Re: Mildew on exterior rubber trim
Have you only been using a sponge to try to rub it off? Rubber is very porous so you'll probably need to use something like a toothbrush.
For rubber, use gentle cleaners. Harsh stuff will dry it out faster so you'll end up having to replace it sooner.
Once you get it clean, use silicone spray or Wurth Rubber Care to preserve it. This makes the water bead on the rubber, which allows the rubber to dry faster and reduces the mildew issue.
