Does anyone know what the proper tire pressure for the Pirelli 295x45's
is supposed to be? These are the tires that come with the Tundra X-SP
package. The door jam lists the pressure for the standard tires at
32psi front and 35psi rear.
The tire itself indicates 51psi at max load (which seems a bit high for normal
loads)
I checked all of my tires and they were all at 28psi so I inflated both
front and back to 35psi. But I have no way of knowing what the optimal
pressure is for an unloaded truck. My truck is a 2005 DC.
Has anyone with the X-SP setup had any luck finding out what the proper
tire pressure is supposed to be? The Pirelli and Toyota websites are no help.
I have the Enkei's with Falken tires of the same dimension as yours. You can use the factory spec for tire pressure and be just fine. The tire pressure listed on the sides of the tires are MAX pressure for that tire, not the recommended pressure for your vehicle.
I was having a slight feathering problem with my tires, so I increased the pressure to 40 psi front and 36 psi rear. This stiffens things up a little and doesn't allow the tire to flex as much, and it has stopped my feathering problem. Before anyone comments, yes the alignment has been checked and is correct.
Tire pressure is debatable for non-factory size tires, but what I have learned is that if they start wearing in the center more than the outer tread, the pressure is probably to high. If your pressure is to low, the the outer edges of the tire will wear faster than the centers.
Anyway, I have found on my 295/45/20 tires that 40 psi front and 36 psi rear is wearing pretty even. The reason for more pressure in the front is they carry more weight (unloaded) and the have a tendency to wear more especially if you drive mostly in town and take a lot of corners. Since most of my driving is around town at lower than highway speeds, the higher pressure helps to stop the feathering and other weird wear patterns.
Phil
__________________ 05 White TRD D-Cab, SR5, Limited slip, 20" TRD Enkei's with BFGoodrich G-Force TA NT, All weather guard package, factory rear privacy glass with matching front door tint, Toyota bedliner plus bed mat, Toyota/A.R.E. color keyed tonneau cover, overhead console with temp, compass and Homelink, Toyota/Gentex electrochromatic mirror, keyless, mats, TRD aluminum front skidplate, Toyota/Bazooka VSE 100 watt self-powered subwoofer, TRD stainless exhaust tip, door sill guards, Custom TRD matched pin striping with Toyota logos, painted calipers with TRD letters, TRD billet aluminum third brake light cover with true TRD letters, Pioneer AVIC D-3 GPS head unit with IP Buss controlled Pioneer XM radio tuner and iPod interface, Pac remote(maintains steering wheel controls) Polk Audio speakers DB675 two way in rear, Polk DB6750 components in front powered by a Polk C400.4 4 channel amp, seperate amped Aura Pro Bass Shakers under each front seat, Bazooka EL series 8" 100 watt self-powered subwoofer with Polk Momo driver with quick disconnect, Memphis tweeters in rear, back-up sensors (very handy), foglight mod, Sylvania Silverstars in both head and fog lights, added rear halogen back-up lighting, BellTech 6700 1" lowering shackles, Hellwig anti-sway bar, Magnaflow 14586 Stainless muffler, Wheelskins two-tone leather steering wheel cover, Ventvisors for side and rear windows, custom lower grill insert, Hoppy tailgate spring. More to come!
I was thinking about going up to 40psi. That's 80% of the tires rated
max pressure and I read somewhere that 80% is a good rule of thumb.
I know that looking at the wear pattern will tell you if you're over or under
pressure but I don't want to wait until I have uneven wear to figure things
out.
I expect I'll get slightly better gas mileage with more pressure in the tires.
I just hope 40psi isn't over doing it.
Running 32PSI with the last set (and a good alignment) I was getting cupping on the front shoulders. I just got a new set of Toyo's I am trying 36PSI front and rear now. So far so good.
2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
