Old 12-08-2006, 11:52 PM
Dealer : Capitol Toyota Scion
Last Online: 09-25-2007 10:10 PM
valiantjedi is on a distinguished road.
valiantjedi's Photo Albums
Default Timing belt change
Hi Everyone,
I'm changing the timing belt on my tundra, which may be for the first time it's ever been done. I'm the second owner on the truck and it's at about 145k miles. After following the Chilton's guide for the tundra I think the guide may be wrong. What happens after following their instructions is the truck turns over but won't start.
I have both left and right gears aligned with the "I" mark on the engine housing. I used the "T" mark on them to loosen the belt, along with loosening the tensioner. The crankshaft gear notch is aligned with the dot on the engine housing.
Now the left gear was off by half a notch, but I could not see how to get it any tighter. Would half a notch stop the engine from starting? By notch I mean the grooves in the gear for the timing belt to attatch. Thanks for any help.
Old 12-08-2006, 11:54 PM
Default Re: Timing belt change
Also it's a 2000 v8 4wd tundra, 4.7 liter.
Old 12-09-2006, 01:36 AM
Ando140's Avatar
Dealer : Beechmont Toyota
2002 Toyota Tundra SR5 V8 AC TRD LSD
Last Online: 10-31-2009 10:23 PM
Ando140 is on a distinguished road.
Ando140's Photo Albums
here's what the 2002 factory manual says for re-installing the timing belt on the V8:
3. Temporarily Install Timing Belt
Notice: The engine should be cold
(a) Remove any oil or water on the crankshaft pulley, oil pump pulley, water pump pulley, No. 1 idler pulley and No. 2 idler pulley, and keep them clean.
Notice: Only wipe the pulleys; do not use any cleansing agent.
(b) Align the installation mark on the timing belt with the timing mark of the crankshaft timing pulley.
(c) Install the timing belt on the crankshaft timing pulley, No. 1 idler pulley and No. 2 idler pulley.
4. Install Timing Belt
(a) Install the gasket to the cover spacer.
(b) Install the cover spacer.
5. Install timing belt guide
Install the belt guide, facing the cup side outward
6. Install No. 1 Timing Belt Cover
Install the timing belt cover with the 4 bolts.
7. Install Crankshaft Pulley
(a) Align the pulley set key with the key groove of the crankshaft pulley
(b) Using SST and a hammer, tap in the crankshaft pulley.
SST 09223-46011
8. Install Drive Belt Tensioner
Install the belt tensioner with the bolt and 2 nuts
Torque: 16 N*m (160 kgf*cm, 12 ft*lbf)
Hint: Use a bolt 106 mm (4.18 in.) in length
9. Install Generator
10. Check Crankshaft Pulley Position
Check that the timing mark of the crankshaft pulley is aligned with the timing mark "0" of the No. 1 timing belt cover
11. Install RH, LH Camshaft Timing Pulleys
(a) Align the camshaft knock pin with the knock pin groove of the timing pulley, and slide on the timing pulley.
(b)Using SST, install the pulley bolt.
SST 09960-10010 (09962-01000, 09963-01000)
Torque: 108 N*m(1,100 kgf*cm, 80 ft*lbf)
12. Connect timing belt to LH Camshaft Timing Pulley
(a) Remove any oil or water on the LH camshaft timing pulley and keep it clean.
(b) Turn the LH camshaft timing pulley. Align the installation mark on the timing belt with the timing mark of the camshaft timing pulley, and hang the timing belt on the LH camshaft timing pulley.
(c) Turn the LH camshaft timing pulley counterclockwise until there is tension between the crankshaft timing pulley and the LH camshaft timing pulley.
13. Connect the timing belt to RH Camshaft Timing Pulley
(a) Remove any oil or water on the RH camshaft timing pulley and water pump pulley, and keep them clean.
(b) Turn the RH camshaft timing pulley. Align the installation mark on the timing belt with the timing mark of the camshaft timing pulley, and hang the timing belt on the RH camshaft timing pulley.
14. Set Timing Belt Tensioner
(a) Using a press, slowly press in the push rod using 981-9807 N (100-1,000 kgf, 220-2,205 lbf) of pressure.
(b) Align the holes of the push rod and housing, pass a 1.27 mm hexagon wrench through the holes to keep the setting position of th epush rod.
(c) Release the press
(d) Install the dust boot to the belt tensioner
15. Install Timing Belt Tensioner
(a) Temporarily install the belt tensioner with the 2 bolts.
(b) Alternately tighten the 2 bolts
Torque: 26 N*m (270 kgf*cm, 19 ft-lbf)
(c) Using pliers, remove the 1.27 mm hexagon wrench from the belt tensioner
16. Check Valve Timing
(a) Temporarily install the crankshaft pulley bolt.
(b) Slowly turn the crankshaft pulley 2 revolutions from TDC to TDC.
Notice: Always turn the crankshaft pulley clockwise
(c) Check that each pulley aligns with the timing marks as shown in the illustration (picture shows L-CAM and R-CAM marks lining up exactly with marks)
If the timing marks do not align, remove the timing belt and reinstall it.
17. Tighten Crankshaft Pulley Bolt
Using SST 09213-54015 (90119-08216), 09330-0021
Torque: 245 N*m (2,500 kgf*cm, 181 ft*lbf)
Hope that helps, good luck and let us know what happens... also, if you think I might have made a mistake or typo, let me know and I'll re-check it. I've never done a timing belt, so the best I can do is tell you what my book says.
Good Luck!
Old 12-09-2006, 05:37 AM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
Last Online: 11-08-2009 07:50 AM
cookiemech is on a distinguished road.
cookiemech's Photo Albums
You didn't neglect to plug in the camshaft sensor on the left (driver's side) cylinder bank, did you? (You have to unplug it to do the job.)
Half a tooth off won't stop the engine from starting or running, though when I hear "half a tooth off" I am suspicious, since unless there's something strange going on, you should not be able to be off in half-tooth increments. I assume that after installing the belt and tensioner, you turned the engine over (clockwise direction) two full revolutions and checked again. Also, as I recall, there are a couple of different marks on the crankshaft, so if you moved the crankshaft during belt installation, you could create a problem. The manual should be explicit as to which mark to use.
Please post again with your observations. Good luck with it.
Old 12-09-2006, 03:55 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
You need to verify that you have spark, fuel, and compression in order to narrow it down to the cause of the no start. Put a vacuum gauge on and do a cranking vacuum test. You should have about 2-3 in of vacuum. If you don't have this than you will need to do a compression test to verify that you have compression. Without engine compression the engine won't start; if you don't have either of these things than you probably made a mistake with the timing belt change. Pull off one of the ignition modules/ coils and put a spark plug in it that is grounded so you can see that you have spark when you crank the engine. If you don't have spark than you probably forgot to plug in a sensor like the crankshaft or camshaft sensor. You’ll have to refer to a manual to test those. Last verify that you have fuel pressure by putting a gauge on the shradder valve. Verify that you are getting fuel by putting a timing light on the ground side of the fuel injector. If the engine computer is grounding the injector coil than the timing light will flash when the engine is cranked and if you have fuel pressure than your engine is getting fuel. You can also use a HIGH IMPEDIENCE multi meter but only a high impedience multi meter or you will fry the computer.
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
Old 12-26-2006, 07:27 AM
Dealer : Jon Lancaster Toyota Scion
Last Online: 12-26-2006 07:34 AM
Bigdano2z is on a distinguished road.
Bigdano2z's Photo Albums
Looking for part numbers for Idler arm pully and tentioner pully, they are skweeking and want to replace.
Old 12-26-2006, 09:53 PM
Tennesseestorm's Avatar
Dealer : Phil Bachman Toyota
2000 Toyota Tundra SR5 4wd V8,
- Other - 1972 Caprice Estate
Last Online: 08-04-2009 08:26 PM
Tennesseestorm is on a distinguished road.
Tennesseestorm's Photo Albums
145K on the original belt.... interesting. I am wondering- what was the conditions of the belt?
My dads 1988 Nissan V6 truck had 205K on the original belt. It was getting pretty thin.
Old 12-26-2006, 11:45 PM
bucstundra's Avatar
Dealer : David Maus Toyota Scion
2005 Toyota Tundra,
Last Online: 11-20-2008 10:32 PM
bucstundra is on a distinguished road.
bucstundra's Photo Albums
Check the crankshaft timing gear. There should be a small thin gear on either the inside or outside of the gear. This thin gear tells the crank sensor where the crank is in rotation. Check to make sure that none of the teeth on this smaller gear are not chipped or missing. My dad and I run a high line european auto repair shop, but we also service Lexus. We ran into a very similar problem on a Lexus V8. After doing the timing belt, we tried to start it up. The darn thing wouldn't fire. After some asking around, we found that stupid gear was missing a tooth. Never came across that problem before, but there is a first for everything. You've got to be careful with the gear. It is pretty fragile. If you have a chipped or missing tooth, you have to replace the crank timing gear. I hope this helps. Good luck.
Old 05-22-2007, 03:47 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 06:27 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Gates Part Locator & Interchange if ya want OEM just call Toyota Parts with VIN#! this site also has an OEM Cross Refference capability!
Old 02-28-2009, 10:34 AM
Dealer : Cobb County Toyota Scion
Last Online: 10-24-2009 12:56 PM
Images: 3
caribman is on a distinguished road.
caribman's Photo Albums
Thumbs up Re: Timing belt change
Thank You! for the link..
2000 Toyota Tundra SR5 Access Cab. 2WD. 4.7L V8. Signature Series Rotors. Hawk LTS Brake Pads. Magnaflow 22" Dual Exhaust, Silverline Tips.
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
Did the Timing Belt Today @ 92,200 Mi. jqqd 1Gen-Tundra 23 01-14-2007 10:49 PM
Valve clearance and timing belt hilus Engine & Drivetrain 10 10-07-2006 07:46 AM
Timing belt change time, and what else? hsvhobbit Engine & Drivetrain 1 08-24-2005 02:56 PM
need advice on engine timing belt and h20 water pump (at once) Tundrav8yamaha Engine & Drivetrain 4 06-29-2004 10:32 PM
