Installing OEM autodimming, compass, temperature rear view mirror
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Installing OEM autodimming, compass, temperature rear view mirror
  1. #1
    Supporter Himself's Avatar
    Join Date
    Feb 2005
    Location
    Rochester, MN
    Posts
    155
    Liked
    0 times
    Rep Power
    11
    Default Installing OEM autodimming, compass, temperature rear view mirror
    Want to install the above in my 05 tundra. Does anyone know how this installation will be or if anyone who has the above as OEM, take some pictures to show how the wires are run, if they are visible? Thanks
    2005 Tundra Access Cab 4.7L V8 4x4
    Phantom Gray Pearl with Light Charcoal Interior
    Bedliner, Railcaps, Towing package, JBL CD/FM with 6 Speakers, Captain's Chairs, Central Console, Privacy Glass,TRD Offroad Package, Foglamps, Colour Toned Overfenders
    Truxedo Lo-Pro Tonneau Cover
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member tripleb's Avatar
    Join Date
    Jun 2005
    Location
    Valparaiso, FL
    Age
    63
    Posts
    146
    Liked
    0 times
    Rep Power
    11
    Default Re: Installing OEM autodimming, compass, temperature rear view mirror
    Hey Himself,
    The wires do not show other than a very short piece from the headliner to the mirror.
    My wife bought me one for Christmas and also pre-paid for the installation by the Dealer. However, it would not be to hard to install yourself ..... I found a complete installation description on the Internet ..... don't know where I put it.
    Do a Google search for the installation instructions.
    Good luck,
    2005 Tundra A/C Stepside 4x2
    Natural White/Light Charcoal Cloth
    TRD Sport Package
    Towing Package
    Cloth Captains Chairs
    JBL 6 Disk/6 Speaker CD
    All Weather Guard Package
    Carpet Mats
    Toyoguard Plus Protection Group
  4. #3
    Join Date
    Sep 2002
    Location
    Cibolo, TX
    Age
    46
    Posts
    34
    Liked
    0 times
    Rep Power
    13
    I installed the auto dimming mirror in my 05 AC. Very easy install. You will have to pull a couple of the plastic molding off to run the wires and tap into a positive lead so the mirror will know to activate when the iginition turns on. The instructions tell you to tap into a wire, I went and bought a fuse extender to plug into the correct wire without splicing anything. You will also have to run the actual temp sensor to the outside of the truck, but again, not very difficult.
    With a couple of basic tools, it is an easy job.
    I don't know how I lived without the mirror, I love the auto dim feature....although it takes a little getting used to at first.
    Worth the effort.
    Good luck.
  5. #4
    Join Date
    Nov 2005
    Location
    high desert
    Posts
    52
    Liked
    0 times
    Rep Power
    10
    How much was it.
  6. #5
    Join Date
    Feb 2005
    Location
    Rochester, MN
    Posts
    155
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    So there is no wire showing? Do you have the detailed instructions or how it looks like after install? ie. I mean the wires etc?
    Thanks
  7. #6
    Join Date
    Jun 2005
    Location
    Valparaiso, FL
    Age
    63
    Posts
    146
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by Himself
    Like I said, "The wires do not show other than a very short piece from the headliner to the mirror." The short piece of exposed wire is covered with a plastic piece that came with the mirror kit.
    I will try to find the instructions by doing a Google search. If I can find them, I will post the link.
    Ok, found the link ..... it is for a Highlander but the Tundra installation would be the same:
    http://www.toyotaparts4u.com/pdf_fil...e%20Mirror.pdf
    TRD Sport Package
    Towing Package
    Carpet Mats
  8. #7
    Join Date
    Feb 2005
    Location
    Rochester, MN
    Posts
    155
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Thank you so much. The link is really informative. At least I can see how much work is required. I will prob ask the dealer to install it for me for I can see that this installation is gonna be a little challenging for me. How much did installation cost typically'? Thanks
  9. #8
    Junior Member T100_2_TUNDRA's Avatar
    Join Date
    Jan 2006
    Location
    Portsmouth, VA
    Posts
    170
    Liked
    2 times
    Rep Power
    10
    I just installed an aftermarket mirror and have documented the installation on my 05 access cab. FYI, the only connection in the map light fixture is for battery and door switch. You can pull the battery line by tapping in, but you need an ignition source or the mirror will always be on. Also, there will be no temp. sensor so if the mirror comes with that then you will have to wire that in as well.
    Here is a link to my installation: http://www.tundrasolutions.com/forum...-compass-temp/
  10. #9
    Join Date
    Sep 2002
    Location
    Cibolo, TX
    Age
    46
    Posts
    34
    Liked
    0 times
    Rep Power
    13
    Install it yourself and save the money. I purchased mine off ebay for around $75. Compared to dealer pricing, that is pretty cheap. It is worth the cost in my opinion.
  11. #10
    Join Date
    Jun 2005
    Location
    Valparaiso, FL
    Age
    63
    Posts
    146
    Liked
    0 times
    Rep Power
    11
    Hey Himself,
    The installation calls for 2 hours ..... at my dealer that is about $160.00.
    TRD Sport Package
    Towing Package
    Carpet Mats
  12. #11
    Join Date
    Feb 2005
    Location
    Rochester, MN
    Posts
    155
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Tell me again how u removed the driver's side A-pillar?
    I tugged on mine but it would not budge? Do I have to remove the handle first? If so, how do I do it?
    Thanks
  13. #12
    Supporter LGL002's Avatar
    Join Date
    Jan 2003
    Location
    West Fargo, ND
    Age
    74
    Posts
    2,235
    Liked
    15 times
    Images
    17
    Rep Power
    1319
    Pop off the two plastic rectangular screw covers on the assist handle, remove the screws then tug on the pillar cover.
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  14. #13
    Join Date
    Feb 2005
    Location
    Rochester, MN
    Posts
    155
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Ok...so can someone recommend me exactly what I need to get? I understand that there are a few brands floating around like Gentech, Mito etc. and they come with different adaptors. I would like to get the OEM one as far as possible. And where would be a good place to purchase? Thanks
  15. #14
    Join Date
    Jun 2005
    Location
    Valparaiso, FL
    Age
    63
    Posts
    146
    Liked
    0 times
    Rep Power
    11
    Hey Himself,
    Ok, here is a link to the mirror that is sold as an aftermarket accessory by my Toyota dealer:
    http://www.mitocorp.com/html/nightvi...ingmirrors.htm
    And here is a link to Ebay where lots of these units are listed:
    http://search.ebay.com/search/search...tex&category0=
    Remeber, Google is your friend
    TRD Sport Package
    Towing Package
    Carpet Mats
  16. #15
    Junior Member duke boy's Avatar
    Join Date
    Aug 2005
    Location
    Augusta, ME
    Posts
    163
    Liked
    0 times
    Rep Power
    10
    Some of the Gentex models come with an "easy install" wiring harness and are significantly more money than others. What's the deal with it? Would it make the install significantly easier on a Tundra? I assumed that it wasn't very hard anyway. Also, is there a better (either closer to the unit or more accurate) location to install the temp sensor than behind the front bumper or is that the best spot?
    2005 Charcoal Tundra Access Cab 4WD, TRD Offroad, Ivan Stewart Wheels (see my tire pressure monitoring system override mod in my photos), Line-X, Magnaflow 14586 muffler, Hellwig anti-sway bar, Gentex mirror
    Audio: Eclipse CD5444 HU, Kicker Zx 550.3 powering 2 ID8V.3D4 8" Image Dynamics Subs in Q-Logic underseat enclosure and Infinity 652i Reference in rear doors, Carver M2120 amp powering Infinity Kappa 60.5CS in front doors
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Left Side Rear View Mirror
    By tedm in forum Interior & Exterior
    Last Post: 12-28-2004, 07:38 AM
  2. Replies: 3
    Last Post: 03-18-2003, 11:51 AM
  3. rear view mirror
    By sfgiants in forum Interior & Exterior
    Last Post: 07-11-2002, 09:00 PM
  4. Sun Visor Hitting Rear View Mirror
    By Cajunman in forum Interior & Exterior
    Last Post: 06-20-2002, 05:13 PM
  5. Lowering the inside rear view mirror?
    By nhparrot in forum Interior & Exterior
    Last Post: 03-28-2002, 11:49 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
