Old 03-30-2006, 10:09 PM
Dealer : Checkered Flag Toyota
Last Online: 02-19-2007 09:35 PM
bullstundra is on a distinguished road.
bullstundra's Photo Albums
Default problems after timing belt replacement
I have had a rough idle problem after having my timing belt changed. Ive replaced my spark plugs,fuel injectors cleaned, mass air flow sensor repalced,new o2 sensors,and ecu has been reprogrammed by toyota and i still have a rough idle. Its Idles worse once its been running for awhile. Also ive noticed that when i go to pass someone (3500 rpm and higher) the engine has a much higher pitch than it did before the timing belt change. A Toyota mechanic has checked to make sure that the timing belt was properly installed. He said that everything looked ok. Ive asked them to check the valves to see if they need to be adjusted but they seem to think thats a waste of time. Does anyone have any suggestions. Thanks
Old 03-31-2006, 05:26 AM
sevenpedaler's Avatar
Schumacher! Need I say more?
Dealer : Carlson Toyota
2008 Toyota Tundra DC Turd Slate
Last Online: 11-13-2009 05:42 PM
sevenpedaler is on a distinguished road.
sevenpedaler's Photo Albums
Default Re: problems after timing belt replacement
It sounds like it could be something as simple as a vacuum leak. That "higher pitch" makes me think that.
Old 03-31-2006, 05:43 AM
42GAMI's Avatar
Dealer : Servco Auto Center
2004 Toyota Tundra Stepside
Last Online: 11-15-2009 09:49 AM
42GAMI is on a distinguished road.
42GAMI's Photo Albums My eBay
time to bust out that water spray bottle and look for vac leaks.
MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
... Find any spelling errors? Take it up with admin.
...... btw If I offend anyone, get over it. I know I will.
......... Panties are optional.
~ been there, done that, got the panties ~
Old 03-31-2006, 06:31 AM
MEvang's Avatar
Dealer : Toyota of Cincinnati Co.
Last Online: 08-26-2009 09:37 PM
MEvang will become famous soon enough. MEvang will become famous soon enough.
MEvang's Photo Albums
If it was find before they change the belt, they have one of the cams off a tooth. This is the exact symptom of a cam off. Take it to an independent garage and have them check the cam timing.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
Old 04-02-2006, 09:41 PM
thanks for your suggestions. A Toyota mech. did check the timing belt to make sure that one of the cams was not off a tooth. He said it looked fine to him.Would you have to take the belt off to do that? I know he didnt take it off.
My truck definitely runs rougher at idle when its been running for awhile. Im wondering if this has something to do with my radiator that had to be repaired because of a small puncture. There are no leaks, but my temp gauge will sometimes rise up to about the half way mark. I cant remember but i think it used to only go up about a 1/4 of the way. could this cause a rough idle as well as a vacuum leak?
Old 04-02-2006, 09:49 PM
Dealer : Brunswick Toyota
Last Online: 11-12-2008 08:34 PM
capacar is on a distinguished road.
capacar's Photo Albums
hpoe they didnt bend a valve its a interferince motor if you dont do it correctly it could defintly bend a valve
Old 04-03-2006, 03:57 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
the timing belt is off a tooth on the crank pulley. also, both engines in the 00 tundra are "non-interference" engines. yspert
Graduated from Y to Z status.
Old 04-03-2006, 04:51 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
A leaking or bent exhaust valve will cause a piece of paper that is placed against the exhaust tip to be sucked in rhythmically every time the offending cylinder goes through its cycle at idle.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 04-03-2006, 05:54 PM
geojim's Avatar
Dealer : Emerson Toyota
Last Online: 05-19-2008 06:34 AM
geojim is on a distinguished road.
geojim's Photo Albums
Like others state, sounds like a cam timing issue. They can be pretty tricky to get right as the cams want to 'find' a slightly new position once the belt is removed. As far as checking it, I know they would not need to remove the belt, by will need to remove the covers. Kind of a pain, I would imagine. The fact that this is a new symtom since the belt change would lead me to believe this, or possibly they disturbed one of the vacuum hoses near the front.
Jim
2001 Tundra AC V8 4x4 TRD, Sunfire Red Pearl, Matching A.R.E. Z series cap.
Old 04-03-2006, 08:49 PM
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
Last Online: Today 11:58 AM
tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light.
tempetom's Photo Albums
I'd bet the belt's off a bit too. From my experience, vacuum leaks are usually felt at idle and pretty much go away at higher rpms. At least that's how my 76 Blazer acted.
From an earler post, weren't all the V-8 Tundras interference engines? I don't know though, but it seems logical that it's the same basic engine.
Old 04-04-2006, 09:00 PM
thanks for your advice. Will it be a difficult job to locate and fix the tooth thats not on the crank pulley? Should I let Toyota fix this or should I go back to the Master mechanic who replaced my belt. He has a good reputation but Im not sure how much he knows about Toyota's.
Timing Belt Replacement 2000 Tundra hughes_mich Engine & Drivetrain 24 06-10-2008 11:50 AM
timing belt replacement guide Tundrav8yamaha Engine & Drivetrain 26 04-18-2008 07:24 PM
Timing belt replacement Iron Horse Herb Engine & Drivetrain 102 03-28-2008 12:08 PM
Timing Belt replacement cost bearded1 Engine & Drivetrain 64 01-08-2006 10:05 PM
Avalon Timing Belt Replacement & Other Service Intervals TLoewenberg Avalon 5 03-06-2005 08:25 AM
