  #16 (permalink)
Old 03-26-2008, 02:27 PM
Dealer : Toyota of Newburgh
Last Online: 02-23-2009 06:37 PM
dennis12550 is on a distinguished road.
dennis12550's Photo Albums
Default Re: Tundra Towing Capacity
Im looking to tow a Trailmanor 3124KS. with a tongue weight of approx. 500#'s. I contacted Gary at Deavers and he suggested I install the 3 leaf overload replacement. I was told the stock setup is not suitable for such a tongue weight. Has anyone installed a pair of these ? Im being told your towing will improve dramatically, along with safty, with a minimal loss in ride comfort empty. 1998-2006 TUNDRA/TACOMA 2WD/4WD 1.5" Lift, 3 leaf overload replacementF85$211.11
  #17 (permalink)
Old 03-26-2008, 04:41 PM
Dealer : Doxon Toyota
2002 Toyota Tundra mica green trd
Last Online: Yesterday 11:28 PM
sr5mike will become famous soon enough.
sr5mike's Photo Albums
Why not a weight distribution hitch?
At least they have circled the problem.
  #18 (permalink)
Old 03-26-2008, 06:20 PM
Anarcy21's Avatar
Dealer : Yuba City Toyota
2002 Toyota Tundra SR5
Last Online: 11-18-2009 12:06 PM
Anarcy21 is on a distinguished road.
Send a message via MSN to Anarcy21 Anarcy21's Photo Albums My eBay
Any idea what the v6 3.4l tundra will tow? I am going to be moving, and renting a uhaul trailer, and hoping to be able to pull it from MO to CA in June.. dont' know if it is a good idea.
2002 Toyota Tundra SR5 Model l Flowmaster 40 Series Exhaust With 3.5" Tips Out The Sides l 16" Ultra Wheels l Toyo A/T Tires l 12" Audiobahn 122T l Audiobahn A2601Q Amp l Eclipse 3434 Headunit l Sylvania Silverstar Headlights l K&N FIPK Gen II Intake (Installed again!) l BedRug Bed Liner l Debadged 7/22/2005 l
  #19 (permalink)
Old 03-27-2008, 11:58 AM
Last Online: 04-02-2009 01:48 AM
TUNDRA786 is on a distinguished road.
TUNDRA786's Photo Albums
Check your owners manual and check your Payload capacity.
Payload capacity-all the additional weight in your truck= acceptable hitch weight.
just make sure that the weight of the trailer is not more then the truck is rated for by Toyota and i wouldnt worry about a thing.
Those U haul trailers arent that heavy. Call U Haul and ask them the trailer weight and estimate how much weight you will put in it. Post the number up and im sure the Towing Guru's on this fourm will be able to help out.
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
  #20 (permalink)
Old 11-07-2009, 07:33 PM
Dealer : Parker Toyota Scion
Last Online: 11-19-2009 02:07 PM
Images: 1
binduni is on a distinguished road.
binduni's Photo Albums
I have a 1700# flatbed car trailer that I've hauled a '36 and '46 Chevy 1 1/2 ton trucks on. By my calcs, 1700 (trailer)+ 4365 (truck) = 6335. I definitely would not have wanted to haul it further than the 10 miles I needed to! I do have electric brakes on both axles of the trailer. The Tundra didn't bottom out on the rear suspension, but it felt very light on the front wheels. Towed fine at 45, but I didn't want to go more than that. No hills either.
  #21 (permalink)
Old 11-07-2009, 10:26 PM
That is a bad idea. that problem is 90% of the tundra braking ower comes from the front. By overloading the rears you are removing weight from the front. I tow thousands of miles a year and the only way to do it is safely.
  #22 (permalink)
Old 11-08-2009, 12:40 AM
Dealer : DCH Freehold Toyota Scion
1996 Toyota T100
Last Online: Today 12:47 AM
CJM_T100 is on a distinguished road.
CJM_T100's Photo Albums
If you relocate the brake proportioning bracket it will fix the brake bias issue from a lift.
  #23 (permalink)
Old 11-08-2009, 05:00 PM
dogger's Avatar
2000 Toyota Tundra,
2001 Toyota Sequoia
Last Online: 11-08-2009 05:02 PM
Images: 6
dogger is on a distinguished road.
dogger's Photo Albums
I tow a Wells Cargo Cycle Wagon that is 15' long and weighs between 3500 and 4000 lbs
with all my gear. My Tundra can comfortably tow this as long as the road is flat and
there isn't a big headwind. As you can see my trailer is below the rated weight Toyota
publishes but I have had to make many modifications to make the pulls safe.
My trailer has a tongue weight of 350 lbs so I use a weight distrubution hitch to lessen
the nose up tendency. I have also installed higher load rated tires, Bilstein "Red" shocks,
sway bar, bigger brakes, supercharger, headers, dual exhaust, deep sump tranny pan and
an electric fan for the transmission cooler. This combination gets down the road fairly
efficiently and safely out of overdrive, but I wouldn't push the rear end or tranny any
further, both are weak links.
The 1st gen Tundras are just not ideally suited for towing anywhere near the limit, I
agree 100% with RockyMtnRay in that you are driving a V8 powered Tacoma, so plan
accordingly.
dogger
  #24 (permalink)
Old 11-08-2009, 07:38 PM
Last Online: 11-18-2009 07:44 PM
munkydotorg is on a distinguished road.
munkydotorg's Photo Albums
I have an 06 DC 2wd, and I occassionally haul a boat/trailer that weighs approx 3200 lbs with no problems. The biggest haul I have done was a uhaul car trailer w/ a 99 audi a4 quattro on it. According the specs on the trailer and car, the whole thing weighed between 5500 and 5600 lbs. I hauled it several hundred miles from VA beach to Staunton, VA, then back home to Charlotte, NC. You could notice the weight back there, but she handled the extra weight fine, even through the mountains. I don't think I'd want to run it with an extra 1,000lbs tho, especially through the mountains.
  #25 (permalink)
Old 11-09-2009, 01:45 AM
Last Online: 11-09-2009 02:14 AM
SquatinS13 is on a distinguished road.
SquatinS13's Photo Albums My eBay
This is my first post. Hello all.
Anyways, I just sold my 05 Titan 4x4 crew cab and bought a 05 Tundra Double Cab 2wd TRD... I have towed the earth and the stars with the Titan. Looking at 8000lbs from Vegas to Tampa Florida, and now Im sitting in a truck with 3000 lbs less capacity lol...
I have my 2 car trailer, and a nissan 240sx with about 20 sets of tires... The titan pulled it like a red wagon... Tundra.... Not so well... Climbing hills makes me think this trucks gonna blow up. Ive never seen 7000 rpms on anything but my racecars lol until I towed this trailer to california.
This truck besides towing and SPACE INSIDE is 50000X's better than the titan. believe me, i get about 6MPG more than the titan in all areas.
  #26 (permalink)
Old 11-10-2009, 10:06 PM
trfytoy's Avatar
Dealer : Toyota of Santa Maria
2003 Toyota Tundra RACE TRUCK,
2006 Toyota Corolla S
Last Online: 11-16-2009 06:22 PM
trfytoy is on a distinguished road.
trfytoy's Photo Albums
Towing a 6,300lb CNC lathe on a 3,000lb trailer didn't work out too well for me..
Go to JSIMotorSports.com for billet window hinges.
NOW IN STOCK AND READY TO SHIP
  #27 (permalink)
Old 11-10-2009, 10:17 PM
whitesc3's Avatar
Dealer : Boulder Toyota
1995 Lexus SC300
Last Online: Today 01:57 AM
whitesc3 is on a distinguished road.
whitesc3's Photo Albums
Damn, what happened? Also what kind of wheels are those?
2005 DC X-SP, favorite new DD
1993 Lexus Sc300, built 2jz-gte,th400,N20 built to go fast but alwalys broken
  #28 (permalink)
Old 11-11-2009, 11:39 AM
trfytoy's Avatar
Trailer fish-tailed and pulled the truck right off the road.
Those are RobbyGordon wheels.
  #29 (permalink)
Old 11-11-2009, 11:46 AM
duffyatkinson's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra,
2003 Toyota 4Runner V6 Limited 4WD
Images: 17
duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence. duffyatkinson has blessed us with their presence.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Jeez Josh! What kind of damage did the truck sustain?
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
  #30 (permalink)
Old 11-12-2009, 11:06 AM
trfytoy's Avatar
New bed, that was about it. Biggest pain is my truck is a Limited and finding a used bed was nearly impossible at the time. Insurance bought a new one from toyota, 12k in damage lol.
Was quite the ride I must say. ha ha
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/54437-tundra-towing-capacity/
Posted By For Type Date
Titanium RV Owners Forum - 2008 Toyota Tundra as tow vehicle This thread Refback 11-10-2009 11:01 PM
Nissan Titan Camper, Nissan Titan Accessories, Nissan Titan Crew Cab - Frontierspices This thread Refback 03-08-2009 12:11 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Towing Capacity? thompme Towing 18 11-19-2008 04:47 PM
Towing Capacity shorberg Towing 7 10-11-2007 05:41 PM
Tundra Towing what would you add? h7009 Towing 9 12-13-2004 10:49 PM
Towing Package 2003 Tundra Access Cab misterdf Towing 9 07-20-2004 02:26 PM
Question about stock Tundra Foglights..Help! nhparrot Electrical & Computer Systems 0 03-28-2002 01:13 PM
