Old 04-30-2006, 11:28 AM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 08:08 AM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Default third brake light
Has anyone chage bulb in third brake light on d/c tundra?how hard is it to do?any suggestions?Thanks in advance.
Old 02-10-2008, 09:33 PM
2004 Toyota Tundra
Last Online: 03-28-2008 11:20 AM
GRON86 is on a distinguished road.
GRON86's Photo Albums
Default 3rd Brake Light OUT! HELP please.
My 3rd Brake light is out, I know its not the bulbs I tested them on my friends tundra and they work just fine. So I was wondering could this problem be the cause of a bad fuse?
or is it more serious than that?
Thanks
Old 02-10-2008, 09:37 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 04:08 PM
Images: 3
Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything.
Mr. Creosote's Photo Albums
Default Re: 3rd Brake Light OUT! HELP please.
There is a heat problem in the CHMSL. Have a look at the chrome plastic reflector and you may find it has warped / burned from the heat. Perhaps there is a heat related problem with the socket which hold the bulb? I would check the fuse first, then use a voltmeter to see if you are getting 12V at the base of the socket.
Old 04-12-2008, 11:34 AM
2002 Toyota Tundra
Last Online: 11-06-2009 03:18 PM
Images: 4
arseum is on a distinguished road.
arseum's Photo Albums
My third brake light bulb kept burning out. It appeared that it heated through the chrome plastic casing, and some material from above was dripping down into the casing, and onto the bulb.
I used the aluminum-type faced tape. I am not sure if it is aluminum, but it is duct tape type thickness, and has a shiny metal coating. I cut it out to fit on the top underside of the casing, and I have had no more bulbs go out.
Old 04-12-2008, 11:37 AM
2002 Toyota Tundra
Images: 4
Default Re: third brake light
It is two or four phillips screws. It is simple. Check my other recent post, as my bulb was going out constantly, and I found an easy solution.
Old 04-12-2008, 11:38 AM
Images: 3
LEDs in mine.
Old 04-14-2008, 12:13 PM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: Today 12:42 AM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Thread merged w/ third brake light
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 04-14-2008, 12:22 PM
dublj's Avatar
Dealer : Keith Pierson Toyota Scion
Last Online: 10-09-2009 02:13 PM
dublj is on a distinguished road.
dublj's Photo Albums
I put led's in mine also. You just need to take out a few screws and you can get to them real easy.
'01 Tundra AC
Brake Light Indicator always coming on. You too???? Diamond Dog 1Gen-Sequoia 10 01-23-2007 05:32 PM
Blown brake light fuse locks out tranny shifter. russ25ny Tacoma 4 12-29-2006 03:28 PM
brake light on while driving sequoia24z 1Gen-Sequoia 7 12-04-2005 08:43 PM
Third Brake Light Question sdmahr Interior & Exterior 4 01-28-2004 08:40 PM
Converting Cargo to Brake light? unixguru Interior & Exterior 8 08-27-2003 08:46 PM
