How do I replace the Integration Relay? - Page 2
  1. Welcome to Toyota Tundra Forums : Tundra Solutions Forums Ė General discussion forum for Toyota Trucks
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: How do I replace the Integration Relay?
  1. #16
    Join Date
    Nov 2008
    Location
    Ashtabula,Oh
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Talking Re: How do I replace the Integration Relay?
    Ok,
    Since no one has officially said how to actually replace this, I'll give my input.
    I currently have a Solara that the lights turn back on after the dome light timer times out.
    The integration relay is a white plastic box on the back of the fuse block.
    It does not require removing the fuse block to get it off.
    It is a white plastic box approx 3" x 5" and approx 1.5" thick.
    To remove it turn yourself upside down under the dash, and look up behind the fuse block.
    You will see two connectors one which is large with approx 10 wires in it, and a small one with 4 or so.
    Push in the locking tab, and remove the two connectors.
    Now just slightly to the right you will see a locking tab that latches the integration relay box to the back of the fuse block.
    Pull up the tab to loose the bottom from the fuse block.
    Now either by pulling and/or prying with a large screw driver, the entire integration block pops out of the fuse block toward the front of the vehicle. Just like unplugging a big giant relay. Be careful not to apply too much upward or angled stress on the assembly. The direction is out away from the fuse block.
    Inside is a very complex circuit board. I seriously doubt unless you can find a full blown schematic you will be able to repair this. There are multiple relays, an embedded logic/timer micro, many surface mount diodes, and quite a few output transistors.
    I'm obviously going to have to find a replacement.
    Not sure if these are all basically the same, and I can get one from a bone yard, or if I have to buy a new one.
    I have to believe that this is not a cheep item.
    Hope this helps.
    Regards
    Delerious
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    577
    Default Re: How do I replace the Integration Relay?
    http://www.toyodiy.com/ should have info, ya just need to enter your specific trucks info and look it up! looking at the part might help with figuring out how to replace it? I would think a Relay would not be that hard to replace? I know my PCV on my 93 V6 was probably harder to replace than this relay!
    the part # mentioned earlier is in this link can be founf on 3rd pg of 8 and it's around 250.00 but not much of a picture? 82730-0C020
    http://www.trademotion.com/partlocat...OEM&siteid=840 add above PN and it's like 165.00?
  4. #18
    Join Date
    Aug 2008
    Location
    Florida
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by mnm View Post
    I nearly had to replace mine due to a leaking windshield allowing water to enter the J/B and integration relay. The dealer wanted ~$220.00 for the part and needed a day to get it. I removed it and took it apart and dried it out and re-installed it and it has been 2 months with no more problems. But anyway the dealer said it was all one assembly. Not sure if he was right. Good luck.
    Thanks MNM for the heads up. I had exactly the same problem. Had a small hole in the top corner of the drivers windshield. Pulled out the Integration relay and found water sitting in a few of the connectors. I let it dry out and I am back in business. Also coated them in Dialectic grease and sealed windshield hole. Thanks.
  5. #19
    Supporter UnSub's Avatar
    Join Date
    Mar 2007
    Location
    Mesquite, TX
    Age
    63
    Posts
    992
    Liked
    1 times
    Images
    6
    Rep Power
    37
    Attached is a picture another member took. If you do a search you might find info. Sorry but I don't remember who to give credit to.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
    Scion Head Unit 08600-21802,
    Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
    Rhino Liner, Die Hard Platinum P5 battery
    5.7 Killer
  6. #20
    Join Date
    Mar 2009
    Location
    cambridge ontario
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    i have no tail lights and every thing is good but the integration relay. i have the same hole in the wind shield problem. i will pull hte relay and dry it out thanks for the info
  7. #21
    Join Date
    Aug 2014
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Is the horn relay part of the integration relay on 2000 tundra?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 09-10-2010, 10:47 AM
  1. Door lock help needed.
    By tundraboy27909 in forum Interior & Exterior
    Last Post: 03-10-2012, 05:47 PM
  2. integration relay
    By jackthelab in forum Audio & Stereo
    Last Post: 11-16-2006, 02:09 PM
  3. To integrate...or not to integrate.
    By Mark440 in forum Electrical & Computer Systems
    Last Post: 06-05-2002, 09:12 PM
  4. INFO: How a Relay Works
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-23-2002, 06:39 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
