hows everybody doing im gona buy a fmu (fuel management unit) almost the same as a fuel pressure regulator but anyways i need help on installing this if anybody out there has installed one of these could u help me i need to know where to cut the fuel line what to do with the existing regulator that sits on the fuel rail if any body could help me asap id appreciate it
ENGINE MODS: k&n fipk II, motorvation throttlebody spacer, kamealion colored throttle body cover, ss autochrome headers, ss autochrome y-pipe, flowmaster 40series muffler with chrome tip. stealth mode a 950cca dry cell battery, TRD limited slip diff.
EXTERIOR: TRD third brake cover,Towing harness, Powerpulse wig wag headlight flasher, sylvania headlight bulbs, tranparent TRD headlight emblems, Toyota symbol tribal on windshield, clear corners with blue lights and blue strobe lights, billet grille with blue strobe lights behind it, and finally more strobe lights in the reverse light.
INTERIOR: Clarion 7" touchscreen dvd player with two 12" 800watt audiobaun subs, powered by a jensen 400watt amp. bigger amp is on the way , two gauge pods mounted on the a pillar with a carbon fiber air/fuel ratio gauge in one and a carbon fiber 30invac/20psi boost gauge in the other and color matched.
What brand FMU? A true FMU is a rising-rate fuel pressure regulator,where fuel pressure increases a certain amount of PSI per pound of boost,for example a 12:1 FPR increases fuel pressure an additional 12psi per pound of boost. There won't be any power gain in a naturally-aspirated setup (I don't see turbo or sc listed in your mods),since there's no boost there won't be an increase in pressure. Or are you getting an adjustable fuel pressure regulator?
I haven't done a Tundra install,but I have installed both Vortech ones (FMU and SFMU) in other vehicles.
The FMU is a piggyback style,you keep the stock regulator on and tap into the return line. Run a new hose from the stock regulator to the FPR's side port. The FPR's bottom port connects to the original return line that was originally connected to the stock regulator. The stock return hose is probably too short so you'll need a length of new hose and a double-barbed fitting to connect to the factory fuel line. Top port is a vacuum/boost reference connection,don't use the factory connection (by airbox).Instead tee a source from the intake manifold.
The SFMU can be installed the same way,but since you can adjust static (base) pressure with it I use this as the main regulator and remove the factory one altogether. For a Tundra I'd either drill/tap the stock fuel rail (where the factory regulator was connected) for a new fitting or fab an adapter plate with a fitting already tapped on it. You then run a hose from this fitting to the SFMU's side port,SFMU bottom port to original return hose.
__________________ Try SEARCHING before posting. Thanks!
hey wasup thanks for the advice i got a turbo setup on the way and cant afford the the unichip and was told the other safe way was 2 buy a 255lph walbro and a fmu. the other problem is that i cant find a walbro for the tundra everywhere ilook theres no listing for the tundra maybe u could give a partnumber or cross reference another fuel pump from another vehicle using a 255lph walbro thatll fit. as to the fmu let me see if understand what u want me to do im gona disconnect the return hose and run a new hose from the regulator to the inlet on the fmu. then run a new hose from the outlet of the fmu to the origal return hose right?
Yup,new hose from stock regulator to FMU inlet,then another new hose from FMU outlet to the original return hose.
Some TS members run Walbros or Supra TT fuel pumps,you might want to try searching. I'd say use one for a Supra application,and I suggest getting the High Pressure 255 since you're running an FMU.
These guys have good Walbro pricing http://www.autoperformanceengineering.com/
And I found a photo of a Walbro pump installed on a Tundra: http://www.tundrasolutions.com/photo...cat//si/walbro
hey thanks for the info i bought a pump from the place u suggested a 255 and also a 12:1 fmu from ebayhopefully this will aid in my project until i save enough for the unichip
I have a Unichip programmed for boost, oversize crank pulley and nitrous that has never been installed. PM me and let's talk....you may be closer than you think. Either way, you will need the fuel system upgrade.
