Old 08-19-2006, 11:46 AM
Dealer : Jack Safro Toyota Scion
Last Online: 10-22-2008 03:25 PM
Don H is on a distinguished road.
Don H's Photo Albums
Default Michelin LTX M/S
Just had a set of Michelin LTX M/S tires installed on my Tundra last week. With the OEM Dunlops I use to run 31lbs front and 33lbs rear. I ran them at that pressure because I found it to be the best compromise between ride and steering response.
With the LTX's set to that pressure the ride is so harsh that the whole truck shudders and booms when hitting large cracks in the road. I've lowered the pressure to the 26lbs front and 29lbs rear that Toyota recommends but now the steering is sluggish.
Here's my question to those of you that have Michelin LTX M/S tires and said that you thought they have a smooth ride. What shocks do you have installed? My Tundra Limited has the OEM shocks and I was wondering if I upgraded that maybe it would help and I could run a higher pressure.
BTW
Had an alignment done after I got the tires and they didn't have to change a thing. As bad as the roads are here the Tundra must have one tough front end.
Don H
Old 08-19-2006, 11:51 AM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Default Re: Michelin LTX M/S
With my P series LTX M/S I would run 32 psi in all 4 and carry at least 200 pounds in the bed.
Now that I run E series LTX M/S I run 45 psi in all 4 and carry at least 400 lbs in the bed.
Both gave a real smooth ride.
I also had my OE shocks replaced with HD Bilsteins.
Old 08-19-2006, 11:52 AM
Dealer : Haley Toyota. Of Richmond
Last Online: 08-10-2007 09:55 PM
mwfromva is on a distinguished road.
mwfromva's Photo Albums
I'm not a big tire guy, but from what I understand, the OE tires are technically "car tires" and the Michelins are LT rated truck tires.
It's going to be a stiffer ride.
Old 08-19-2006, 12:21 PM
I wasn't aware that the tire came both LT and P so I checked. They are a P tire with a max pressure of 35lbs.
I asked about the shocks because I think a better shock has a multi-valve system that rides soft over cracks and tar lines but stiffens up when needed for things such as chuck holes.
Don Hansen
Old 08-19-2006, 09:31 PM
1993 Toyota Truck Xtracab 4x4 V6
Last Online: 11-16-2009 02:03 AM
Shite2k is on a distinguished road.
Shite2k's Photo Albums
The stock shocks in Toyota's are generally a softer ride than most shocks you'll find, in most cases anyways.
The MIchelin LTX M/S is an awesome tire for tread life and they have pretty descent winter performance despite not being winter rated (they have good sipes, but I Think the compound they use isn't as soft as more winter rated tires - probably why they never got the winter rating on these I'm guessing). They do have a stiffer compound but I don't think this would have anything to do with it.
Old 08-20-2006, 01:24 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 04:03 AM
RichR is on a distinguished road.
RichR's Photo Albums
I have a set of LTX M/S 10ply on and at 50psi the truck rides like a buckboard wagon.I have 40k at about 1/2 worn.Good in snow and rain and they handle turns very well.Bad pavement is rough.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
Old 08-20-2006, 12:00 PM
I've been driving for a few days now with the tire set to 26 front and 29 rear. While the ride is still stiffer than with the OEM Dunlops I suspose I can live with it. It's the steering response I don't like. Last night, on a city street, I got behind a slow driver in the left lane. When I moved to right to get around him I could actually feel the front of the truck move side to side like like it was on marshmellows. Haven't put on enough miles to see if it will have any affect on my gas milage.
I got the tires because I'm about ready to take my yearly fishing trip to Canada. Towing my boat and the truck packed for a 2 week trip, I know I'm going to have to up the pressure. Higway 17, in Canada, can have some bad sections. I just hope the pounding doesn't shake the truck apart.
As for the shocks. It was my understanding that premium shocks have special valving that smooth out the road but still give control when needed. Control is determined by the speed and distance of tire/rim deflection caused by the road defect.
Don H
Old 08-20-2006, 12:08 PM
Tundrav8yamaha's Avatar
Banned
Images: 100
BTW
Don H
I have these tires and there pretty stiff but I think it's because the Trd edition shock's are made that way. These Tires are sooo much Better vs those Oem POs Dunlops. Michelin are the best tire out there for wear and tear and I'll replace back to them when these tires wear out..
Old 08-22-2006, 11:49 AM
At least I've got the steering response I want. Someone I work with said that Toyota wants 3 lbs less in the front to induce understeer which was what I was getting to the extreme. I brought the fronts up to 29 lbs and that improved the steering a lot. I will play around with the air pressure until I get the best compromise between ride and control. Maybe after the first time I drive in rain or snow I'll find they are so much better than the Dunlops I can justify the rough ride in my mind.
Don H
Old 08-23-2006, 12:53 AM
Dealer : Continental Toyota
2008 Toyota Tundra Black Crewmax SR5
Last Online: 10-07-2009 10:32 PM
Images: 1
figit is on a distinguished road.
figit's Photo Albums
Have you ever replaced your shocks/struts? If they're old, replacing them will make a big difference in your handling. I just put a 2nd set of tires (goodyear fortera's which blow away the stock dunlops & my firestone destinations) and had to drive about 2 weeks b4 my shocks/struts came in. The new hardware improved my ride and cornering more than I could have imagined.
Old 08-23-2006, 08:22 AM
Canada Jeff's Avatar
Dealer : Mendes Toyota
2008 Toyota Tundra rcsb 5.7L,
- Other - 2007 Ford Edge
Last Online: 11-10-2009 07:57 AM
Canada Jeff is on a distinguished road.
Canada Jeff's Photo Albums
I went with those tires in a 6 ply, 265 75 16 size. Little bigger, I run around 32 psi, and they ride great! Little soft in the corners, but it is a pickup truck with 16" wheels . What ply are your tires?
2008 Tundra Reg Cab, 5.7L
2007 Ford Edge SEL AWD, Black! (wifes)
Pulling 2001 288 Sunsation with a supercharged HP500EFI.
Old 08-23-2006, 11:56 AM
figit
What brand shocks did you put on?
Canada Jeff
Don't know how many plys, will check.
BTW
I assume your from Canada. Where abouts. Will be heading to Ignace, Ontario this Friday, Aug 25.
Old 08-23-2006, 11:58 AM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: Yesterday 07:47 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
You should run the same pressure all the way around. If anything, I prefer the fronts to be a little HIGHER pressure than the rears.
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Old 08-23-2006, 12:06 PM
figit
Canada Jeff
BTW
Ottawa.
Old 08-23-2006, 03:02 PM
The Michelin LTX M/S are:
Thread-2 ply steel/2 ply polyester
Side walls-2 ply polyester
Don H
Michelin LTX M/s vs Nokian Vatiiva delsoft Tires and Wheels 30 09-08-2008 08:14 AM
Michelin LTX M/S vs. Cross Terrain robertnltx Tires and Wheels 10 02-18-2008 07:49 AM
Michelin m/s LTX Tires HOTundra Tires and Wheels 8 01-15-2005 05:56 PM
Bridgestone Revo vs. Michelin LTX M/S teamlong Tires and Wheels 79 12-29-2004 12:39 AM
Michelin Cross Terrain SUV vs LTX M/S nhparrot Tires and Wheels 28 05-10-2002 08:54 AM
