start up trouble then rough idle - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Like Tree1Likes
Thread: start up trouble then rough idle
  1. #16
    Supercharged Member 2003bajatundra4x4ac's Avatar
    Join Date
    Sep 2009
    Location
    Sunset Cliffside, CA
    Posts
    2,153
    Liked
    926 times
    Images
    14
    Rep Power
    41486
    Default Re: start up trouble then rough idle
    this isn't tundra related, but my wifes camry had a stumble on starting from a stop. when i changed the air filter i noticed the air intake tube had cracked 75% all the way around. it was almost in two pieces. the CEL has been on also.
    i ordered a new one from rock auto and wrapped the intake with duct tape for now. guess what, no stumble. always consider vacuum/air leaks....
    All you Baja lovers check out: http://www.MasOlas.com
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Join Date
    Oct 2011
    Location
    ft worth
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    I have a 2010 tundra that is hard starting and when it does start is a job to keep it running, I got a code of P0300 misfiring, It started yesterday and I went an but in a new battery which was going bad any way. I drove around town all afternoon and night. stopped and started 15 times. this morning i get in it and i would barely start and when it did it would not idle and ran real rough. when i hit the gas it would back fire, thoughts
  4. #18
    Join Date
    Jul 2006
    Location
    homestead
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    I am having the same problem, if I rev the engine slightly it runs smooth. Do this for about 30 seconds and I'm golden. It seem like there is air forming in the fuel line and it has to get run out of the lines. Correct me if I'm wrong but is it not part of the job of the fuel pump to maintain a pressure seal when the engine is off? If it is starting to fail, fuel drains and air is introduced, hence harder start and roughness till the line is purged. Does this sound correct or am I off.Cleaned TB, MAS and has factory double plugs.
  5. #19
    Join Date
    Jan 2013
    Location
    San Diego
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Click image for larger version.
Name:	hole in vaccum line.JPG
    same thing would not idle or barley at all less then 500 RPM
    I have a K&N intake also so I cleaned the throttle body (butterfly) cleaned the MAS with electrical cleaner it was dirty
    still rough idle or no idle at all.
    Now I noticed a hole in the vacuum line that leads to the intake tube on the other side of engine block
    where it crosses the block its a steel tube then back to rubber tube is were I found the hole.
    electrical tape was the fix.
    hope this helps
  6. #20
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,707
    Liked
    1078 times
    Images
    38
    Rep Power
    44364
    there also is a idle speed control motor on these trucks that get dirty and will cause it to run like crap. clean it and it will help as well.
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 214,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s, 3" LED flood cubes, 4" LED hyperspot Pods
    CBTMA Member
    For Sale: LED Light bar
  7. #21
    Lurking Member christopher126's Avatar
    Join Date
    Aug 2010
    Location
    deep
    Posts
    46
    Liked
    5 times
    Images
    3
    Rep Power
    5
    Quote Originally Posted by tundra3400 View Post
    where is this? and how would u clean it? im having same issue i cleaned MAF and put in new filter then cleaned TB still idling rough, does anyone have a way for me to find all vacuum lines? im not sure if i know where all them are? any map or pics out there with them highlighted? any helps appreciated
  8. #22
    Join Date
    Aug 2010
    Location
    deep
    Posts
    46
    Liked
    5 times
    Images
    3
    Rep Power
    5
    I replaced 02 sensor 2195 and everythings running fine now
    Sent from AutoGuide.com Free App
    tundra3400 likes this.
  9. #23
    Join Date
    Aug 2010
    Location
    deep
    Posts
    46
    Liked
    5 times
    Images
    3
    Rep Power
    5
    Until now im getting 2197 and 0158
  10. #24
    September Sky Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    7,640
    Liked
    2746 times
    Rep Power
    236614
    Quote Originally Posted by christopher126 View Post
    I second the question - where is this idle air control valve located?
    289,965 miles on the odometer [come see me when you get that on your ford]
    2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Ultragauge, Long Tubes with x-pipe and true duals, Stock intake, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front and rear differentials, Cooper Discover ATP tires
    Highwaylizard needs a new front bumper
  11. #25
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,707
    Liked
    1078 times
    Images
    38
    Rep Power
    44364
    Quote Originally Posted by Highwaylizard View Post
    my statement only applies to the 3.4L V6 tundras. the V8s dont have them. and i believe it located under the intake somewhere but im not completely sure.
    CBTMA Member
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. V8 Tundra Rough Idle
    By BAMAFAN4 in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-04-2015, 08:38 AM
  2. Rough Idle problem
    By Rayh78 in forum 1Gen-Tundra
    Last Post: 03-09-2006, 09:11 PM
  3. rough idle
    By PapaPS in forum 1Gen-Tundra
    Last Post: 01-14-2006, 02:30 PM
  4. rough idle, possibly burnt out light, bad mileage...
    By DevinSixtySeven in forum Engine, Intake, Exhaust, Induction
    Last Post: 02-22-2004, 05:21 PM
  5. rough idle
    By famous in forum Engine, Intake, Exhaust, Induction
    Last Post: 01-12-2004, 05:57 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
