Old 11-02-2006, 02:35 PM
Dealer : Toyota of Greenville
Last Online: 10-21-2009 10:59 AM
T-Nick is on a distinguished road.
T-Nick's Photo Albums
Default Anyone daring enough to try this!
Hydrogen Booster
Water for Fuel
I have read alot about this the past couple of months. Seems to have alot of potential. Not sure what the long term effects would be if any. If anyone has tried this or has feedback or knowledge I would be very interested.
Old 11-02-2006, 07:28 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Images: 22
Default Re: Anyone daring enough to try this!
well, it's a good idea...and i'm sure it works...the scientific principles are quite sound. it's easy to split the h and the o, and would be interesting to try...first of course on a car i had the luxury of modifying/risking to that degree.
i'm also quite certain that the guys posting the content on that site have collectively solved the world's fertilizer problems.
at least there's nothing wrong with their hydrolytic equipment.
if you try it, i wouldn't mention to them that you drive a truck .
-sean
GFX by FreedomEagle50
Manual Hubs
Old 11-02-2006, 11:50 PM
low c1500's Avatar
Dealer : Red Deer Toyota
Last Online: 11-20-2009 11:33 AM
Images: 1
low c1500 is on a distinguished road.
low c1500's Photo Albums
Did this in grade 11 chemistry.
I recall it took alot of electrity to make a little hydrogen.
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
Old 11-03-2006, 02:24 AM
Dealer : Toby Murry Toyota
1997 Toyota T100
Last Online: 07-29-2008 08:10 PM
LTrain is on a distinguished road.
LTrain's Photo Albums
Originally Posted by T-Nick View Post
Hydrogen Booster
Water for Fuel
They tested this on Mythbusters...it was busted.
Old 11-03-2006, 09:04 AM
Do you know what episode or what else was on with it I would be very interested in watching it.
Old 11-03-2006, 10:21 AM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
my guess is if it was safe and economic, you would see it on every car/truck out there right?
Old 11-03-2006, 11:50 AM
1997 Toyota T100
Hey T-Nick, I looked it up, and it appears to be Episode #53. They downloaded the plans off the internet, built it and installed it in an old Oldsmobile.
I'm going out on a limb and saying that if these guys can't build it and make it work, the average Joe without their resources probably isn't going to have any more luck with it.
Old 11-03-2006, 09:52 PM
low c1500's Avatar
Images: 1
When you burn hydrogen + oxygen it releases energy and makes water, then you can put energy back into the water to get hydrogen and oxygen again.
Only problem with this is beacuse putting energy back into the water is 100% effiencent. So it actuallly takes more energy to make hydrogen than will be release when you burn it in the engine.
Also internal combustion engines are very poor at converting the energy from the burning fuel to mechanicla motion. There only about 1/3 efficient, beacuse about 1/3 goes out the exhaust as heat, and 1/3 of the energy goes to the radiator.
So if you make this, and get the electricity from the vehicles alternator, I estimate that you can maybe get 20% of that alternator energy back as mechanical motion.
If this thing worked then the mystery of Fusion would be solved (to a have a process that outputs more energy than is inputed).
Old 11-06-2006, 07:57 AM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
Last Online: 11-19-2009 12:19 PM
shall36 is on a distinguished road.
shall36's Photo Albums
Low c1500 hit the nail on the head, I think. There's no free lunch. Believe it or not, when you put a load on an alternator, the altenator puts up resistance. In other words, the altenator requires a certain amount of HP to put out the 20 to 30 amps needed to break apart the H20.
Someone chime in here, but I think there is a big difference between using liquid hydrogen (e.g. fuel cell cars) as fuel and just injecting gasious hydrogen into the intake track.
Old 11-06-2006, 10:41 AM
Moderator
Images: 2
the same goes for women. i wish i could get more output with less input
what are the negative effects or things that could go wrong? I know that it draws more energy than it puts out, but can it blow up or anything?
Old 11-06-2006, 12:02 PM
Images: 22
lmao!
from reading over their website, it appears that a major downside is conspiracy theorism and emotional politicking . also, it did seem odd when considering it does take a lot of energy to convert water to gas, how do you create that energy? seems like you'd be plugging in your car, or using some other type of energy to fuel the process. i guess either dreams and rainbows, or perhaps a solar cell.
hydrogen requires an oxidizer, then it goes big. oxygen goes even bigger. maybe a better question would be how do they compare to propane, which is pretty common on public transportation vehicles and small industrial machines.
-s
Manual Hubs
Old 11-25-2006, 01:02 PM
Epicdude's Avatar
1997 Toyota Tacoma
Last Online: 12-25-2006 03:33 PM
Epicdude is on a distinguished road.
Epicdude's Photo Albums
Originally Posted by DevinSixtySeven View Post
lmao!from reading over their website, it appears that a major downside is conspiracy theorism and emotional politicking . also, it did seem odd when considering it does take a lot of energy to convert water to gas, how do you create that energy? seems like you'd be plugging in your car, or using some other type of energy to fuel the process. i guess either dreams and rainbows, or perhaps a solar cell.
-s
It seems there are more questions than answers in this forum. There is no conspiracy theory crap on my website. BUT People willing to bet lock, stock, and barrel on what some jackasses put on their TV show. Hold ON!!! I seen that episode, and they are scientific idiots. I also seen the one where they tested a dummy on a crapper full of gasoline. Nowhere do they test their IQ or the show's producer's IQ. I'm sure it wouldn't be a long show if they did. Lets get scientific and stop jerkin my chain.
IF YOU READ!!!! READ would be the important part in that last sentence. Read our website. WWW.WaterforFuel.Com
Read the Blog, and don't revolve your life around what you see on TV.
I just put up a blog from an artical from 1974 (I'm 32 also) and the UCLA guys had a car and so did Bringham Young. In my case, nothing is worth more than running everything on water(house, car, boat, plane), and if you're not willing to sell me the product, I'll make it myself... you want to buy one? Because gas is going up and it will run out, and we are fighting a war over it, people are dying for your freedom to buy cheap gas. If you want to talk Toyota, that's fine, but I check all the websites that send me hits and keep the sheep in line. Don't make me come back. And if you're too scared to test out something before you put your scientific, TV rated, sticker of approval on it, just say so. Think of the bennitfits and not the road blocks. Just like women...
And if you're not getting more out of your woman then maybe you should trade her in for a newer, import design with bigger wheels, smaller/more powerfull engine, and a quiet ride...lol
Old 11-25-2006, 02:18 PM
low c1500's Avatar
Images: 1
First off, I have read very little on your website, and I'm all for Hydrogen powered vehicals (mainly the hydrogen fuel cell). Also I'm an Industrial Instrument Technologist, with a Journyman Instrument Technicain ticket. I am very familair with thermo-dynamics. The idea that hydrogen can be added to the intake of engine will indeed increase its power output and mpg. But the idea that an engine alternator can provide the energy to turn H2O back into seperate molicules, and then burn the new hydrogen for increased mpg is IMPOSSIBLE!! There is just way too much energy loss do to friction and heat loss. I will state just a few energy losses in the system: alternator is never 100% efficient in turing mech energy into electrity, the actual "cracking of the H2O" can never be 100% efficient (if it was then FUSION has been finally solved!!), also the biggest enery loss of all is the actual engine, it is able only to convert about 35% of the energy in the burnt fuel to mechanical motion.
If a "cracker" was ran by a engine alternator then for every 10 parts of mechanical energy put into the alternator, I would say that only 1 or 2 parts would be recoverd when the engine actually burns the new hydrogen and turns it back into mechanical energy. About a 500% LOSS!
Now if your "testers" are using a battery bank and not the alternator, I could see the vehcile getting increase MPG, but only until the batterys went dead, then when they were recharged your putting in 5X more energy in, then the actual burnt Hydrogen put out from the "cracker".
Read up on the Hydrogen fuel cell, they take clean burning Hydrogen, put it through the Hydrogen cell, and get electricty out, and it has very few energy losses. It works great, only problem it that you need the Hydrogen to begin with. Using large scale industrial "cracking" devices hydrogen can be produced form water, again with very little energy loss.
These are just my college educated (chemistry, thermo/fluid-dynamics, calculus etc..) thoughts. Your crazy claims of 2x MPG from usoing this stuff is ridiculas.
Old 11-25-2006, 03:40 PM
Dealer : Prime Toyota
Last Online: 10-14-2009 06:45 PM
Apollo is on a distinguished road.
Apollo's Photo Albums
I would love to see something other than fossil fuels. But with the oil companies so far up all of the politician's a$$es, you will never see it until it all collapses. Either that, or global warming will become too much of a problem to deny. But remember, "we're study'in it". I'm no tree hugger, but I do believe there is a problem. Yes I drive a truck so I'm a hypocrite ! But this whole oil + politics thing just pi$$es me off ! Remember all of those GM electric cars ? They took them all away because they actually worked.
http://www.ev1.org/
Sorry I'm venting ...
These will rock when they get an entire line of vehicles to choose from:
http://www.teslamotors.com/index.php?js_enabled=1
I'm going to have a beer and calm down now ... Thanks for listening.
No More Fords
Old 11-25-2006, 05:12 PM
phanham's Avatar
Dealer : J. Pauley Toyota Scion
Last Online: 09-12-2009 07:58 PM
phanham is on a distinguished road.
phanham's Photo Albums
Video showing H2O as fuel (HHO) -- guy makes welders, but video shows that he incorporated same design successfully in his car.
2006 Tundra DC SR5 TRD 4x4. Pretty much stock besides the Extang Trifecta Tonneau, Hellwig sway bar, shorter antenna, & Kel-Tec in the console.
