Just got my recall notice, I bought the truck used and it has a spacer lift. Should I have any problems w/ the recall work. I did see the post above, but darn it's too long to look through. Any help is appreciated.
You shouldn't have any problem at all. They did my recall and have done warranty work up front and I have Daystar spacers and wheel adapters. They could have cared less. I would just take it in and drop it off.
2003 TRD Stepside 2WD LSD, 275 Revos, 1 inch Daystar spacer up front, TRD AALs in the back, 1.5 inch Wheeladapter.com wheel adapters, Truxedo tonneau cover, Rhino Lining, Self-Dimming Mirror w/Compass & Temperature, RS3200 Alarm Upgrade, Stant 11506 Locking Gas Cap, Hellwig Anti-Sway Bar, Magnaflow 12586 on the way
I have and had a revtek 2.5 spacer lift on my truck when it went in for the recall notice. Nobody said anything and had no problems with it .
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
I have a 2.75" ezlift spacer kit and the dealer didn't say anything, you shouldn't have a problem either. It is kind of odd though, when they raise the front of the vehicle to do the ball joint service you would think they would notice the underside of the uca coming into contact with the coilover at full droop. I think I would notice...............
I bought my 2000 Access Cab from a private party and would like to know what do I need to do to receive these recall letters. I feel it is important because I would like to be notified and have something to show for if the dealer decides to give me a hard time. Thanks!
