Tundra Rotor Replacement
+ Reply to Thread
Results 1 to 4 of 4
Thread: Tundra Rotor Replacement
  1. #1
    Join Date
    Dec 2004
    Location
    Birmingham, AL
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default Tundra Rotor Replacement
    Sorry for an additional post on "brakes." I am a novice mechanic and have searched the site to get a simple question answered but have not found it. I want to replace my rotors and pads. In order to remove the rotors I know that I will have to remove the calipers. Do I have to remove the brake lines in order to move the calipers to a position so I can get the rotors off? The brake line is metal from the caliper to a "bracket" - then it is a rubber line. Will I bend or kink the metal if I don't remove the line?
    Thanks for your help.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Gort11's Avatar
    Join Date
    Feb 2004
    Location
    Emerado, North Dakota
    Posts
    53
    Liked
    0 times
    Rep Power
    12
    Default Re: Tundra Rotor Replacement
    NO, get a piece of coat hanger or wire and just tie them up, do not let hang by the brake hose.
    2014 Toyota Tundra SR5 4X4 Barcelona Red,SR5 upgrade package 4.6L V8
    2013 Toyota Venza Limited Blizzard Pearl,Vent Visors,Auto Start,Weather Tech floor liners and cargo floor liner
    "You Can't Fix Stupid"
  4. #3
    Supporter cupidstoy's Avatar
    Join Date
    Jun 2005
    Location
    Central Midwest (KS, MO)
    Posts
    882
    Liked
    2 times
    Rep Power
    930
    also, while loose, inspect for any damage to line - kinks, leaks, dry rot, etc.
    if you don't break any of the line connections, you won't have to bleed a lot of air out of the lines, although i would suggest a bleed once everything is back together. in fact it is recommended to completely change out brake fluid every few years. it get's dirty from little particles of rubber and attracts moisture. this would be a good time to take care of it.
    be sure to inspect the calipers while they are loose for any signs of leakage and lube the moving parts with caliper grease (probably provided in a small tube with the new pads). also, be sure to get them torqued down properly when reinstalling.
    while you have the rotor off, check the wheel bearing assembly and on a 2000 model year, i would definitely repack the bearings while you have everything apart.
    if you have a hard time remembering how the shims go and what direction the pads go, do one wheel at a time so you can look at the other wheel to see how it goes back together.
    2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
    Wish list: too long, wife would kill me!
    2003 Corolla (bone stock, but well loved and cared for!)
    "Expect the impossible."
    - JC and the Brothers of Thunder
  5. #4
    Supporter MtTrout's Avatar
    Join Date
    May 2005
    Location
    MT
    Posts
    426
    Liked
    0 times
    Rep Power
    10
    I replaced my brakes and rotors about ten days ago. It was not that hard at all. One thing suggested above, which I did not do or even think about, was repack the bearings.
    I have never done brake work before, and followed the Haynes manual. I either misread the deal or it is overly cautious but I took off the calipers instead of hanging them by a coat hanger. It actually seemed a little easier with the pressure relieved but I did have to bleed the front brakes once done.
    To bleed the brakes, I got a 2' section of plastic tubing at the parts store and attached one end to the bleed valve and the other in a clean gatorade bottle about half full of fresh brake fluid. I topped off the master cylinder and had my wife pump the brakes while I kept an eye on both to make sure the mc did not get too empty and watched until the tubing until it came through without any air. Be sure and start with the passenger side brake first as it is farther from the mc.
    I purchased Wagner Quiet Stop ceramic brakes, Raybestos rotors, and brake fluid for a total cost of about $200 for everything.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. How does the performance of the 4.7L i-force V8 compare to the 5.3L LS1-based Chevy?
    By Threxx in forum Engine, Intake, Exhaust, Induction
    Last Post: 04-22-2009, 07:54 PM
  2. How Good are Tundras Off-Road - Really???
    By taconow in forum Off-Roading
    Last Post: 01-27-2007, 12:26 AM
  3. Tundra DC Parts Compatibility
    By RoundTuit in forum 1Gen-Tundra
    Last Post: 08-25-2006, 09:49 AM
  4. Which truck is faster, Tacoma vs Tundra
    By fslaugts in forum Tacoma
    Last Post: 12-23-2005, 09:13 PM
  5. HID auxiliary lowbeam photos
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 06:06 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
