Old 05-16-2006, 11:57 AM
natelev's Avatar
Dealer : Madera Toyota
2004 Toyota Tundra
Last Online: 04-21-2008 09:48 PM
natelev is on a distinguished road.
natelev's Photo Albums
Default AC Smell is Back!
Now that the warm weather has returned I have noticed the same odor problem with my 04 DC AC system. If I run the AC untill I shut the car off I see a large amount of condensation dripping under the truck. I am assuming that most but not all of the condesation is being routed away from the heat exchanger and the water that can't get away begins to promote mold growth and smell the next time I turn the AC on. If I turn the AC off 5 minutes before I shut down the truck and run the fan only I don't have the problem next time I run the AC but I don't feel like I should have to do this.
Has anyone come up with a mechanical fix for this? I am not really interested in spraying some type of chemical cleaner in there because I'm sure the problem will return. Has anyone taken apart the condensation catch tray? How do you get to it on the DC? Is there a design flaw that causes it to hold water?
Old 05-16-2006, 12:18 PM
Cali D's Avatar
Dealer : Bingham Toyota Scion
2002 Toyota Tundra
Last Online: 02-27-2009 01:20 AM
Cali D is on a distinguished road.
Cali D's Photo Albums
Default Re: AC Smell is Back!
I run my ac on the recycle mode and don't have the problem. From what I understand, it can only be properly cleaned with the chemical spray. I turn off my ac and let the fan run with the windows down for about a block before shutting down. Then when I run the ac I use the fresh ac mode for a block with windows down before using recycle. If you're still under warranty have madera toyota check if there's a problem. You also might want to try spaying lysol into the exterior intake vents. Try it using fresh ac mode then switch to recycle. This is only a temp fix, you will have to do this about once a week. I also used some ac spray cleaner at kragen that is used on interior and exterior vent. I used to have the mold problem in my old jeep grand junker. It is a nasty and annoying problem, it does't seem like this should occur in a truck that's only 2 yrs. old
2002 Limited 4WD TRD access cab
Rockford Fosgate front&rear K&N FIPK2 Series 57
Extreme Flow 3" cat-back 4"D 14"L rolled slant chrome tip
N.R.A. hitch plug Aftermarket lighting
Some people live an entire lifetime and wonder if they have ever made a difference in the world, but the Marines don’t have that problem.
—President Ronald Reagan
Old 05-16-2006, 12:21 PM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: 11-06-2009 05:57 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
You both are correct. You need to run it about a block on fresh without the ac on before you shut it down. The spray is the only method I have heard of and what we used at the dealership I worked at. I use Lysol.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 05-21-2006, 08:26 AM
Dealer : Miller Toyota
2004 Toyota Tundra
Last Online: 11-04-2009 04:21 PM
Erick W is on a distinguished road.
Erick W's Photo Albums
Try this http://www.bgfindashop.com/bgservices/climate.htm , Pat Goss highly recommends this and should solve your problem.
The Lysol work, but seems to be short term, I've tried it as Pat Goss directed.
Run your truck with the heat and fan on high, spay a can of Lysol in the air intake, dont forget to have the doors open.
Also, running the heat and fan on high in a used care can clue you in if its had water/flood damage. The heat and fan will oncover what someone maybe hiding.
Hope this helps.
Erick
2004 DC SR5
debadged
Magnaflow
K&N drop-in
Old 05-21-2006, 10:49 PM
cupidstoy's Avatar
Dealer : Reliable Toytota
2004 Toyota Tundra,
2003 Toyota Corolla Lola
Last Online: 12-31-2008 07:02 PM
cupidstoy is on a distinguished road.
cupidstoy's Photo Albums
based on the amount of out door debris caught in our corolla's a/c filter, and knowing the tundra doesn't have a fiilter, i think it's pretty likely we all have some leaves, pollen, small branches, bugs, etc in our a/c and heater core coils. something like that could easily plug up the small drain holes and cause water to be trapped in there.
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
Wish list: too long, wife would kill me!
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
Traded in Ridgeline. Back to Toyota! ( long) Steve Smith 1Gen-Tundra 11 05-19-2006 10:06 PM
Back up lights wallygator24 Electrical & Computer Systems 32 05-18-2005 08:15 AM
Gear grinding noise when vehicle rolls back maverick2003 4Runner 3 07-01-2004 11:46 AM
I'm thinking of going back to Ford....Mustang that is!!!! Johnny Law Off-Topic 21 05-01-2004 02:17 PM
I smell a rat, (really) craigferriter Interior & Exterior 12 10-07-2003 10:38 PM
