Re: Starting Problems on 2001 Tundra
Check the voltage on your battery to make sure you alternator is charging properly or could do the old timer test and start the truck remove the battery cables and see if the truck will run staight off the alternator.
2006 Tundra Double-Cab X-SP 4WD
2.5" piping w/ Magnaflow (clip in gallery) - OBX Pedals - 20% Tint - DEBADGED!
Pioneer Z1 w/backup CAM & ipod - Painted Brake Calipers - ATE Slotted Rotors + Pads
2.5 Daystar w/ AAL - 275/55/20 Toyo A/T
