Old 02-08-2006, 12:01 PM
Dealer : Dunning Toyota Ann Arbor
2004 Toyota Tundra
Last Online: 05-14-2007 02:07 PM
Kreuz may have some regrets.
Kreuz's Photo Albums
Default 30K Maintenance questions
Hi all,
I'm coming up on 30K miles on my 2004 Tundra and I'd like some advice on what maintenance I should perform.
I've been keeping up on oil changes Etc. (Mobil1 and Pureone filter) up until now, but 30K seem to call for more than just the oil.
What fluids should I use (Synthetic?) for the differential, transfer case and transmission?
Any particular brand/type of spark plugs you prefer?
I have yet to adjust the brakes. I assume only the rear drums need adjustment. Can anyone offer some guidance?
Also, what does Toyota mean 'lube chassis'? I've lubed the drive shaft, but what else should I be oiling or greasing?
Are they any other items you'd recommend me doing to the truck besides the obvious airfilters, Etc.?
Thanks for the feedback!!
-Matt
Old 02-08-2006, 04:06 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
2001 Toyota Tundra AC V8
Last Online: 12-06-2009 12:03 PM
Tones may have some regrets.
Tones's Photo Albums
Default Re: 30K Maintenance questions
My list for 30k goes like this: drain and fill transmission, differential, coolant, and engine (if due). Change plugs, PCV, air filter and cabin air filter (if present). Either NGK or Nippondenso copper plugs are excellent.
Old 02-08-2006, 04:54 PM
TIE-YOTA's Avatar
Dealer : Ron Carter Toyota
2004 Toyota Tundra
Last Online: 12-05-2008 07:57 AM
TIE-YOTA may have some regrets.
TIE-YOTA's Photo Albums
Best thing to do is go to a Toyota dealership, ask for a maintenance schedule which is a brochure, which basically documents every 15K, 30K, 45K, 60K, etc. etc. on what needs to be done. That's what I did. Ask for it and tell them you will come in at a later point. If you cannot do it all, then have a trustworthy mechanic do it for you.
Would've help if I would've looked for a website first. Here it is:
http://www.toyotaownersonline.com/pa...an=GM_TN_PARTS
Previous Trucks Owned:
1990 Toyota Xtra-Cab 2wd (145,000 miles)
1996 Toyota Tacoma Ext. Cab 4wd (171,000 miles)
2004 Toyota Tundra DC 4wd (Phantom Grey - 48,700 miles and counting)
Toyota truck user for 16 years and counting..........
Also known as Thibodeaux at the Fuge.
Gig'em Ag's (Class of '94)
Modifications on DC to date:
3" Toytec lift, 1.5" Add-A-Leaf, Line X, Eagle Alloys Series 101 16x8 (3.60 B.S.), 285/75/R16's Cooper Discoverer ST's
Old 02-08-2006, 09:41 PM
drewbush's Avatar
Dealer : Manhattan Beach Toyota
2001 Toyota Tundra,
2000 Toyota Camry
Last Online: 01-27-2010 10:59 PM
drewbush may have some regrets.
drewbush's Photo Albums
2004 Tundra
30,000 Miles - 36 Months
Replace engine oil and oil filter
Rotate tires
Lubricate propeller shaft (4WD)
Replace limited-slip differential oil, if equipped (2WD)
Replace spark plugs
Re-torque propeller shaft bolt
Replace engine air filter
Replace cabin air filter (if equipped)
Inspect the following:
Automatic transmission fluid
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs
Drive shaft boots (4WD)
Engine coolant
Exhaust pipes and mountings
Front differential oil (4WD)
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Manual transmission oil
Radiator core and condenser
Rear differential oil
Steering gear box
Steering linkage and boots
Transfer case oil (4WD)
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Replace front differential oil (4WD)
Replace manual transmission oil
Replace rear differential oil, including limited-slip
Replace transfer case oil (4WD)
Tighten nuts and bolts on chassis
Driving in Desert or On Dirt Roads
Applicable Footnotes:
1) Reset the oil replacement reminder (“MAINT REQD”) light after replacing engine oil, if vehicle is equipped with this light.
2) Required under the terms of the Emission Control Warranty.
3) Inspect thickness measurement and disc runout.
--------straight from toyotas website
then click on the top where it says scheduled maint. you can select any toyota vehicle and year (within reason)
Old 02-09-2006, 10:07 AM
2004 Toyota Tundra
Thaks guys.
Does anyone have a recomendation for a maintenance manual/book for the Tundra? I checked on amazon and they didn't really have anything for the 2004.
-Matt
Old 02-09-2006, 01:24 PM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 03-09-2010 07:22 PM
Hey TIE-YOTA... that's a pretty resoruceful website.
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 02-09-2006, 02:26 PM
My03Tundra's Avatar
LOVES TO EDIT POSTS!!
- Other - 2007 Honda Ridgeline
Last Online: 12-08-2009 01:06 AM
My03Tundra may have some regrets.
Send a message via AIM to My03Tundra Send a message via Yahoo to My03Tundra My03Tundra's Photo Albums My eBay
At 30,000 miles I had the regularly scheduled maintenance and new brakes put on the front. :-(
Is something supposed to be here?
Old 02-09-2006, 10:06 PM
cupidstoy's Avatar
Dealer : Reliable Toytota
2004 Toyota Tundra,
2003 Toyota Corolla Lola
Last Online: 12-31-2008 06:02 PM
cupidstoy may have some regrets.
cupidstoy's Photo Albums
i guess you don't have the owner's manual/maintenance books? the manual gives you all the specs on what grease/fluids to use. the maintenance book gives you the maintenance schedule for each mileage interval.
if you don't have 'em, i'd recommend gettin' 'em.
download, dealer, photocopy a friend's, whatever. if you have warranty left, you'll need to be able to show you did the scheduled maintenance correctly and if you wan't your truck to last, you'll need to do it anyway, so either way, since you're asking, you seem motivated and should definitely get the instruction books so you'll know what to do, how to do it and when.
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
Wish list: too long, wife would kill me!
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
Old 03-27-2006, 02:29 PM
Dealer : Findlay Toyota Scion
2004 Toyota Tundra
Last Online: 12-13-2009 05:51 PM
bajafiend may have some regrets.
bajafiend's Photo Albums
"black rubber floor mats from Sams.)" ....
Thats just wrong....
Old 03-27-2006, 05:10 PM
cupidstoy's Avatar
2004 Toyota Tundra,
ha! i couldn't resist.... ended up getting a set for my brother in law for his jeep, too. i have the tundra mats safely stored away for... hmmmm... not sure what i'm storing them for? resale? not planning... someday when the truck is an antique? not likely... i guess i just hate it when the factory floor mats are ruined and it's hard to find a set. ;-)
Old 03-27-2006, 08:31 PM
Dealer : Al Hendrickson Toyota
Last Online: 06-27-2009 03:35 PM
mayfer may have some regrets.
mayfer's Photo Albums
Can anyone throw out a rough ballpark price estimate for the full 30K maintenance from a Toyota dealer?
Thanks
Old 03-27-2006, 10:06 PM
cupidstoy's Avatar
2004 Toyota Tundra,
200 bux or so for the 30,000 mile maintenance. you can do it yourself for a lot less.
my local dealer has a sign posting the 60,000 mile service to cost 520 dollars. when pressed, he said that includes a timing belt change that isn't actually due until 90,000. i did find their price of 200 for the timing belt change to be quite reasonable. i kind of doubt that is the price for the 4.7 v8 considering all the labor involved. if it is, i'll definitely be having them do it ;-)
Old 03-28-2006, 08:49 PM
Dealer : Folsom Lake Toyota Scion
Last Online: 03-05-2010 06:34 PM
vic60 may have some regrets.
vic60's Photo Albums
Thanks
Hi
I just paid $480.00 for 30k maint it included changing all fluids, plugs, air filter,
basically that was it plan on front brakes as well.
Old 03-28-2006, 09:33 PM
randyeverett's Avatar
Dealer : Coad Toyota
2005 Toyota Tundra,
2008 Toyota Rav4 Limited, V-6
Last Online: 03-02-2010 12:11 AM
randyeverett may have some regrets.
randyeverett's Photo Albums
Originally Posted by vic60
Hi
Ouch! Was that on an '06? Also, did they change the trans fluid?
RE
I really don't care if I hurt your metro-sexual sensibilities.
Bone-stock 05 Access Cab Tundra, V-8, 4x4, TRD Off-Road w/LSD, Spectra Blue Mica
05 Camry LE, 4cyl
30K Maintenance cost skappen 1Gen-Sequoia 32 02-19-2007 12:30 PM
V-6 30k maintenance phantom1 Engine & Drivetrain 1 09-28-2004 11:08 PM
Sequoia: Service Intervals (10k, 20k, 30k etc..). Questions, Issues and Discussion sushah 1Gen-Sequoia 89 06-21-2004 02:13 PM
Questions on 30K Service dgg2002 Engine & Drivetrain 3 01-01-2004 12:07 AM
30k service questions StellarTundra Engine & Drivetrain 3 08-06-2002 09:53 AM
