6, 6 Speed
Mods to date: Extang Full-Tilt Tonneau, Pioneer DEH-P7800MP, Elemental Designs Nine.4, Elemental Designs Nine.2x, Elemental Designs 11Kv.2, CDT EF-61's, Sirius Starmate Replay, Weathertech Floor Liners, EGR In-Channel Vent Visors, Aires Black Oval Step Bars, Fog Light Mod, Bed Storage Lock Mod, CoverKing Neoprene Seat Covers, DRL Mod, Map Light Mod
Future Mods: Bed lights, some kind of exhaust....maybe
Similar Threads for: Brake Light Coming On?! Help?!
TRD "REAL LETTERING" Third Brake Light Cover twism89484 Interior & Exterior 4 12-05-2004 09:57 PM
Third Brake Light Question sdmahr Interior & Exterior 4 01-28-2004 08:40 PM
Converting Cargo to Brake light? unixguru Interior & Exterior 8 08-27-2003 08:46 PM
Fog Light Mod Quirks nhparrot Electrical & Computer Systems 0 03-28-2002 01:16 PM
