Rear Brake Adjustment
+ Reply to Thread
Results 1 to 6 of 6
Thread: Rear Brake Adjustment
  1. #1
    Junior Member Parshal is on a distinguished road.
    Join Date
    Mar 2002
    Location
    Parker, Colorado
    Posts
    234
    Liked
    0 times
    Rep Power
    12
    Default Rear Brake Adjustment
    I did a search here but didn't find exactly what I was looking for. My brake pedal was getting pretty sloppy so I decided to adjust the rear brakes. I've got the LSD and it's pretty tough to get a good feel for how tight the brakes are getting. I got them fairly tight and took it for a ride. Boy, does the pedal feel good! However, applying the parking brake I could only get nine clicks or so if I pressed it real hard. The book says 6-9 clicks with 66 lbs. but I'd guess I've got more than that. I still like the feel of the pedal and was thinking that I needed to bleed the brakes to get clean fluid in them ('03, 85k miles, original fluid) until I adjusted the brakes. I'd say, on a scale of 1-10 with 5 being adjusted perfectly I'm at about 6 or 7.
    Now, my question is this. I always use the parking brake and I know it adjusts the rear shoes. Will the parking brake loosen the shoes if they are too tight? It wouldn't appear like it would since the little metal tab keeps the star adjuster from going one way.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member benbeaux is on the right track. benbeaux is on the right track. benbeaux's Avatar
    Join Date
    Feb 2006
    Location
    Plano, TX
    Posts
    640
    Liked
    0 times
    Images
    2
    Rep Power
    8
    Default Re: Rear Brake Adjustment
    [/quote]
    Now, my question is this. I always use the parking brake and I know it adjusts the rear shoes. Will the parking brake loosen the shoes if they are too tight? It wouldn't appear like it would since the little metal tab keeps the star adjuster from going one way.[/quote]
    Did you check/top off the reservoir with fresh fluid before starting?
    Self adjusting only works to a certain point (still soft) & then you have to manually adjust the brakes.
    I adjusted my brakes by visually watching the gap through the inspection hole at the edge of the brake backing plate. I left about a 64th of an inch.
    My brakes were al lot firmer & my emergency brake pedal travel dropped by almost 50% (guesstimate). Nothing has changed with this since I made the adjustment several months ago. I use my emergency brake every day when I park.
    HTH
  4. #3
    Supporter cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy has done just about everything...and then some. cupidstoy's Avatar
    Join Date
    Jun 2005
    Location
    Central Midwest (KS, MO)
    Posts
    884
    Liked
    0 times
    Rep Power
    928
    the parking brake does adjust the rear shoes, but the actual cable on the parking brake itself is adjustable where it goes under the truck by the driver's side door. first adjust the rear brakes, then adjust the parking brake cable. here is a good read to learn more about the tundra brakes:
    Toyota Tundra Brake FAQ - Maintenance and Adjustment
    2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
    Wish list: too long, wife would kill me!
    2003 Corolla (bone stock, but well loved and cared for!)
    "Expect the impossible."
    - JC and the Brothers of Thunder
  5. #4
    Junior Member tecoya is on a distinguished road.
    Join Date
    Mar 2005
    Location
    Orange County, CA
    Age
    27
    Posts
    55
    Liked
    0 times
    Images
    3
    Rep Power
    9
    i heard from a friend mechanic that another way to adjust the drums in the back is just to put the truck in reverse, back up to a pretty decent speed and just slam on the brakes... do it a couple times and its adjusted. I have the hardest time believing that can even be true...
  6. #5
    Ever the explorer rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush is a pinnacle in their own mind. rambrush's Avatar
    Join Date
    Mar 2006
    Location
    kingman-Anaconda
    Posts
    2,274
    Liked
    0 times
    Blog Entries
    2
    Images
    137
    Rep Power
    1367
    Quote Originally Posted by tecoya View Post
    Not a good idea; back up softly and apply the brakes not slam the gas and apply the brakes, very good way to glaze the shoes.
  7. #6
    Veteran Member yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert has done just about everything...and then some. yspert's Avatar
    Join Date
    Dec 2005
    Location
    The Real World
    Posts
    660
    Liked
    10 times
    Rep Power
    1025
    adjust the drum brakes with the star wheel ONLY!!!
    there should never be a need to adjust anything having
    to do with the cable. yspert
    Graduated from Y to Z status. I only work for "likes"!
  1. 12-05-2010, 06:10 AM
  1. Installed Deaver 3 Leaf Aal-- Not Happy
    By kylant in forum Towing
    Last Post: 03-28-2007, 07:53 PM
  2. Group dyno run results
    By v8Toilet in forum Off-Topic
    Last Post: 10-23-2005, 08:44 PM
  3. rear brake drum paint
    By burnham in forum Brakes
    Last Post: 09-12-2005, 06:35 PM
  4. Replies: 4
    Last Post: 07-16-2005, 10:35 AM
  5. Replies: 4
    Last Post: 05-25-2005, 07:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
