How often does your low tire pressure light come on?
+ Reply to Thread
Results 1 to 10 of 10
Thread: How often does your low tire pressure light come on?
  1. #1
    Junior Member CMB1998's Avatar
    Join Date
    Dec 2004
    Location
    VANCOUVER WA
    Age
    35
    Posts
    326
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Default How often does your low tire pressure light come on?
    I get a low tire pressure light about once a month. I have the stock tires and stock wheels and just turned 11K on my truck. Tires have been rotated and are still in good shape.
    I initially thought this was the result of living in an area where temps went from 40 to -40 in the same day. However I am back in Portland Oregon now and I still get the same problem with out the wild swing in temps.
    I usually just air up all the tires and the light goes off, but its kinda a pain having to do it over and over. With my old tacoma I had to add air to the tires maybe once a year.
    Is this normal?
    Chris
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Banned AFP520's Avatar
    Join Date
    May 2006
    Location
    NJ/PA
    Age
    31
    Posts
    622
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Default Re: How often does your low tire pressure light come on?
    tires do lose air pressure over time so maybe once a month isnt bad... can you honestly recall if you didnt have that light the last time you checked your tire pressure on all 5 tires every month???
    i know i never bothered once a month.. every rotation i checked them though
  4. #3
    Supporter Canada Jeff's Avatar
    Join Date
    Jan 2006
    Location
    Ottawa, Ontario, Canada
    Posts
    612
    Liked
    0 times
    Thanks
    0
    Rep Power
    10
    Never had mine come yet! Went to bigger tires, played with the preasures and still never seen it light up. I don't know if Toyota monitors the spare or not, but if it does, maybe check it.
    2008 Tundra Reg Cab, 5.7L
    2007 Ford Edge SEL AWD, Black! (wifes)
    Pulling 2001 288 Sunsation with a supercharged HP500EFI.
  5. #4
    Junior Member Gunter's Avatar
    Join Date
    Oct 2005
    Location
    Southern California
    Age
    27
    Posts
    119
    Liked
    0 times
    Thanks
    0
    Rep Power
    344
    I think my 05 DC's spare tire is monitored, I have never had the tire pressure light turn on, how many lbs are you putting in them/did they have before you aired up?
    Are you driving in streets, or alot of offroad?
    Im at 17500 mi.
  6. #5
    Join Date
    Jan 2006
    Location
    Santa Rosa, CA
    Posts
    173
    Liked
    0 times
    Thanks
    0
    Rep Power
    10
    3K miles so far and it hasn't come on. Maybe I should test it.
  7. #6
    Supercharged Member dsrtrcr01's Avatar
    Join Date
    Dec 2004
    Location
    Here
    Posts
    2,711
    Liked
    0 times
    Thanks
    0
    Images
    11
    Rep Power
    404
    NEVER (so far)
    '05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
  8. #7
    Join Date
    Nov 2004
    Location
    West Newton, PA
    Age
    58
    Posts
    183
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Also, after you adjust the tire pressures on all FIVE tires, do you go through the reset procedure? If not, the system may be looking for > 30 psi, for example, and maybe you're setting pressures to 32 psi. Then, if you lose 2 psi in any one of the tires (easy to do just because of temperature swings), the light will come on. If you do a reset, the system will allow about 4 to 5 psi drop before illuminating the light.
    The only time my light came on was after the pickup was several months old and the spare tire was 5 psi low (hadn't checked that one).
  9. #8
    Join Date
    Dec 2004
    Location
    VANCOUVER WA
    Age
    35
    Posts
    326
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    Thread Starter
    Quote Originally Posted by cookiemech
    I am not resting it, and from your discription it sounds like the problem I am having. Usually one tire is 1-2lbs below the others and that causes the dash light to come on.
    How do you reset the system?
    Chris
  10. #9
    Join Date
    Nov 2004
    Location
    West Newton, PA
    Age
    58
    Posts
    183
    Liked
    0 times
    Thanks
    0
    Rep Power
    11
    The owner's manual describes the procedure (can't remember off the top of my head at 3:50 AM). There is a reset button, which in my 2005 regular cab pickup is straight down from the steering column. I believe you turn on the ignition and hold down the button for some amount of time or warning light flashes. But consult your manual; if you don't find it, post again and I'll pull mine out.
    Hopefully that will fix the problem.
  11. #10
    Supporter skipo's Avatar
    Join Date
    Jun 2006
    Location
    Plantation, FL
    Age
    58
    Posts
    103
    Liked
    1 times
    Thanks
    0
    Rep Power
    12
    mine kept coming about every week or so until i found that stupid drywall screw near the inside of the tire, i wanted it patched but it was to close to the sidewall and i had it plugged didnt feel like spending $200.00 on a new tire when i only had 1500 miles
    TUNDRA DC 4WD NATURAL WHITE XSP
    Enkei 20" Deep Six Alloys, ARE LSII Tonneau Cover,Borla Dual Exhaust, LSD, JBL 6 Disc Changer, USA Spec Auxiliary Input, Sirius Sportster, Scanguage w/ Blendmount
    http://www.myspace.com/skiposurfever
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 11-13-2009, 02:57 PM
  1. synthetic oils - yes or no?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-10-2010, 03:43 PM
  2. Low Pressure Tire Light went on for 2 days.
    By phen in forum Highlander
    Last Post: 07-18-2005, 11:33 AM
  3. Bad tire pressure sensor (Sequoia)
    By High Altitude in forum Tires and Wheels
    Last Post: 02-06-2005, 07:29 PM
  4. Tire pressure question?
    By tmr812 in forum Tires and Wheels
    Last Post: 04-10-2002, 05:42 PM
  5. Fog Light Mod Quirks
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:16 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
