This is the Check Engine Light or Malfunction Indicator Lamp (MIL)
This is the Maintenance Required Light or the Engine Oil Replacement Reminder
Light.
OBD II regulations require that the vehicle’s on−board computer
illuminates the Malfunction Indicator Lamp (MIL) on the
instrument panel when the computer detects a malfunction in:
1) The emission control system/components
2) The powertrain control components (which affect vehicle
emissions)
3) The computer
In addition, the applicable Diagnostic Trouble Codes (DTCs)
prescribed by SAE J2012 are recorded in the ECM memory.
If the malfunction does not reoccur in 3 consecutive trips, the
MIL turns off automatically but the DTCs remain recorded in the
ECM memory.
The diagnosis system operates in ”normal mode” during normal
vehicle use. In normal mode, ”2−trip detection logic” is used to
ensure accurate detection of malfunctions. ”Check mode” is
also available to technicians as an option. In check mode,
”1−trip detection logic” is used for simulating malfunction symptoms
and increasing the system’s ability to detect malfunctions,
including intermittent malfunctions.
When a malfunction is first detected, the malfunction is temporarily
stored in the ECM memory (1st trip). If the ignition switch
is turned OFF and then ON again, and the same malfunction is
detected again, the MIL will illuminate.
A DTC can be cleared using a hand−held tester or by disconnecting the neg side of the battery. However if the problem that triggered the illumination of the MIL is detected at startup the light will be illuminated again.
Light
Refer to Section 1-6 of your owner's manual.
This light acts as a reminder when to
replace the engine oil.
This light will come on when the ignition
key is turned to “ON” and will go off after
about a few seconds.
When you drive for about 7200 km (4500
miles) after the engine oil replacement,
this light illuminates for about 3 seconds
and then flashes for about 12 seconds
with the ignition key turned to the “ON”
position. If you continue driving without
replacing the engine oil, and if the distance
driven exceeds 8000 km (5000
miles), the light will come on after the
ignition key is turned to “ON” position.
The light will remain on thereafter.
If the light is flashing, we recommend that
you replace the engine oil at an early
opportunity depending on the driving and
road conditions. If the light comes on,
replace it as soon as possible.
The system must be reset after the engine
oil replacement. Reset the system by
the following procedure:
1. Turn the ignition key to the “ACC” or
“LOCK” position with the odometer
reading shown. (For details, see
“Odometer and two trip meters” in this
Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset knob.
Hold down the knob for at least 5 seconds.
The odometer indicates “000000”
and the light goes off.
If the system fails to reset, the light will
continue flashing.
