This is a discussion thread titled "Tundra transmission problems (failure) -- V8 automatic", within the 1Gen-Tundra forum, part of the Truck Forums category.
  #16 (permalink)
Old 11-13-2005, 01:49 PM
Dealer : Fitzgerald's Lakeforest Toyota
lawnmowing20837's Photo Albums
Last Online: 10-21-2008 09:08 AM
lawnmowing20837 is on a distinguished road.
MEvang,
Yes, I'm glad it wasn't the trans, also!!
Here's how I use my truck: I do short trip, city driving with around 1000lbs loaded in the back at all times... the truck is used in my lawn business. I use my cars for personal use. I drive a 92 Civic EX ABS with 4 wheel discs, and my wife has a 98 Acura 3.0 CL with 4 wheel discs and ABS. I love the brakes on both cars, and can feel the difference (poor brake feel) with the Tundra having drums in the rear. I think my Tundra has the proportioning valve, and also has ABS. If later Tundras use the ABS to proportion brake force, is it possible to remove the proportioning valve in my Tundra altogether?
  #17 (permalink)
Old 11-13-2005, 02:01 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Your poor brake feel might be due to air in the braking system. The proportioning valve has a bleeder, and it is difficult to remove all the air from this spot. Anybody can do it, but it has to be done completely. Being the high point, the proportioning valve retains more air than the wheel cylinders.
The job of the proportioning valve is to allow higher braking effort from the rear brakes when there is more rear tire traction due to more weight on them. The pro-valve is attached to the truck frame above the rear axle. It has a linkage to the rear axle. when the frame is closer to the axle due to weight in the bed, you get more rear braking.
I have no problem with my rear drum brakes. Keep in mind that all heavy trucks, buses, etc., have drum brakes. The rear brakes are self adjusting every time you use your parking brake.
ABS does a different job than the proportioning valve. ABS limits wheel skid, and the wheel must skid before the ABS begins to work. I would not remove the proportioning valve, and I wouldn't worry about the drum brakes except to get them into good working order.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
  #18 (permalink)
Old 01-03-2008, 12:23 PM
Dealer : Quality Toyota Scion
RFAZ's Photo Albums
Last Online: 01-11-2008 04:47 PM
RFAZ is on a distinguished road.
Default Re: Tundra transmission problems (failure) -- V8 automatic
My son just purchased his 2007 Tundra last week and the transmission is gone already! It's at the dealer being fixed as I speak - they have to replace the entire transmission. He drove his new truck to the river over this past weekend, drove through some sand, and all of a sudden the tires stopped spinning and an awful grinding noise. He had to drive it home like that as no Toyota dealer around. Dealer didn't mention that this is a recurring problem until I told them I checked the internet and found that many are experiencing the same issue with their Toyota trucks & suv's. Has anyone had any further problems with transmission after it had been replaced? This makes me a little nervous.
  #19 (permalink)
Old 01-03-2008, 04:01 PM
Dealer : Muller Toyota
PJinNJ's Photo Albums
Last Online: 10-23-2008 02:03 PM
PJinNJ is on a distinguished road.
Just say you've got the "Roll Control" feature for free and enjoy it.
  #20 (permalink)
Old 01-03-2008, 04:13 PM
Tundrav8yamaha's Avatar
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2008 Toyota Highlander HV Limited i4wd,
2004 Toyota Tundra Trd Off road Navi
Tundrav8yamaha's Photo Albums
Last Online: Today 09:11 AM
Send a message via AIM to Tundrav8yamaha Send a message via Yahoo to Tundrav8yamaha
Originally Posted by 04DSGTUNDRA View Post
you just drain and refill your tanny fluid??? you should be flushing it, theres alot of fluid that stays in your tranny so when you just exhange the fluid in the oil pan your not getting much of the oil, you should also change the filter.
Oh and I have 30k miles on my truck, I tow HEAVY loads (8000lbs + at times), and drive the truck hard, not one problem here with the tranny.... that being said, hopefully its something simple like brake caliper sticking or something, because in my eyes the tundra tranny are very strong (compared to chevy trannys that can't seem to go longer the 100k)...
I've
been told flushing is bad and doing a simple drain and refill is much better on the seal's. I've done the drain and fill method every 30k now and had yet to experince any issues. My First 2000 Tundra on the other hand I never touched the fluid and it had 124k because she was totalled out since brand new . My shop guy was surprised I didn't change the fluid and it lasted that long
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
  #21 (permalink)
Old 01-03-2008, 04:16 PM
- Other - yamaha,
I know a guy in Georgia who's new 2007 Had 600 miles and His truck took a dump on a problem on the 6 speed auto trans and being one of the first . It's a new Transmission i expected this to happen got to love them rushing product's out the door
  #22 (permalink)
Old 01-03-2008, 10:58 PM
Dealer : Toyota Carlsbad
2003 Toyota Tundra
kcstott's Photo Albums
Last Online: 09-13-2008 01:55 PM
kcstott is on a distinguished road.
I called my local very reputable tranny shop after sending the company ford over there for a grenaded tranny. I asked about my truck and was told that if it ever did go out plan on about 5K to rebuild. He also said that since it is very labor intensive to repair that I may want to think about selling the truck as soon as the tranny so much as hiccups. So ?????
2003 Tundra 4.7L
92 GMC K1500 5.7L
07 Kawasaki KLR650
Bridgeport Mill
South Bend lathe
Miller syncrowave 200
And other misc goodies and toys
Similar Threads for: Tundra transmission problems (failure) -- V8 automatic
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
transmission flush nhparrot Engine & Drivetrain 4 08-26-2007 08:46 PM
Symptoms of Transmission Failure kymatt Engine & Drivetrain 12 03-12-2007 09:47 AM
2003 Tundra Front Brakes Problems! 909tundra Brakes 4 12-16-2004 03:32 PM
Question about stock Tundra Foglights..Help! nhparrot Electrical & Computer Systems 0 03-28-2002 01:13 PM
