best upgrades for 2wd for better snow/mud traction
+ Reply to Thread
Results 1 to 12 of 12
Thread: best upgrades for 2wd for better snow/mud traction
  1. #1
    Join Date
    Aug 2006
    Location
    nowata
    Posts
    27
    Liked
    0 times
    Rep Power
    10
    Default best upgrades for 2wd for better snow/mud traction
    Obviously tires but I wondered if I could buy some of those snoclaws or something other than chains w/o spending hundereds on tires I could only use a couple times a year here in Oklahoma. I wish I had a 4wd but love my Tundra otherwise. Also, can a limited slip diff be installed in these trucks? That would help a huge amount I think.
    thanks for any ideas.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    Default Re: best upgrades for 2wd for better snow/mud traction
    You can get snow tires with studs, which help significantly on icy intersections, streets, etc. You should be able to get posi as it is available on the same truck as yours. I use 400 lbs of sand just in front of the tailgate to load down the rear tires. Because of the poor weight distribution on a pickup, this helps quite a bit.
  4. #3
    The Friendly Dragon by the Sea Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    51
    Posts
    2,876
    Liked
    183 times
    Images
    45
    Rep Power
    16219
    I would get a lsd/locker rear end and place lots of unshiftable weight in the bed over the rear axle. Otherwise make sure you've got tire chains, shovels and a bag of salt to aid you if you should become stuck. The last time I lived in snow country everything I owned was 4wd.
  5. #4
    Join Date
    Dec 2006
    Location
    Suburbia
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Get a mechanical locking rear locker. It will cure what ails you.
  6. #5
    Join Date
    Dec 2005
    Location
    Arkansas City, KS
    Posts
    42
    Liked
    0 times
    Rep Power
    10
    You are having the same problem as me. I have been living in Stillwater, but now moved streight north about a mile and a half into Kansas. I have used air lockers on other trucks, but have been looking at elockers mainly but have also wondered about powertrax units because of how easy they install.
    What are you thinking about getting? What does everyone think about the powertrax units? Is it worth the extra money and work for the elocker or arb unit?
  7. #6
    Junior Member CT-Tundra's Avatar
    Join Date
    Oct 2005
    Location
    CT
    Posts
    225
    Liked
    0 times
    Rep Power
    10
    LSD will help, but you need to load up your bed with a few hundred pounds to get some traction. Very common to see 2wd trucks with sand bags in the back during winter.
    2005 Tundra Access Cab 4x4 4.7L - BFG ATs on MT Classic Locks - Warn M8000
  8. #7
    Join Date
    Dec 2005
    Location
    Arkansas City, KS
    Posts
    42
    Liked
    0 times
    Rep Power
    10
    Have you been around one of the powertrax units before?
  9. #8
    Veteran Member Hugemoose's Avatar
    Join Date
    Dec 2005
    Location
    Mohnton, PA
    Age
    28
    Posts
    1,863
    Liked
    3 times
    Rep Power
    3434
    I have a Powertrax unit and I personlly love it. BUT, it is not worth it if you drive mostly road. It is street friendly but it still locks every time you hit the gas. So every time your on the gas around a corner that inside tire is spinning just as fast and sometimes can chirp causing added wear. And it does cause some understeer which is quite noticable around a corner when it's wet. So be careful!!!
    There is some added wear on the rear tires so I have to rotate often. But when off-road.....it is unbeatable. If you drive mostly road than yes the air-locker is a better bet altough it does cost a lot more.
    NOTE: there are some pics in my galley of the No-slip install.
    David~2001 Toyota Tundra 4X4 TRD SR5~SSautochrome headers~Single 2.5" exhaust w/ Flowmaster 50 series delta flow muffler~K&N FIPK intake system w/True-flow filter~ASP underdrive pulley~Custom tuned Unichip (thank you Johan)~Powertrax No-slip~Bilstein 5100 front and rear w/ Deaver 10 pack~Diff breather mod~255/85 BFG M/T on Wheelers Black Steelies Type B~Custom Rocksliders~Skid Row front skid plate~Custom Transfer case skid plate
  10. #9
    Join Date
    Jul 2002
    Location
    Sagnasty
    Posts
    204
    Liked
    0 times
    Rep Power
    14
    Exclamation Re: best upgrades for 2wd for better snow/mud traction
    I'm in Michigan and my 2WD Tundra does well. I have the factory LSD and as long as your pointing straight when you hit the gas, You will go...A little weight will help as long as its secure. Loose weight will really screw up your truck!
    Motoretro
  11. #10
    Supercharged Member v8Toilet's Avatar
    Join Date
    Apr 2002
    Location
    Worcester, MA
    Posts
    2,145
    Liked
    2 times
    Rep Power
    16
    I have a 2WD Tundra and live in the snow belt so I know what works best. Get an LSD and when it snows add 3-4 cement 8"*16" blocks over the rear axle and you'll get through most any area a good front wheel drive car can.
    stock exhaust
    TRD LSD
    Extang lift off tonneau
    Hankook DynaPro AS RH03
    stock air filter & box
    220 HP @ 4800 RPM
    302 TQ @ 3400 RPM
    Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
    208 HP @ 4800 RPM
    285 TQ @ 3400 RPM
    Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
    204 HP @ 4800 RPM
    271 TQ @ 3400 RPM
    Bone stock
    Dyno run results click here
  12. #11
    Join Date
    Dec 2005
    Location
    Arkansas City, KS
    Posts
    42
    Liked
    0 times
    Rep Power
    10
    SOrry it took me so long to get back on here, I have been out of town without internet. I woul still really like to do the arb, but will probably buy a powertrax just because of price.
  13. #12
    Join Date
    Aug 2006
    Location
    nowata
    Posts
    27
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Default Now need a good recommendation on snow/mud/AT tires
    Quote Originally Posted by kirker912 View Post
    My toyota dealer will install a TRD LSD for about $500. Now I am just shopping for a good set of snow/AT tires. I don't mind having a set just for winter but if they drive nice and are not too $$ I will just leave them on because we do some light off road driving too.
    I was thinking of the Goodyear MT/R because of a post here that said they are good for regular highway and last a long time. But the dealer is recommending a set of HerculesTeratrac AT for $107 each, and he can sell me a full set of steel wheels to go with them for about $175.
    So, any recommendations on the tires? I don't mind if they are aggressive as long as they don't give up too much in the way of mileage and noise.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Tundra Offroad Mods and Tech
    By DevinSixtySeven in forum Off-Roading
    Last Post: 05-24-2004, 07:22 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
