Old 01-03-2006, 11:28 PM
2005 Toyota Tundra
Last Online: 11-11-2009 10:50 PM
jploski is on a distinguished road.
jploski's Photo Albums
Default Check engine light when starting - 2005 DC
First, I have a 2005 Tundra Doublecab 2wd with about 4500 miles. This morning when I started the truck the "Maintenance Required" light was flashing and then turned off when I pressed on the gas pedal. Throughout the day I made several trips and each time I started the engine the check engine light would come on and then turn off after 10-20 seconds. Any ideas what would cause this??
Old 01-04-2006, 08:55 AM
okcowboy's Avatar
Dealer : Jim Norton Toyota
2005 Toyota Tundra
Last Online: 09-19-2009 10:15 AM
okcowboy is on a distinguished road.
okcowboy's Photo Albums
Default Re: Check engine light when starting - 2005 DC
it is warning you that you have 500 miles until you need an oil change, in another 500 miles it will stay on until you have it reset (when you get the oil changed)
do a search, i believe you can reset it yourself if you don't want it to flash at every startup until then
Old 01-04-2006, 10:20 AM
2005 Toyota Tundra
Wow! Thanks for that piece of information. I was about ready to take it to the dealership to have them diagnose the problem. I will do a search to find out how to reset this warning. Thanks again!!
Old 01-04-2006, 11:16 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:02 AM
nhparrot's Photo Albums
Reset information for the "Maintenance Required" light is in your owner's manual.
~Glenn
Old 01-04-2006, 11:28 AM
Dealer : Pueblo Toyota
Last Online: 05-25-2009 05:09 PM
Colorado4wheeler is on a distinguished road.
Colorado4wheeler's Photo Albums
Did you change the oil? Use a Toyota Filter and change the oil. Reset the light, and save all reciepts for warranty reasons. Check your Maintence book as well and inspect all the parts they say to inspect. If you have issues with any of those parts they could deny warranty due to them not being inspected by mechanic.
Resetting Check Engine Light garys2 Engine & Drivetrain 7 10-31-2006 05:43 PM
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 08:33 PM
Check engine light flashes about 5 Times... Amerikes 1Gen-Tundra 2 09-07-2005 08:48 PM
Check engine light; engine misses (newbie) skipster46 Engine & Drivetrain 2 02-08-2004 08:26 PM
