This is a discussion thread titled "Anyone think running Premium gas makes a differance in milage?", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 11-02-2005, 01:05 PM
TheGryme's Avatar
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
TheGryme's Photo Albums
Last Online: Today 10:48 AM
TheGryme is on a distinguished road.
Default Anyone think running Premium gas makes a differance in milage?
Just wondering.....
I drive at least 120 miles a day....across open roads....little stopping. Setting my cruze at all of 61......or if I'm feeling daring.....63mph, I get about 18 MPG running on the "A" map (UNICHIP) on regular gas.
I have yet to hear this engine ping....(I don't even know what this one sounds like pinging! ) so I wonder what effect if any higher octane gasola might produce......milage wise.
I have always equated milage with power....an underpowered '80's era truck with a 318CI engine would get about 12 MPG but the same truck with a 440 would get 15. I know 'cause I used to do these swaps. I always figured the 318's were working too much at wide open throttle to move the truck and the 440 had way more power on tap and didn't have to be ran at WOT.
So maybe higher octane gas will produce more power and the truck can be ran at a lesser throttle setting and get the same MPH on less gas?
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Nitto Terra Grapplers LT265 75 16's, Magnaflowed (w/ Secret AirBox Mods!), UNIChipped, True~Flowed, DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, ASV Controls....
'87 Nissan Pathfinder......gave to son in Oregon
Old 11-02-2005, 01:08 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Very unlikely that you will have a lower cost per mile with high octane gas. That's what really counts...fuel cost per mile, not miles per gallon nor cost per gallon.
You will never hear ping unless the knock sensors or other electronic parts fail. Some engines, not ours, build up carbon in the combuston chambers and ping when the red hot carbon ignites the fuel charge before the spark fires.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 11-02-2005, 06:47 PM
Dealer : Taylor Lexus Toyota
2006 Toyota 4Runner
2btundra's Photo Albums
Last Online: 10-11-2007 07:29 AM
2btundra is on a distinguished road.
Just the opposite for me. I've run 87, 89, and 93 in my '05 V8 Access Cab at different times. The lower the octane, the better the mileage. I can get 35-40 more miles on a tank of 87 as opposed to 93.
Old 11-02-2005, 07:56 PM
cubic22's Avatar
Dealer : Durant Toyota
2002 Toyota Tundra
cubic22's Photo Albums
Last Online: 11-17-2008 10:54 AM
cubic22 is on a distinguished road.
Send a message via Yahoo to cubic22
Gas is gas is gas...unless..its ~GAS~
Clean throttle body, good spark plugs, clean air filter, and if you drive that much go ahead and spring for Nitrogen in the tires vs o2
JOHN
Old 11-02-2005, 08:32 PM
Inactive Account
Dealer : Toyota Scion of Tri-Cities
1993 Toyota 4Runner
djw29's Photo Albums
Last Online: 05-07-2006 05:07 AM
djw29 is on a distinguished road.
Default no benefit to running premium in motors that don't require it
Higher Octane fuels are more resistant to pre-ignition. Meaning that the fuel is less volatile or slower burning than low octane fuel. Only engines with high compression ratios need higher octane slower burning fuel because the higher the compression ratio, more heat is generated, which preignites fuel (pinging)unless an an additive is used to slow the burn. On some motors pinging can be very damaging. This is why supercharged rigs run premium, a greater volume of air is crammed into the cyllinder which creates more heat in the compression stroke and thus preignition of the fuel unless you use higher octane gas. So if your engine doesn't require premium, don't use it. In a lower compression motor it actually makes less power and produces more pollutants out the tailpipe than the lower rated fuel.
Old 11-03-2005, 12:12 AM
S-Man's Avatar
2002 Toyota Tundra
S-Man's Photo Albums
Last Online: 10-06-2008 11:45 PM
S-Man is on a distinguished road.
What about using synthetic oil? i heard on tv that synthetic oil, although more expensive, will give you better gas mileage...probably not mileage worth the increased cost of syn oil, but i'd still like to know.
Old 11-03-2005, 12:14 PM
TheGryme's Avatar
2004 Toyota Tundra,
Thats interesting....I knew the info about pressures / heat and pinging...and damage caused (ask me about my $7K 3.0 engine someday ) I read a post in here a while back from a guy that just got a custom tune on his UNICHIP and was telling of special listening devices the shop used during the tune/ dyno to "listen" for ping. I'd like to know more about the tool used.
My truck seems to run the same (good ) on any gas......so far.
But I'm always looking for an edge in the gas milage dep't.
'04 Tundra DC
'92 4Runner
'04 YZ250F
Old 11-03-2005, 12:24 PM
supritdeol's Avatar
Dealer : Dublin Toyota Scion
2006 Toyota Corolla
supritdeol's Photo Albums
Last Online: 03-25-2008 01:39 PM
supritdeol is on a distinguished road.
Nitrogen in tires makes no difference in MPG's. N2 gas is used my some shops because it stays in the tire longer than oxygen.
Old 11-03-2005, 01:08 PM
dannozrx's Avatar
Dealer : Carlson Toyota
2002 Toyota Tundra
dannozrx's Photo Albums
Last Online: 02-14-2007 02:42 PM
dannozrx is on a distinguished road.
It probably wouldn't make a difference unless you also can find a chip that is programmed to work with the higher octane gas. I had 95 Chevy that I ran 92 octane for a few weeks, thinking better mileage, that got the same mileage and began stalling at times. The tech at the dealer found out what I was running for gas and told me to go back to 87 cause that is what the chip was programmed for.
Old 11-03-2005, 01:27 PM
Crx722's Avatar
Crx722's Photo Albums
Last Online: Yesterday 07:04 PM
Crx722 is on a distinguished road.
I use 85 in montana and dont notice any different from 91 at home
Old 11-03-2005, 03:35 PM
cubic22's Avatar
2002 Toyota Tundra
Talking
Correct it does not leave the rubber as quickly, does not eat away at the inner lining, and does not heat up as fast so you can keep the psi level more consistant...and I always thought keeping your psi level constant is a good way to conserve gas.
JOHN
Old 11-03-2005, 04:11 PM
student's tundra's Avatar
Dealer : Longo Toyota
2003 Toyota Tundra,
1998 Toyota Camry Daily Driver
student's tundra's Photo Albums
Last Online: Yesterday 03:43 PM
student's tundra is on a distinguished road.
Correct. We have been using Nitrogen in our customers cars for a year or so now. I believe that the molecules in Nitrogen are seperated more than oxygen. Thus allowing for more resistance to contracting and expanding with the daily elements. This is why Nitrogen will not escape as fast as oxygen in automotive tires. In addition, I have been told that it is supposedly saver in terms of tire blowout, can confirm this however. Just what I have picked up .
2003 Tundra Imperial Jade TRD offroad
Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed
Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade
Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Old 11-03-2005, 04:50 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Modern engine control systems work best at every altitude with the fuel the engine was designed to run. This would be 87 even in the Rockies. 85 is the fuel of choice for an old, carbureted engine designed for low octane gas and run at high elevations. If you carefully measured engine performance, you'd get better performance with 87 over 85, even in Bozeman. (I use 85 in the Rockies...runs OK and is cheaper. I haven't tested to see which gives the lowest fuel cost per mile.)
Ken
Old 11-03-2005, 07:32 PM
Dealer : Toyota of Tacoma
2005 Toyota Tundra
fcatwo's Photo Albums
Last Online: 04-21-2008 07:25 PM
fcatwo is on a distinguished road.
I question whether there are any absolute rules on the "octane" thing. We had a 2002 Honda Odyssey minivan that the owners manual specified 87 octane but the towing section of the manual said premium fuel would provide better performance while towing. My trials were far from scientific but it seemed to hold transmission lock-up longer with premium which could provide a slight fuel economy advantage because of reduced engine revolutions per mile while towing -- but then, who knows. I often use premium in the Tundra and I think it runs quieter, has more power and my wife is less crabby than when I run 87 :-). I see buying premium as money well spent. Also, since many stations have kept the same 10 cent spread between fuel grades, $3.20 for premium is only 7% more than $3.00 for regular while $1.20 was 20% more than $1.00 for regular. It's a relative bargain now.
Frank
Frank
05 SR5 AC Tundra V-8 4X2
Similar Threads for: Anyone think running Premium gas makes a differance in milage?
Gas Milage rirrgang Engine & Drivetrain 20 05-27-2006 07:04 AM
Running it Close on Gas!!! BT-22 1Gen-Tundra 6 10-23-2005 12:53 AM
Look at those Tundras go! Toyota Wins at Kansas! tundrabrad Off-Topic 1 07-03-2005 12:24 AM
Rocket fuel? glenhaven Engine & Drivetrain 5 08-14-2004 12:48 PM
Why must I run premium gas to avoid engine noise?? Scott Hawn Engine & Drivetrain 5 02-12-2003 08:04 PM
