Old 02-12-2006, 08:37 AM
sevenpedaler's Avatar
Schumacher! Need I say more?
Dealer : Carlson Toyota
2008 Toyota Tundra DC Turd Slate
Last Online: 06-19-2009 10:47 AM
sevenpedaler is on a distinguished road.
sevenpedaler's Photo Albums
Default Can't grease prop shaft on 4X4
Does anyone else have issues getting their grease gun in the u-joints of the prop shaft for the 4wd? I've tried spinning the shaft in every way possible and still no luck. The diameter of the gun's tip is a bit too large to fit between the knuckes of the u-joint. I have two grease guns and both have the same diameter tips. Luckily, I rarely use 4wd so it isn't a huge issue, but I would like to get some fresh grease in there due to the salt and other **** we have up in MN. Is there a narrow tip you can put on a grease gun? I've pumped litterally hundreds of gallons of grease in my day (farm boy) and never have had this much of an issue before.
Old 02-12-2006, 08:46 AM
Gort11's Avatar
Dealer : Lithia Toyota Grand Forks
2009 Toyota Camry SE V6 Barcelona Red
Last Online: 01-02-2009 03:47 PM
Gort11 is on a distinguished road.
Gort11's Photo Albums
Default Re: Can't grease prop shaft on 4X4
Taper the end of the grease fitting on a grinder until it fits, I got this advice from my Toyota Tech.
Bob
2009 Camry SE V6, Barcelona Red,Sport Conv,Sport Leather Package,Moonroof Package,Rear lip Spoiler,JBL
"You Can't Fix Stupid"
Old 02-12-2006, 12:28 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
A pencil tip applicator tip on your GG will do the trick
