start up trouble then rough idle
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Like Tree1Likes
Thread: start up trouble then rough idle
  1. #1
    Join Date
    Jun 2006
    Location
    statesboro, ga
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Question start up trouble then rough idle
    This is my first post, so hello to all. I have a 2002 Tundra with 75K miles and I have had no trouble what so ever until about a month ago. Sometimes when I start the engine, it will fire up, but runs very sluggish and will eventually stall unless I rev up the engine. After stalling, I can crank it again only to have the same problem. Once I rev it up good and begin to move, I have no trouble unless I am in a parking lot where I have to idle around at low speed (it will stall again). Once I am on the highway, I have no problems, and when I get home, I can cut the truck off and crank it back up and it runs fine. I took it to the dealer two weeks ago and they said the injectors needed cleaning, so I had them clean that for $90, but that has not fixed the problem. After reading other posts, I decided that I needed to clean the Throttle Body and the MAF. I cleaned the TB a week ago and had no trouble until yesterday. I cleaned the MAF today. I cranked the truck up probably five times with no problems but on the next crank the engine was very sluggish, almost as if it was only halfway running. I cut if off and crank it again, and it runs fine. Cut it on and off a couple more times and it runs sluggish. Probably about one out of five cranks results in a sluggish engine. Anybody have any ideas? I did install a K&N air filter about two months ago and it may have something to do with it. Any help will be greatly appreciated.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Banned AFP520's Avatar
    Join Date
    May 2006
    Location
    NJ/PA
    Age
    32
    Posts
    622
    Liked
    0 times
    Rep Power
    0
    Default Re: start up trouble then rough idle
    first thing that came to my mind was dirty maf... that k&n filter probly did it.. they douche them so bad with the oil when they are first produced (do you remember if it was in a sealed piece of plastic when you first bought it)
    anyway as you punch the gas, the oil is so heavy on the filter and it does go through the intake and onto the MAF... i had this problem when i used the TRD air filter (same thing as k&n) on my tacoma... you can use electronics cleaner from radioshack, but any average mechanic you'll see (even a toyota tech did this in front of me) used a can of brakekleen and that did the trick.. but you'll have several electronic junkies yelling up a storm that brakekleen is too strong for the maf...
    maybe see if you can snag another MAF from a junkyard and try running a stock filter and see if that helps some...
    and just for clarification, your stock air filter does filter air better than the k&n does... you can see right thru k&n's if you hold them up to the sun..
  4. #3
    Veteran Member longwoodklon's Avatar
    Join Date
    Feb 2002
    Location
    Murrieta, CA
    Age
    42
    Posts
    1,745
    Liked
    16 times
    Images
    9
    Rep Power
    870
    I've never had this question answered to my satisfaction. I had a '95 4cyl. toyota truck do this badly since new, and my Tundra does this slightly also. The key here is that the truck is warmed up real good, then left to sit for maybe 30min. Start the truck and it takes a little longer of a crank to pop off, and when it does it idles low until you get the RPM's up and some cool air thru it. To me, that's the key--Cool air. So I have to think it's normal, at least to some extent. I think though, that if your truck is stalling, that is NOT normal. /Mike
    2001 2WD Silver Tundra: 4x4 TRD springs, Camburg Uniballs with adjustable Bilsteins, Carson AAL, red/blue Bilsteins in rear, 265/75 Yokohama A/T, IS kit(minus bumper) and rims(hand polished), Billet Wing Window Latch Upgrade, TC Steering Bushings, RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. Stebel 300Hz Air Horn.
    202k miles and counting......
    2011 Honda Pilot EX-L, black with gray interior.
  5. #4
    Join Date
    May 2006
    Location
    NJ/PA
    Age
    32
    Posts
    622
    Liked
    0 times
    Rep Power
    0
    temperature shouldnt have anything to do with it though... my truck starts the same whether its cold or hot...
  6. #5
    Join Date
    Jun 2006
    Location
    Superior, CO
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Wow - I am having the exact same problem at 76K mile. 2002 V8 tundra. Tough starting, rough idle.....My truck has set codes. Toyota tells me that the injectors are running really rich. 7 out of 8 are running rich/leaky. After engine sits, fuel leaks into cycliner - essentially floods the engine = tough starting. I just posted message pertaining to this issue.
    Toyota quotes - $960 for one injector replacement-includes labor
    Another shop quotes - $183 for injector $90.00 for labor. This shop recommends replacing all 8 injectors for $1900.00
    Very upsetting to think injectors have gone bad.
  7. #6
    Supporter 42GAMI's Avatar
    Join Date
    Jun 2004
    Location
    808-state
    Posts
    1,677
    Liked
    0 times
    Rep Power
    15
    cold stat injector / circuit?
    MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
    ~ been there, done that, got the panties ~
  8. #7
    Join Date
    May 2006
    Location
    NJ/PA
    Age
    32
    Posts
    622
    Liked
    0 times
    Rep Power
    0
    the injectors shouldn't be faulty... how can the truck run rich if injectors are bad... wouldn't they be clogged??? it must be the control of the fuel flow... meaning MAF ...
  9. #8
    Join Date
    Jan 2006
    Location
    Santa Rosa, CA
    Posts
    173
    Liked
    0 times
    Rep Power
    10
    Poor fuel pump electrical connection?
  10. #9
    Join Date
    Jun 2006
    Location
    statesboro, ga
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the input. I haven't had any trouble since I cleaned the MAF a couple of days ago, and I am hoping that was the problem. It was REALLY dirty on the upstream side. I'll keep and eye on it and let you all know if the problem returns.
  11. #10
    Join Date
    Jun 2006
    Location
    Superior, CO
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I will try that too. Is is easy? How do you do it?
  12. #11
    Join Date
    Dec 2005
    Location
    Boynton Beach, FL
    Posts
    871
    Liked
    82 times
    Rep Power
    1519
    Quote Originally Posted by cobarr
    Is this an easy thing to do on an 03 Tundra V6?
    Ray Kane
    If you don't try, nothing happens
  13. #12
    Join Date
    May 2006
    Location
    NJ/PA
    Age
    32
    Posts
    622
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by Ray Kane
    pull it out.. and spray electronics cleaner all inside... let it drip and dry.. re-install.. should be good to go
  14. #13
    Join Date
    Jun 2006
    Location
    statesboro, ga
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Just as an update, I have not had any trouble since cleaning the MAF several months ago.
  15. #14
    Moderator thumbster's Avatar
    Join Date
    Aug 2005
    Location
    Portland OR
    Posts
    2,395
    Liked
    8 times
    Rep Power
    1424
    Quote Originally Posted by AFP520 View Post
    It doesn't have anything at all to do with the strength of the brake cleaner, it's all a matter of compatability between the item to be cleaned and the solvent itself. Brakleen is a chlorinated solvent, which most electronic cleaners happen to be as well. The difference is that some electronic cleaners contain lubricants, since they are typically used to clean potentiometers - using this would be counterproductive because your trying to remove oil contamination to begin with. Also, car manufacturers won't usually use a material in the intake tract that is not compatible with oil or gasoline (which in itself is a solvent) - the fumes from these alone would deteriorate the plastics and other non metal parts found in the intake. That being said, I think it's safe to say you won't do any harm using brake cleaner (the kind in the red can) to clean your maf sensor.
    1995 Mercury Villager - the man van
  16. #15
    Join Date
    Sep 2010
    Location
    Orange County CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I had this same EXACT problem with my 02 tundra V6. I did what they said, cleaned the MAF and put a new air filter which were both FILThY! I guess when I went quading in the dunes it jacked up my air filter so now I just change it every time I get back from dusty areas. Just a few bucks. After I cleaned those things up and put some lucas gas additive with some mid grade gas, it runs like a new truck again! I only use 89 now and never cheap gas. Now smooth idle and clean start ups every time. My next mission mission is to clean the throttle assembly and the fuel injectors. Maybe even the pcv valve just for kicks! Well this a lil gem of info for all tundra owners around my year. Before I did these fixes I thought I might have to trade it in. Now I am so glad I get to run my truck alot longer! I love my Tundra!
    Oh yeah! I used this electrical cleaner which worked really well. I sprayed the MAF and immediately seen how dirty it was. Then I used a electrical cleaning swab not a cotton swab which leaves lint and carefully cleaned the metal contacts and the bulb on the end and let it dry. I also cleaned the Air filter housing.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. V8 Tundra Rough Idle
    By BAMAFAN4 in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-04-2015, 08:38 AM
  2. Rough Idle problem
    By Rayh78 in forum 1Gen-Tundra
    Last Post: 03-09-2006, 09:11 PM
  3. rough idle
    By PapaPS in forum 1Gen-Tundra
    Last Post: 01-14-2006, 02:30 PM
  4. rough idle, possibly burnt out light, bad mileage...
    By DevinSixtySeven in forum Engine, Intake, Exhaust, Induction
    Last Post: 02-22-2004, 05:21 PM
  5. rough idle
    By famous in forum Engine, Intake, Exhaust, Induction
    Last Post: 01-12-2004, 05:57 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
