Old 12-16-2005, 04:06 PM
Dealer : Phil Wright Toyota
2005 Toyota Tundra
Last Online: 07-01-2009 03:52 PM
Bravo11 is on a distinguished road.
Bravo11's Photo Albums
Default Tire pressure warning light.
'05 Tundra DC.
I had the tire pressure warning light come on at the beginning of the cooler season and I just assumed it was the change in the weather so I adjusted the pressures and the lamp went out. A week or so ago the light came back on but I let it ride because I could see that the tires were not bad. Last night I checked the pressures and they were only 2 to 4 lbs out of spec. I brought them back up but the light stayed on. The dealer said that I needed to check the spare to which I replied "bull". They insisted the spare was in the loop also so I guess I'll check it tonight.
How much tolerance does the system allow, +/- what PSI? Will the system warn if too much pressure?
How can I reset the warning if the pressures are good all around? This is still under warranty so I'm not going to do too much myself.
What all needs to be done when I get new tires?
Lots of ?'s
Thanks
Old 12-16-2005, 04:12 PM
Dealer : Estabrook Toyota
Last Online: 10-30-2009 01:14 PM
HeartsOfWar is on a distinguished road.
HeartsOfWar's Photo Albums
the spare is in the loop... read the manual it's in there...
Old 12-16-2005, 06:31 PM
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
Last Online: Today 11:58 AM
tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light.
tempetom's Photo Albums
I don't know what the tolerance is either but the reset button is under the steering wheel on the dash. I have slow leaks in 2 of the crappy Bridgestone tires that came with the truck and the light is nearly always on. I guess I'll get around to putting some air in em but wish they would wear out.
Old 12-16-2005, 06:36 PM
okcowboy's Avatar
Dealer : Jim Norton Toyota
2005 Toyota Tundra
Last Online: 09-19-2009 10:15 AM
okcowboy is on a distinguished road.
okcowboy's Photo Albums
Default tolerances
I don't know what the tolerances are supposed to be but have had the light come on when one tire was 2-1/2 lbs low.
I have since installed a custom extension hose from the spare to an existing hole in the frame so that i can check/adjust the pressure in the spare easier (i still have the spare valve stem pointing up)
I also purchased some valve stems caps from Walmart that allow you to set the pressure that they monitor and then they have a flashing light if the pressure drops 4 pounds. (not quite the 2-1/2 lb sensitivity of the dash light, but hey)
Now I can look under my rear bumper and see if my spare is flashing.
Old 12-16-2005, 09:14 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Yesterday 02:21 PM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Angry spare
I had the same problem its your spare.Kinda stupid but I guess in a way you wouldn't want to get a flat,go to change it and the spare be flat.
Old 12-16-2005, 09:56 PM
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: 05-14-2008 09:18 PM
faaengr is on a distinguished road.
faaengr's Photo Albums
I get this everytime it gets a little cold. And it goes away on its own in a couple of days after it warms up.
Old 12-17-2005, 06:11 AM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
Last Online: 11-08-2009 07:50 AM
cookiemech is on a distinguished road.
cookiemech's Photo Albums
My light came on when the spare tire pressure dropped 4 psi below where it was when I initialized the system, so it's pretty sensitive.
Old 12-17-2005, 10:54 AM
Dealer : Fox Toyota
2006 Toyota Tundra,
2005 Toyota Sequoia
Last Online: 11-03-2009 02:11 PM
Images: 20
RickC is on a distinguished road.
RickC's Photo Albums
Tire pressure changes with the ambient temperature. When it starts getting colder the pressure will decrease. My light came on the first night we had a cold spell. It got down to 20 degrees and the light came on. I checked all 5 tires and they were all at 28 lbs. I put them all back up to 35 lbs, and the light went out. The amount of change required to cause the light to come on is 5 lbs from it's programmed pressure. The reset button is what changes the programmed pressure.
RickC
Old 12-19-2005, 09:15 AM
2005 Toyota Tundra
Good info, thanks for the replies. How about too much pressure. If the specs call for 29psi and I put in 35 will the warning lamp come on?
Old 12-19-2005, 01:03 PM
Phil0411's Avatar
Dealer : Alan Jay Toyota Scion
2005 Toyota Tundra,
- Other - 1989 Supra Turbo
Last Online: 11-06-2009 08:54 AM
Phil0411 will become famous soon enough.
Phil0411's Photo Albums
No, it only will come on if the pressure goes below the preset.
05 White TRD D-Cab, SR5, Limited slip, 20" TRD Enkei's with BFGoodrich G-Force TA NT, All weather guard package, factory rear privacy glass with matching front door tint, Toyota bedliner plus bed mat, Toyota/A.R.E. color keyed tonneau cover, overhead console with temp, compass and Homelink, Toyota/Gentex electrochromatic mirror, keyless, mats, TRD aluminum front skidplate, Toyota/Bazooka VSE 100 watt self-powered subwoofer, TRD stainless exhaust tip, door sill guards, Custom TRD matched pin striping with Toyota logos, painted calipers with TRD letters, TRD billet aluminum third brake light cover with true TRD letters, Pioneer AVIC D-3 GPS head unit with IP Buss controlled Pioneer XM radio tuner and iPod interface, Pac remote(maintains steering wheel controls) Polk Audio speakers DB675 two way in rear, Polk DB6750 components in front powered by a Polk C400.4 4 channel amp, seperate amped Aura Pro Bass Shakers under each front seat, Bazooka EL series 8" 100 watt self-powered subwoofer with Polk Momo driver with quick disconnect, Memphis tweeters in rear, back-up sensors (very handy), foglight mod, Sylvania Silverstars in both head and fog lights, added rear halogen back-up lighting, BellTech 6700 1" lowering shackles, Hellwig anti-sway bar, Magnaflow 14586 Stainless muffler, Wheelskins two-tone leather steering wheel cover, Ventvisors for side and rear windows, custom lower grill insert, Hoppy tailgate spring. More to come!
Very funny Scotty, now beam up my clothes!
Old 12-19-2005, 02:13 PM
bugmenot's Avatar
Dealer : Toyota of Plano
2006 Toyota 4Runner,
2000 Toyota Tundra,
2003 Toyota Tundra,
2005 Toyota Tundra,
2004 Toyota Camry
Last Online: 08-31-2007 06:17 PM
bugmenot is on a distinguished road.
bugmenot's Photo Albums
Default how is the spare in the loop??
Can someone explain this to me. I thought if one wheel turned more or less than the others it was sensed and the dash light would come on. How can it tell if the spare is low??? The spare is not moving it's just sitting there. There would have to be some electronic device monitoring pressure and then sending that information wirelessly to some computer somewhere.
Old 12-19-2005, 07:46 PM
2005 Toyota Tundra
No, that's the old (indirect) system, as in my wife's 2001 Sienna. That system operated by taking input information from the ABS sensors at the wheels and comparing their speeds. The 2005-up Tundras have pressure sensors that are part of the valve stems (important to know when dismounting tires, as they can be rather easily broken by technicians unfamiliar with these sensors), and they do transmit data to the vehicle computer. That's why they can be much more sensitive to small pressure differences.
Old 12-20-2005, 06:19 AM
sarasota2k4's Avatar
Dealer : Germain Toyota Scion of Sarasota
2005 Toyota Sequoia
Last Online: 09-22-2009 12:37 PM
sarasota2k4 is on a distinguished road.
sarasota2k4's Photo Albums
Had a similar problem w/ 05 Sequoia. Temp dropped to 40 one night, the next morning pressure light was active. Check four tires and all were OK. Checked spare and it was @ 24. Filled to 35 and haven't seen light active since.
2005 Sequoia SR5
Phantom Grey Pearl
Sarasota, Florida
Leather, Roof rack, 17" Rims, Running boards, 6-Disc In Dash JBL, Convenience Package,
60Gb ipod Photo w/ ipod2car interface
Old 12-20-2005, 07:04 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 11:27 AM
nhparrot's Photo Albums
see attached for a description of the system
~Glenn
Old 12-20-2005, 09:27 AM
bugmenot's Avatar
2000 Toyota Tundra,
2003 Toyota Tundra,
2005 Toyota Tundra,
2004 Toyota Camry
Default wow
Thanks guys - i have an 01 Sienna and assumed it was the same thing. I'd assume this system would be the same in Canada. I wonder what the lifespan on the lithium battery is and what it's going to cost us to replace these??
"if the lithium battery is depleted, replace the entire tire pressure sensor assembly"
Reprogram tire pressure sensors after tire swap?? rjlem 4Runner 7 07-15-2009 01:12 AM
05 DC Tire Pressure Sensors Fubar Turtle1 Tires and Wheels 33 07-18-2005 10:33 AM
Grinding while switching from 2wd to 4wd harkeyjt Engine & Drivetrain 11 08-06-2004 06:05 PM
Tire pressure Laubypt Tires and Wheels 3 07-27-2004 11:33 PM
Tire pressure question? tmr812 Tires and Wheels 16 04-10-2002 08:42 PM
