ok on teh 06 dc tundra the foglight wires going into the bulb itself which wire is positive and which is the negative for the dirver and passenger side....
I don't know but go to pep boys or such and buy a 12volt test light for $5 bucks and test it. Ground the clip on the test light and touch the pointed end to each wire, one of them will light up the test light. (make sure the lights are turned on first)
Tom 03 AC SR5 Silver Sky Metallic
Cab height ARE cap, Westin chrome step bars, tinted front windows 35%, Hella mini foglights under front bumper ,fog lights under the frame to light up the door area, fog lights under rear bumper (factory dash switches for each set of lights),Bedrug, Hellwig swaybar, one-touch window control for both windows,Kenwood DDX-6019 double din dvd unit,2 amps, 2 sets of speakers, 6 disc cd changer,Q-logic sub box, subs, rearview camera, & skid plate. Freebies: Power outlet mod,fog light mod, map light mod &, debadged. Hope to add: Chrome bull bar, headest monitors for back seat passengers (daughters) Waiting for time to install: kicking alarm w/remote start. My Website
well mine did not come with foglights so i dont have any power going to the bulb. I bought the factory lights and i am running my own wires to them and i need to know which side of the bulb is the + and which is the - so i can hook them up
The PINK wire is (+)Positive
The WHITE/BLACK wire is GROUND
25 yrs with TOYOTA
Okay, I am about 95% sure that it does not matter. It is DC and the filament is just a resistor. Should work either way if there are only two contacts. Take some extra wire and take the bulb up by the battery and hook it up. Should work either way.
Okay, I am about 95% sure that it does not matter. It is DC and the filament is just a resistor. Should work either way if there are only to contacts. Take some extra wire and take the bulb up by the battery and hook it up. Should work either way.
The only thing that could happen if you hook them up backwards is it will suck the light into the bulbs instead of shine out.
I hate it when that happens!
Actaully it turns your TUNDRA into a "TITAN"
25 yrs with TOYOTA
