This is a discussion thread titled "speedo fix", within the 1Gen-Tundra forum, part of the Truck Forums category.
anyone know how to fix the speedo in a 2006 4wd tundra. just put on 33's with the tuff country lift and when i drive a mile, it only reads 9 tenths. i know that means i will be driving faster then my speedometer reads. anyone that has 33's fixed this, and if so how?
TruSpeed Speedometer Recalibrator. Under $200 and will fix your problems.
2004 DBL Cab 2WD w/ JBA Headers, Boosted Tundras S/C, IPT Valve Body Upgrade, Cat Back w/Magnaflow Muffler, Westin Nerf Bars, Leveling Kit, Pro Comp 17x9 w/Pro Comp Xtreme AT 305/65R17, Precision Billet Grill, Tow Package, & Rollbak Tonneau Cover. Inside: Alpine 9851 head unit, Alpine DVD player, Alpine 10" center drop down monitor w/wireless headphones, 7" passenger visor monitor, JL Audio Stealth 10" Sub, JL Audio front and rear speakers, JL Audio 6 channel amp.
has anyone used this with 100 % success and can a dealer install it- the truspeed calibrator with 33 inch tires
The truspeed or any other calibrator will work just fine, these things all just modify the speed signal (its just a pulsing signal). Install would be very easy, just supply power and ground, then tie into the speedo wire (should be orange with black stripe) behind the cluster, set the truspeed, and your done.
__________________ 2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
Hypertech or someone like them doesnt make a programmer for the tundra???
No programmers, Toyota dealerships can do it with there scanners but no one has had any luck getting them to, they just don't have good enough techs working there (there jsut good at services I guess).
I put the truspeed on my truck with 33's and it works great.
Took a little while to dial in, but using a gps I got it perfect. The truspeed
also has two settings for two different tire sizes, incase you switch for
winter use.
Chris
__________________ Interior: Catch all extreme front floor mat, Custom stereo (JL, XM, and Alpine), Rear seat 1 inch spacers (for amp), Window tint, Radar detector Exterior: Front skid plate, Black headlights, Debadged tailgate, Rcd lift 6", 17x9 Helo Maxx6 black, 285/70/r17 BFG TA/KO, TYC black taillights, Under hood lights, Westin step tubes, Single in dual out Flow Master, Billet fuse box cover, Billet throttle body cover, Line-x bedliner with Toyota logo, Manual hub conversion kit with Aisin hubs
