Old 03-17-2006, 11:43 AM
mogley's Avatar
Dealer : West Ashley Toyota
2009 Toyota Tundra
Last Online: 10-15-2009 10:06 AM
mogley may have some regrets.
mogley's Photo Albums
Post cragar wheels?
Has anyone put cragar wheels on a double cab. I am looking at the cragar classic wheel series 397(it is a black wheel, I think it will look good on my phanton grey 05 sr5 4x2 DC) What backspacing should I use? WHY?
MOGLEY
Old 03-18-2006, 12:12 AM
CT-Tundra's Avatar
Dealer : Toyota of Colchester
2005 Toyota Tundra
Last Online: 12-09-2008 08:26 AM
CT-Tundra may have some regrets.
CT-Tundra's Photo Albums
Default Re: cragar wheels?
Wheels- as with everything, you get what you pay for. Cheap steel wheels are cheap for a reason. Alloy wheels are going to weigh less, ride smoother, they're stronger, and they don't rust (cheap truck wheels rust in a few years which causes slow air leaks).
Backspacing- the distance of the centerline of the wheel (and consequently your tire) to the mounting surface of the hub. More = wider stance. Too much = weird looking and past fender flares. Look up the factory specs for your wheels then compare with what you're shopping for.
16" wheels on a Tundra are close to the brake calipers. Factory 16" wheels seem to fit with good clearance, but I've seen 16" aftermarket wheels on a Tundra that have about 1/4" clearance.
2005 Tundra Access Cab 4x4 4.7L - BFG ATs on MT Classic Locks - Warn M8000
Wheel Selection FAQ OKCTundra Tires and Wheels 1 12-14-2007 08:26 PM
News|Stories|Photos|Videos Possum Off-Topic 513 01-17-2007 05:36 PM
Stock wheels peeling Oafboy182 Tires and Wheels 1 12-15-2005 07:39 AM
HELP Bad luck with new wheels AdamRmr Tires and Wheels 5 12-14-2005 09:37 AM
Tacoma: Question... About OEM Wheels for the Taco TundrastruckDave Tires and Wheels 17 10-15-2004 07:08 AM
