DC Lumber Rack??
+ Reply to Thread
Results 1 to 9 of 9
Thread: DC Lumber Rack??
  1. #1
    Junior Member natelev is on a distinguished road. natelev's Avatar
    Join Date
    May 2004
    Location
    Fresno, CA
    Posts
    68
    Liked
    0 times
    Rep Power
    10
    Default DC Lumber Rack??
    Does anyone have a solid lumber rack on their DC? Something other than the t-rac, I wan't one that goes over the cab so I can handle 20 footers. If you've got one I would appreciate a pick or two, I am interested in how it will interface with the plastic bed rail cap.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    May 2004
    Location
    Fresno, CA
    Posts
    68
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Default Re: DC Lumber Rack??
    Nobody buys a Tundra for construction or what?
  4. #3
    Ever the explorer rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush's Avatar
    Join Date
    Mar 2006
    Location
    kingman-Anaconda
    Posts
    2,274
    Liked
    0 times
    Blog Entries
    2
    Images
    137
    Rep Power
    1367
    I use mine in that capacity but I have the gemtop workmaster canopy on mine.
    I have had to put the long stuff into the rear window and extend it into the cab. (not the best option though)
    The top is rated for 250lbs and I am considering the roof rack option for the longer items.
  5. #4
    Junior Member stan01 is on a distinguished road.
    Join Date
    Nov 2005
    Location
    hawaii
    Posts
    136
    Liked
    0 times
    Rep Power
    8
    Do you have a fred rader mill store around your area? They sell kargomaster truck racks. Or find a welding shop to make one for you.
  6. #5
    Life Apprentice Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur wants you off his porch. Dinosaur's Avatar
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    I am a builder and have used my 03 AC Tundra for work since I bought it. I have a "Rack it" lumber rack. It is built pretty well and I have even gotten some compliments from people (yeah about a lumber rack). They also sell ratchet tie-downs that bolt on to the rack. They are kind of spendy but can be a real time saver. I have had no problems with that setup. My only improvement would be longer straps but they limit that so you can't tie a huge load. I would imagine they make racks for the DC. They manufacture in SoCal (City of Industry I think) so should be an easy find at a truck top distributor.
    Originally it was bolted directly on top of the plastic bed caps then a Leer cab high camper shell on top of that. As you might guess I ended up with some leakage issues. I just recently pulled everything off and went with a more permanent waterproofing solution cause I can't have leaks... but that is another story.
    Rob K.
    2006 DC, SR5, 4.7L, 5 speed, 4WD, LSD, Silver Sky Metallic, Keyless Entry, Tow Package
    Rackit (powder coated), Leer 100 w/Windoors, Westin wheel to wheel step bars
    Air lift Ride Control w/Quick Shot and Onboard Air, Bilstein 5100s (middle notch), Wheeler's AAL
    Powerslot cryo rotors, Hawk HD pads
    Bedrug, Slide Master bed-slide, Pop & Lock, Scangauge II, Viper 5601, MB Quart Speakers
    Toyo ATs 265/70/17 10 ply / Hancooks studded 265/65/17
    Racor remote transmission filter, All Amsoil synthetic lubricants
    Waiting to be installed:
    Eclipse Amp,
    TC steering rack bushings, TC diff drop, Downey end links, Kartec CV boots
    Wish List:
    Headers, SS exhaust system, Sliders, Spidetrax
    HD front bumber (Reuenal or ARB), Mile Marker Winch
    "If there are no dogs in Heaven, then when I die I want to go where they went." Will Rogers, 1897-1935
    Treat others as you would like to be treated
  7. #6
    Supporter cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy's Avatar
    Join Date
    Jun 2005
    Location
    Central Midwest (KS, MO)
    Posts
    884
    Liked
    0 times
    Rep Power
    928
    if you don't mind the extra length, a hitch helper allows you to stash long stuff in the bed and support it out the rear. i put a 14 ft canoe in my bed and long ladders. 20 foot lumber would be no problem. just put a red flag on the end and you're good to go. they run about 100 bux and it keeps the center of gravity low and no problems with brackets/bed rail caps or scratching up the top of the truck. ;-)
    2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
    Wish list: too long, wife would kill me!
    2003 Corolla (bone stock, but well loved and cared for!)
    "Expect the impossible."
    - JC and the Brothers of Thunder
  8. #7
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    I uploaded a few photos of my setup. I know it is not a DC but you get the idea. The rack is way solid and you could damage the truck bed before damaging the rack.
    You may have a "look" issue with just a lumber rack on top of the plastic bed caps. I ended up custom cutting my bed caps so that they are flush with the rack, and that is all covered by the shell. A rack with no shell will obviously have a different size footprint, so not sure how it would lay out with no shell.
    Good Luck.
    Rob K.
    Eclipse Amp,
    Wish List:
  9. #8
    Join Date
    May 2004
    Location
    Fresno, CA
    Posts
    68
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Thaks guys for the suggestions. Highlevel - thank you for the pics, that is a nice looking external rack. I was unable to find a Rack-it website other than a store in Sandy Eggo. I know the Tundra access cab and double cab have much different rail caps. The DC has these big thick plastic jobs that feel quite soft when you stand on them. I just don't know how well that cap will hold up with a load of 2x's or a glue lam up top.
    Stan01 - Thanks for the suggestion on the Kargomaster. Looks like a nice rack also and they say it can be adjusted to fit and full size truck. I might see if I can find one in person and try a test fit.
  10. #9
    Join Date
    May 2004
    Location
    Taylorsville, CA
    Age
    50
    Posts
    2,391
    Liked
    77 times
    Images
    25
    Rep Power
    145104
    You're welcome.
    The AC has those thick bed rail caps also. When they bolted down the rack the caps get squashed slightly.
    Rack-it does not have a website that I have found. They are only accessible through distributors as far as I know.
    Good Luck and happy truckin'.
    Rob K.
    Eclipse Amp,
    Wish List:
  1. Loose rack and pinion bushings.
    By ktdaddy in forum 1Gen-Sequoia
    Last Post: 05-07-2011, 07:32 AM
  2. Roof Rack System w/out using Factory Rack?
    By textacoma in forum Tacoma
    Last Post: 12-27-2005, 08:05 PM
  3. Bike rack for factory roof rack
    By carloslopez63 in forum Tacoma
    Last Post: 12-15-2005, 10:35 AM
  4. Stake Pocket Rack - Rear Only
    By Boston Tundra in forum Interior & Exterior
    Last Post: 07-25-2005, 02:12 PM
  5. Steering Rack noise and movement
    By dezert_rida in forum Suspension & Axle
    Last Post: 01-30-2005, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
