Old 12-19-2005, 07:01 PM
CRF CRF is offline
Last Online: 10-13-2009 07:17 PM
CRF is on a distinguished road.
CRF's Photo Albums
Default 60k service..timing belt or not?
Well I have a 2000 Tundra and I have not needed to do anything on the truck except the usual(tires and brakes). I have about 75k miles on it and I was wondering if I should change out the timing belt or not. It just runs so good as it is that it seems happy without me messing with it. Just curious if you think these belts should be changed out?
Old 12-19-2005, 07:14 PM
redman733's Avatar
Dealer : Colonial Toyota
Last Online: 11-19-2009 11:44 AM
Images: 7
redman733 is on a distinguished road.
redman733's Photo Albums
i'm pretty sure the timimg belts are good for 90,000 on the V8's so you could put it off another year then worry about changing it and possibly the waterpump too(they always try to make you do them both while they are doing it)..not a bad idea as long as they don't rape you for the labor?
2006 Tundra DC 4x4 V-8,Bridgestone Revo's,Westin Platinum Series Black Nerf Bars,Wade Vent Visors,Husky Floor Liners, Wheeler Coils..
Old 12-19-2005, 08:59 PM
cupidstoy's Avatar
Dealer : Reliable Toytota
2004 Toyota Tundra,
2003 Toyota Corolla Lola
Last Online: 12-31-2008 07:02 PM
cupidstoy is on a distinguished road.
cupidstoy's Photo Albums
belt replacement is set for 90,000. i wouldn't do it early as it is significant expense and i would definitely do the waterpump and thermostat at the same time. i also wouldn't put it off much past the 90,000 mark as you'll be buying a new engine if it breaks. others report it can last longer and doesn't look worn out when replaced, but is that a risk you really want to take?
there are lots of good posts out there in TS land regarding the belt change. after you read, you can decide if you want to tackle it yourself or not. if the dealer does it, expect to drop close to a grand for the convenience and all the parts.
fyi, the truck probably won't run bad before it needs a belt change. it will either break and you're screwed as the valves bash into the pistons at 2500 rpms, or it might skip a tooth and mess up the timing, but that's unlikely. i wish there was a magic window into the belt compartment so a person could see what's going on in there. unfortunately, the crystal ball is cloudy and the 8ball says, change it at 90,000 or.... you might be sorry.... (evil organ music plays)
Old 12-20-2005, 12:23 AM
CRF CRF is offline
CRF's Photo Albums
Thanks guys for the response. I didn't know that it was 90k. I thought it was like most cars which are set at 60k.
Old 12-20-2005, 11:55 AM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
2007 Toyota Camry HV
Last Online: 10-28-2009 02:33 PM
Jer is on a distinguished road.
Jer's Photo Albums
Is the 4.7L an interference motor? If so, you can bet I'll change mine at 60k ...actually, I'm on a 3 year lease so I won't need to but trust me when I say it's cheap insurance if it's an interference motor to change all belts, pulleys, tensioners and everything else at 60k. The water pump should be good until 120k so no need to do it at the 60k mark.
A right, not a privilege - ΜΟΛΩΝ ΛΑΒΕ
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
Old 12-20-2005, 12:23 PM
CRF CRF is offline
CRF's Photo Albums
I did not think it was an interference motor but I would like to know if someone could confirm that.
Old 12-20-2005, 02:08 PM
cubic22's Avatar
Dealer : Durant Toyota
2002 Toyota Tundra
Last Online: 07-15-2009 03:02 PM
cubic22 is on a distinguished road.
Send a message via Yahoo to cubic22 cubic22's Photo Albums
Yea the Tundra engines are interference motors.
Check out this quick search I did. ( oops sorry about the search.
just search with the words in quotes "tundra, interference, engine"
JOHN
Old 12-20-2005, 05:38 PM
CATiger's Avatar
Dealer : Dublin Toyota Scion
Last Online: 11-04-2009 04:05 PM
CATiger is on a distinguished road.
Send a message via AIM to CATiger CATiger's Photo Albums
Default over 100k
I am not a gambler, nor ignorant of maintenance concerns. I simply chose not to do the timing belt replacement until over 100k miles.
When I did it, I replaced the timing belt, water pump and thermostat. I honestly don't remember if I had them do the pulleys or tensioners. I was also due for flush of the brake lines and power steering system.
Just my $.02
- JD
2000 Toyota Tundra Limited 4x4 w/ TRD Package
Thunder Grey Metallic
Factory Options: Leather Captain's Chairs, Color Keyed Running Boards, tow package Aftermarket Additions: JVC KDSHX900 w/ HD, Sirius S50 Satellite Radio, JL Audio Stealthbox, Eclipse 500W 5-channel Amp, MB Quart Ref Components w/ 1.5" tweeters up front, Coax rears, Peel & Seal sound deadening, Trenz Billet Grill, Tailgate Extender, Sylvania Silverstar headlights, Hella SuperTone Twin Horns, Ivan Stewart Body kit Modifications: Unichip with custom tune, JBA Titanium coated headers, Hellwig Anti-Sway Bar, TRD Dual Side Exit Exhaust, Powertraxx No-Slip, TRD IS Wheels Polished and Powdercoated Gunmetal Grey, shod w/ 285/75R16 Michelin LTX A/T2, Fabtech Performance Coil-overs & Donahoe Racing leaf springs with bilstein 5100, Rear Porterfield Carbon Kevlar Shoes with cryo-treated drums, Power Outlet Mod, Rear Seat Mod, NGK iridium plugs
MySpace
Old 12-20-2005, 05:42 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Just my $.02
If you're doing timing belt changes on an interference motor every 100k miles they you ARE gambling with your motor. Period.
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Doesn't seem to be working for me.
--try again
Old 12-20-2005, 08:27 PM
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
Last Online: Yesterday 07:48 PM
tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light.
tempetom's Photo Albums
I really don't think 100k miles is that much of a gamble, but it really isn't necessary to try to stretch it to that. I'd think if Toyota says 90k miles, they've put in a safety factor of at least 50%. That's just my opinion, and I guess I'm a bit of a gambler. By the time my Tundra reaches 90k miles, I'll have reached 90 years lol.
Propak's Avatar
Dealer : Checkered Flag Toyota
2002 Toyota Tundra
Last Online: 10-09-2007 09:02 PM
Propak is on a distinguished road.
Propak's Photo Albums
Default Changed mine at 190K
See my previous posts but the belt was in great shape when it was removed. I just went over 300k TODAY and havent done my second replacement yet. Original water pump too BTW. Heck, it's a Toyota!
Old 12-20-2005, 08:33 PM
ToyzOnly's Avatar
Dealer : Folsom Lake Toyota Scion
1998 Toyota Avalon XLS
Last Online: 09-01-2008 01:04 AM
ToyzOnly is on a distinguished road.
ToyzOnly's Photo Albums
Maybe it's a browser thing????
--try again
Old 12-20-2005, 08:55 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 02:18 PM
nhparrot's Photo Albums
Originally Posted by lildamit
That link don't work for me either.....
The serch won't work because the search results have flushed from the system buffer.
~Glenn
Old 12-20-2005, 09:09 PM
ToyzOnly's Avatar
10-4 on the "buffer"...
timing belt and water pump taylor's 2001 Tundra Engine & Drivetrain 24 07-22-2008 11:54 PM
timing belt service chrislloyd Engine & Drivetrain 10 08-20-2005 02:17 PM
Avalon Timing Belt Replacement & Other Service Intervals TLoewenberg Avalon 5 03-06-2005 08:25 AM
HOW TO: Timing Belt Service & Repair nhparrot Knowledgebase Archive 0 11-25-2002 09:11 PM
When to replace timing belt on 4.7? nhparrot Engine & Drivetrain 0 03-28-2002 04:48 PM
