Old 06-21-2006, 10:02 PM
Dealer : Lakeland Toyota
2005 Toyota Tundra
Last Online: Yesterday 11:48 PM
Andrews_Father is on a distinguished road.
Andrews_Father's Photo Albums
Default How to disable the Key Reminder in a 2005 DC
I would like to disable the beeping when I have the key in the ignition and the door open. I read the two methods in the "garage" or electrical wiring section but when I pull my instrument cluster, I find only two connectors, not the four connectors as stated in the instructions. I am going to guess that the instructions are for older tundras, either standard or access cab. Does anyone have ideas on how to do it on an double cab?
Old 06-22-2006, 08:40 PM
AFP520's Avatar
Banned
Dealer : Koons Tysons Toyota
Last Online: 01-11-2007 10:13 AM
AFP520 is on a distinguished road.
Send a message via AIM to AFP520 Send a message via Yahoo to AFP520 AFP520's Photo Albums
Default Re: How to disable the Key Reminder in a 2005 DC
seeing that you're a subscriber and you have access to all the PDF's... i'd look at the wiring diagram and find what color wire goes to the door indicator... i'd assume when it opens, it completes a circuit hence why you hear the beeping noise.. i believe if you ground out the indicator completely and take it out of the loop, you would no longer hear the buzzing noise.. however your interior lights would also not come on when you open the door doing it this way...
i cant think of any other way to do it...
Old 06-22-2006, 10:03 PM
2005 Toyota Tundra
I have the wiring manual for my 2005 and am trying to compare the wiring diagrams to the 2001 diagram in Wiring Diagram section. It appears that the Method 2 in the Lighting and Electronics FAQ pulled the lead from the unlock warning switch (within the key ignition) to the instrument cluster.
When I compare with the 2005 diagram I have, this same switch goes into the Body ECU which then ties into the instrument cluster via THREE wires. Before I begin experimenting and potentially letting the smoke get out of the wrong wires, I thought I would turn to the experts within the population for help.
Old 06-24-2006, 07:56 PM
AFP520's Avatar
Banned
get the test light out and start checkin which wire gives power when the door is opened!
Trasponder Key problem with 2004 Sequoia bspicer 1Gen-Sequoia 7 01-19-2007 05:21 PM
Anyone knows how to program the factory alarm carloslopez63 Tacoma 17 04-11-2006 12:24 AM
Any way to disable the Key Warning? Larakin Tacoma 13 07-09-2005 01:31 PM
- Tacoma News & Reviews - tundrabrad Tacoma 73 03-12-2005 08:38 PM
