check engine light
I need some help. I have a 2000 tundra, v8. I had the upstream o2 sensors and manifolds changed under the recall in Sept. of '04. I went two weeks ago to have the truck inspected. It failed the test. The code that came up was 0171 Bank 1 (system too lean). I took it to the local toyota service dept. and they ran a test on it. The same code came up. I have now had the mass air flow sensor, the same upstream o2 sensors and the left manifold replaced (the left sensor was seized in the manifold, that is why it was replaced). I go to pick up my truck drive 5 miles, go in and eat dinner, come back and crank up the truck and the check engine light came on again. Can any one tell me what the problem is? I am now out $955.00 and I still can't get the blasted truck inspected.
