  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 11-09-2006, 04:36 PM
Dealer : Coad Toyota
2006 Toyota Tundra Salsa! Access cab
Last Online: 09-06-2009 10:20 AM
joewildlife is on a distinguished road.
joewildlife's Photo Albums
Default Tundra vs. Tacoma and towing
Hey,
I bought a 2000 pound bass boat package a few years ago, it is an heavy aluminum 17' boat with a 60 hp motor, 56" wide bottom and 83" beam. This is not a small boat, and is quite heavy when you add three batteries, gas, gear, coolers, trailer, and maybe even a full livewell.
It did NOT tow okay with an Isuzu Rodeo V6, not at all!
Not wanting to make the V6 mistake again, I naturally went and bought a Tundra V8. I went with the Access Cab because of the occasional need for a back seat. The Tundra is the first V8 I've had in awhile and tows my boat wonderfully!
So, I'm talking to a guy and he says "you should have just bought a Taco DC longbed V6, it would tow your boat just as well....blah blah blah...and get better gas mileage." and he quoted that the 4785 lb Tundra has almost equal weight to HP and weight to torque numbers as the Taco.
So I get to thinking about it and a bit of buyer's remorse starts sinking in...is it possible that the Tacoma could pull my boat as confidently as the Tundra? Am I wasting money on gas to run a V8 when a Taco would have been just as good at towing?
Tundra weight to HP ratio: 17.66 Taco 17.52
Tundra weight to ft/lb ratio: 15.29 Taco 15.55
Boy that's close. But I figure I need to add the boat into those figures.
Tundra + Boat weight to HP ratio: 25.04 Taco+Boat 26.00
Tundra + Boat weight to ft/lb ratio: 21.68 Taco+Boat 23.06
Just cause 266 ft/lb of torque gets around a 4135 lb Taco just as well as 313 ft/lb of torque gets around a 4785 pound Tundra (or does it?) Doesn't mean the Taco would handle the extra 2000 pounds as well as the Tundra. Extreme example you could have 150 ft/lb torque in a 2000 pound car and you know it can't pull a 2000 pound boat!!
Am I thinking right here? Anybody tow with both? Did I do the right thing going with the Tundra, when towing capacity was THE reason I switched rigs? (If I didn't have the boat, I'd be driving a V6 RAV4 Sport.) Really, I got the truck to tow the 2000 lb boat confidently. Did I buy the right truck?
2006 4WD TRD Access Cab
Salsa Red Pearl
2010 Sienna XLE
Blizzard White
2003 Subaru Outback AWD
Old 11-09-2006, 05:30 PM
funfinder4's Avatar
Dealer : Atkinson Toyota
Last Online: 11-09-2009 02:41 PM
Images: 4
funfinder4 is on a distinguished road.
funfinder4's Photo Albums
Default Re: Tundra vs. Tacoma and towing
I haven't had mine for very long, but the short answer your looking for is YES!
I to just stepped out from towing my travel trailer with a V6 to a V8. There is more to it than HP. Comfort while towing has GREATLY improved. Why yes it's true the Taco weighs less, but that can also be a disadvantage when towing. Generally speaking, the more the tow truck/car weighs (comparatively) the more comfortable and safer the combo is while towing.
I was totally shocked the first time we towed our camper with the Tundra. Being able to comfortably tow on the highway @ 65 mph in 5th gear (torque converter locked up) at only ~2,250 rpms was very pleasant compared to towing in 3rd gear at 3,000 + rpms @ only 55-60 mph with my V6.
At the end of the day most of us all get about the same mpg while towing anyways no matter if you have a V6, V8, or diesel. It's a little to early for me to tell for sure but I think I'm accurately getting 1-2 more mpg with my V8 while towing than I got with my V6.
Old 11-09-2006, 05:43 PM
Dealer : Ferris Toyota
2005 Toyota Tundra
Last Online: Today 08:44 PM
skinny2 will become famous soon enough.
skinny2's Photo Albums
Take a look at where the torque peaks on these two engines and that should answer your question. The Tundra is 600rpms lower. Even if the weight to ft/lb is in the ballpark, one is going to be revving a lot more to move the load the same.
'05 Tundra DC 4x4 (my DD)
'05 Honda Odyssey (her DD)
'03 Ram 3500 Cummins 6-speed dually (for haulin)
Old 11-09-2006, 10:01 PM
bbfirebird's Avatar
Dealer : Power Toyota Scion Tempe
2006 Toyota Tundra,
2005 Toyota 4Runner
Last Online: 08-09-2008 12:56 AM
bbfirebird is on a distinguished road.
bbfirebird's Photo Albums
Tundra V8:
271 HP @ 5400 RPM
313 lb-ft @ 3400 RPM
Max. towing capacity: 7100 lbs.
Tacoma V6:
236 HP @ 5200 RPM
266 lb-ft @ 4000 RPM
Max. towing capacity: 6500 lbs.
Really, peak numbers don't mean a whole lot, especially when you consider that both of these engines have the VVTi system, which gives a fairly significant increase in peak power. If you're towing for a long period of time, chances are the VVTi system wouldn't be on that entire time. I haven't seen dyno graphs, but I'm sure the V8's torque curve is much broader than the V6's, and makes much, much more torque at low RPMs. Plus, the V8 Tundra has 3.92 gears and the DC V6 Taco has 3.73s, which is going to help your acceleration, especially while towing.
You made the right choice to go with the Tundra. Don't look back.
2006 Tundra SR5 4x2 V8 TRD access cab- Phantom Grey- debadged with a steering wheel cover and a stubbie antenna (woot woot!).
2005 4Runner SR5 4x4 V8 Sport Edition- White (the wife's).
SOLD- 2002 Tundra SR5 4x2 V8 TRD access cab- Imperial Jade- Bassani rear exit exhaust, debadged.
Old 11-09-2006, 10:58 PM
phanham's Avatar
Dealer : J. Pauley Toyota Scion
Last Online: 09-12-2009 07:58 PM
phanham is on a distinguished road.
phanham's Photo Albums
The Tundra really is not designed to tow much. I believe it's payload is near the top when it comes to hauling stuff in the bed, but not so much for towing. If towing capacity is important you may have wanted to consider not really the Tacoma (it isn't great either), but one of the other manufacturers (my $.02). Not that I don't love Toyota trucks, they just excel in other areas, and not as much in this category...
2006 Tundra DC SR5 TRD 4x4. Pretty much stock besides the Extang Trifecta Tonneau, Hellwig sway bar, shorter antenna, & Kel-Tec in the console.
Old 11-09-2006, 11:30 PM
Dealer : Funk's Toyota
2005 Toyota Tundra
Last Online: Today 12:22 AM
Diego is on a distinguished road.
Diego's Photo Albums
Don't worry, you made a great choice in the Tundra and don't look back. My theory is even though the power to weight ratio is very close between the Tundra and Tacoma, this would ONLY mean they would be very close in acceleration if you were to race one against the other. As far as towing goes, the Tundra is a larger, heavier truck WITH more torque at lower RPM that will IMO, handle your boat OR even something a little heavier MORE comfortably than a Tacoma would. Also the Tacoma only gets about 4 MPG better mileage than your Tundra AND I would bet that the difference would be even slightly less when actually pulling a load. Plus the Tundra STILL has a good larger, solid steel bed that you could mount a camper on if you want.
Old 11-10-2006, 12:45 AM
Dealer : Arlington Toyota Scion
- Other - 2003 Accord 6MT,
2004 Toyota RAV4 L 2WD,
2006 Toyota Tundra Limited DC 4WD
Last Online: 07-17-2009 10:54 AM
spleck is on a distinguished road.
spleck's Photo Albums
In this case, the OP is more concerned with towing 2000 lbs <i>better</i>, not with max towing capacity. 2000 lbs is not enough to discount the Tundra being a better ride in the first place vs the "other manufacturers". I think the Tundra is designed to tow just as much as it is specified to be capable of, and to do it well.
Old 11-10-2006, 01:04 AM
Dealer : Ken Shaw Lexus Toyota
2003 Toyota Tundra
Last Online: 10-23-2009 01:10 AM
pagemaster is on a distinguished road.
pagemaster's Photo Albums
Originally Posted by joewildlife View Post
Hey,
Jesus christ. What are you worrying about?
A 2000 lb boat behind a access cab Tundra that can pull up to 7100 lbs is fine.
You have nothing to worry about with either a Tundra or a Tacoma.
You will just have a lot more comfort in the Tundra.
2003 Salsa Red Pearl
Old 11-10-2006, 06:42 AM
kwhite1124's Avatar
Dealer : Butler Toyota Co.
2005 Toyota Tacoma
Last Online: 08-17-2009 05:34 AM
kwhite1124 is on a distinguished road.
kwhite1124's Photo Albums
I just traded a 05 Tacoma dbl 4x4 and it pulled my 18 Ranger bass boat with no trouble. I knew it was back there, but it handled the weight with ease. I haven't towed it with the Tundra yet, but a full size truck is going to handle the weight better and braking should be improved as well. The Tacome would pull and stop the boat, but in a panic braking situation, the boat would just pust the truck. The truck wasn't heavy enough.
Old 11-10-2006, 08:09 AM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Today 07:07 AM
Images: 23
tomhole's Photo Albums
Hmmm... How 'bout we take a closer look at that.
My Tundra has a max tow rating 6800 lbs. I pull a 5200 lbs trailer with 1000 lbs of stuff in the truck (500 lbs of water bags, 500 lbs of gear). Well within the limits, right? Well, I'm actually at my GVWR for the truck and the GCWR. If I load the same stuff and hook the same trailer up to a Nissan Titan, it will be overlaoded. Same for a Dodge MegaCab 2500HD with a diesel engine (yup, a 3/4 ton truck). The Titan is rated to tow 9,300 lbs and the MegaCab 12,500 lbs. That's a heckofa lot more tow rating than a lowly Tundra, yet they both would be overloaded with my rig that is within the limits of my Tundra. Know why? Max tow rating is a bunch of BS. Most trucks hit their GVWR due to hitch/pin weihgt and cargo long before they get to their max tow rating. But the max tow rating looks good in the brochures.
The Tundra towing specs are well balanced and realistic. Toyota could just up the GCWR (which they apparently did in 2006 to 12,800) and get a bigger max tow rating for their brochure. Not a lot of risk in doing that. Upping the GVWR requires some engineering and upping the axle ratings requires some actual hardware. But any way you look at it, it donesn't mean squat unless you have a well rounded package.
Tom
Old 11-10-2006, 08:51 AM
funfinder4's Avatar
Images: 4
Does anyone know of a link that shows the graph of the HP & Torque curve of the 4.7 V8 VVTi ?
Old 11-10-2006, 09:00 AM
Moderator
Images: 23
This is a stock 4.7 VVTi. The blue is stock, the red is with a Unichip.
Compare that to the non VVTi motor:
Important to note the rpm scale.
Tom
Old 11-10-2006, 09:55 AM
2005 Toyota Tundra
The first chart above looks right, but the second one is not a 4.7L. Unichips has a problem on that link.
Here's a stock 4.7L VVTI:
Here's the a modded (intake, exhaust, headers) 4.7L non-VVTI:
Old 11-10-2006, 10:51 AM
No, my name is Joe but thanks for the compliment. I'm NOT worried about towing the boat with the Tundra. I don't even know it is there, accelerating or stopping. It is awesome. Yes the boat is nowhere near the max but that just makes it all the much easier.
I was wondering about the Tacoma thinking that I maybe got more truck than I needed when I bought the Tundra. The fella with the Ranger boat answered my question on that, referring to the panic stop situation.
The Tundra has a better seating position and rides better and tows like a dream. The Tacoma would be a step in the wrong direction on all three counts. Since I got the V8 to put towing worries completely behind me, pun intended, I did the right thing getting the Tundra and not the Tacoma.
thanks for the input guys
Joe
Salsa Red Pearl
2010 Sienna XLE
Blizzard White
Old 11-10-2006, 12:04 PM
ITO's Avatar
ITO ITO is offline
Dealer : Charles Maund Toyota
2006 Toyota Tundra,
2006 Toyota Sienna
Last Online: 07-25-2009 01:00 PM
ITO is on a distinguished road.
ITO's Photo Albums
The minor MPG improvement the Taco offers is not really worth the sacrifice in comfort and performance, and they are not that much cheaper either.
You made a great choice to tow your boat.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/78957-tundra-vs-tacoma-and-towing/
Posted By For Type Date
2002 Ranger Exhuast Headers, 2002 Pontiac Vibe, 2002 S10 Minitruck - Softwareillusions This thread Refback 03-06-2009 03:39 AM
Sunline Coach Company Owner's Club - RV Travel Trailer Forums and Message Boards This thread Refback 07-12-2007 10:50 PM
2007 Toyota Tundra Complete bennicde Tundra 6037 05-11-2007 07:58 PM
05 Tacoma Towing - Revisited j4x4ar3 Towing 20 12-01-2006 05:54 PM
Jim Press/Jim Lentz - 2007 Toyota Tundra Press Conference nhparrot Toyota, Scion & Lexus News 0 02-10-2006 11:28 AM
Tundra, Tacoma, 4Runner - V6 Abilities Towing Capacity JohnJCronin Towing 8 02-25-2005 10:07 PM
Tacoma, 4Runner, Tundra '05 V6 differences j4x4ar3 Tacoma 2 02-25-2005 08:41 PM
