Old 08-20-2006, 12:25 AM
Dealer : Claremont Toyota Scion
2002 Toyota Tundra
Last Online: 08-20-2006 06:26 PM
kakashi is on a distinguished road.
kakashi's Photo Albums
Question 02' tundra keyless entry remote help
Hey all, I lost my remote and that was the only one i had. I lost it awhile back. So i went on ebay and didnt know that FCC ID had to match or style has to match. I went on ahead to buy the FCC ID:BAB237134-056. Seller also gave a guide to "How to Program" or whatever. I followed the instructions about 5-6 times and didnt work one bit. I just remembered that the remote didnt even look the same, so i looked around on ebay and found the one that looks the same as my old one (FCC ID:BAB237134-022). I contacted the seller and told him the issue and he said that he'll give a refund. Funny thing is the the FCC ID:BAB237134-022 is much expensive than the one i bought off ebay.
My question here is if i were to buy the FCC ID:BAB237134-022. Will the instructions still be the same as the other one that i bought(BAB237134-056)?
the seller emailed me with the instructions written below:
Toyota keyless remote programming instructions:
The first programming option allows you to set the entry unlock to: (A)
unlock the driver door with one push, and the remaining doors with a
second
push OR (B) unlock all of the doors with a single push.
1. Open the driver's door. Remove the key from the ignition switch.
2. (Complete these steps within 40 seconds)
1. Insert the key into and remove it from the ignition switch 2
times.
(IN - OUT - IN - OUT)
2. Close, then open the driver's door 2 times.
(SHUT - OPEN - SHUT - OPEN)
3. Insert the key into and remove it from the ignition switch 1
time.
(IN - OUT)
4. Close, then open the driver's door 2 times.
5. Insert the key into the ignition switch and leave it in.
6. Close the driver's door.
7. Turn the key from LOCK to ON 4 times, ending at LOCK
(LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
8. Wait for the locks to stop, then remove the key from the
ignition
switch.
3. On the key fob, press and release both LOCK and UNLOCK buttons at
the
same time.
1. [For all doors unlock] press and release the UNLOCK button.
2. [For driver door unlock] press and release the LOCK button.
4. Open the driver's door. The programming is complete. If
programming did
not occur, start over.
The second programming option allows you to set the doors to lock when
when
the key is turned on, and unlock when the key is turned off.
2. (Complete these steps within 30 seconds)
1. Insert the key into the ignition switch.
3. Turn the key from LOCK to ON 5 times, ending at ON
(LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON)
3. Programming option (select one of the following).
1. [Ignition controlled lock ON] Close the driver's door.
2. [Ignition controlled lock OFF] Close the driver's door
twice,
leaving it closed.
(SHUT - OPEN - SHUT)
4. Turn the key to LOCK. The programming is complete. If programming
did
When performing the programming, the park lights may or may not flash
to
confirm that the program was accepted. The only way to confirm the
programming is to test them to see if they are functioning as desired.
If this isnt the right programming instuctions for my 02 tundra and the keyless remote FCC ID:BAB237134-022. May you guys please post a programming instructions? I beg of you.
Old 08-20-2006, 12:54 AM
Ando140's Avatar
Dealer : Beechmont Toyota
2002 Toyota Tundra SR5 V8 AC TRD LSD
Last Online: 10-31-2009 10:23 PM
Ando140 is on a distinguished road.
Ando140's Photo Albums
Default Re: 02' tundra keyless entry remote help
My 2002 has the FCC ID you quoted ending in 022.
If you only have the keyless entry (no alarm), you have to take the lower part of the dash off on the driver's side (the kick plate). Near the ignition cylinder you'll see a wire with 2 connectors on the outside (I think they're 8 pin). The wire comes out of the casing and goes into these connectors, then back in. Disconnect the connectors from each other (they may be wrapped in foam). Disconnector the connector that's attached to the ignition cylinder (should look the same). Connect one of the first connectors you separated into the ignition cylinder and the other to the connector that was connected to the ignition cylinder. This step activates the alarm, so you can leave them connected if you want when programming is finished and you'll have the alarm without the glass break sensor or status monitor (basically it'll only go off is someone opens the door).
The rest of this is the same whether you have the alarm or not:
The next step is to find the ECU, its usually located above the brake pedal... way up there. Look for a grey box with a small hole with a green button inside (you'll probably need a wire or something to press this button). Once you've located the ECU insert the key into the ignition and turn it to "ON". If you want to erase the old remote codes from the ECU, press the green button for 3 seconds, release, then within 5 seconds press the button again for 2 seconds. The lights should flash and chirper should sound indicating the codes have been cleared. To add a remote, push the green button for 3 seconds, then within 5 seconds, press the button you want to program on the remote. The lights should flash and chirper will sound 3 times indicating it has accepted the new remote code.
That should take care of it.... good luck, its really not as difficult as it sounds.
see this thread for more info
Old 08-20-2006, 06:35 AM
2002 Toyota Tundra
so does that mean that i have to have the same FCC ID as the original one or can i use the one ending with 056 rather than 022? just a question.
Old 08-20-2006, 03:57 PM
Ando140's Avatar
Yeah, you have to have the one with the same FCC ID as the original.
Old 08-20-2006, 06:24 PM
2002 Toyota Tundra
cool, imma order the remote now and if i have any trouble. May you help me? ill message you if i have trouble along the way through the instructions. oh yeah. i bought a spare hey off of ebay. i got so pissed off, cause he sent me the wrong size and all. he's all like yeah its for the 2002 tundra model. and i go to wal mart and had them duplicate it for me and now i cant return it. so yeah, for all you guys out there. dont buy blank keys off ebay.
Old 08-20-2006, 08:19 PM
Ando140's Avatar
yeah, you can pm me if you have any questions... its been a little while since I did mine, but I'll help you as much as I can.
on the key blanks... I bought a couple off ebay and they seem to be fine, except they're a little longer than the originals, so they just don't go in all the way.... but they do work fine for the most part. It did take awhile to break them in though.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/69747-02-tundra-keyless-entry-remote-help/
Posted By For Type Date
can you disable that beep beep sound when you use the remote to lock/unlock doors? - Toyota Forums :: Toyota Nation This thread Refback 11-14-2008 08:17 PM
Programing 04 4runner sport SR5 keyless entry remote Icerunner Electrical & Computer Systems 7 07-26-2006 10:17 PM
It can be done: Remote Start with Factory keyless entry MZ3 1Gen-Tundra 19 04-11-2006 10:24 PM
2000 tundra keyless entry MD8181 Electrical & Computer Systems 2 08-05-2005 05:52 AM
Adding Keyless Entry and Remote Start 2004 Tundra tm311 Electrical & Computer Systems 3 05-20-2004 08:06 AM
HOW-TO: 2003 Tundra Keyless Entry Install Procedure pcosens Member Mods 0 11-26-2003 12:36 PM
