Old 12-12-2006, 01:19 PM
Dealer : Appleway Toyota
2003 Toyota Tundra
Last Online: 05-30-2007 02:07 PM
Brijoe00 may have some regrets.
Brijoe00's Photo Albums
Default 2003 tundra towing question
Hi all, I am new here and thought maybe I could get some opinions.
I am looking at buying a 2003 Tundra access cab 4.7l v-8. I have a 23' travel trailer which weighs about 5000 lbs. I am curiouse if anyone out there can tell me from experiance how the Tundra does towing this much weight. Does it have the power for pulling hills etc.? Any input would be appreciated.
Thanks
Brian
Old 12-12-2006, 02:08 PM
jasbus's Avatar
Dealer : Toyota Scion of Winter Haven
2003 Toyota Tundra
Last Online: 01-11-2010 02:24 PM
jasbus may have some regrets.
jasbus's Photo Albums
Default Re: 2003 tundra towing question
I pull a trailer, and our pop up with my 03. No problems at all.
My folks have a 25' travel trailer and a 06 tundra. Pulls it way better than the 350 chevy truck they traded in for the tundra...
Blacked out 2003 Limited 4X4 Access Cab with TRD Off-Road Package Debadged
2.5" Fabtech suspension lift
3" body lift
Old 12-12-2006, 05:35 PM
Dealer : Tegeler Toyota
2008 Toyota Tundra T Grade 4x4,5.7,CMax
Last Online: 03-11-2010 08:16 PM
billyii may have some regrets.
billyii's Photo Albums
Thanks
Brian
Brian,
Since Oct 2001, I have been pulling a 30' Airstream (6,280 lb dry weight) with my 2002 4WD Access Cab Tundra. Including a 4,500 watt generator in the Tundra's bed, water, propane, personal items and full holding tanks at times, I would estimate the total weight to be well in excess of 7,500 lbs. I have had no problems towing or with the Tundra for almost 100,000 miles, about 1/3 towing the trailer. It will easily pull the trailer over any Rocky Mountain pass on a Canadian or U.S. highway.
Your Tundra should have no problems towing your trailer as far as I know. A couple of things we may have different is that the Airstream has very little wind resistance and my 4WD helps in handling the tongue weight and the generator in the bed of the truck.
Be sure to install electric brakes and a controller, a stabilizer and weight equalizer hitch with bars and a Class IV hitch on your Tundra. I think all or most Tundras are only equipped with a class III hitch which would not be safe with a heavy trailer.
Prior to my Tundra, I pulled the trailer with a T-100. It had problems with some mountain passes but made it over all of them.
Hope this helps.
Billyii
Old 12-12-2006, 07:12 PM
I am looking at buying a 2003 Tundra access cab 4.7l v-8. I have a 23' travel trailer which weighs about 5000 lbs. ..........
Thanks
Brian
There is a "Towing" forum that should be of help. Just go to the bottom right side of this page at the "forum jump" and select towing under Techinical and Vehicle Assistance.
Old 12-13-2006, 02:23 AM
04DSGTUNDRA's Avatar
Dealer : Toyota of Glendora
2006 Toyota Tundra AC Limited 4WD
Last Online: 10-22-2009 01:29 AM
04DSGTUNDRA may have some regrets.
04DSGTUNDRA's Photo Albums
my 2004 tundra tows our 24' toyhauler pretty good, I know loaded up its well in the 8-9k range... Power wise it does pretty good. I agree you should def. use the weight distributing hitch, load levelers, sway control, brake controller, etc. For your trailer the tundra should pull it without a problem. good luck !
only bad part is MPG. I get between 6-7 MPG depending on speed, weight, and tires I have.
2006 Black Limited 4WD TRD Tundra
Present.
2004 Phantom Gray Limited TRD Tundra
RIP.
Question zerofear66 1Gen-Tundra 3 11-26-2006 09:26 AM
Tundra Vs. Tacoma towing joewildlife Tacoma 11 11-13-2006 02:35 PM
Jim Press/Jim Lentz - 2007 Toyota Tundra Press Conference nhparrot Toyota, Scion & Lexus News 0 02-10-2006 10:28 AM
question to 03 tundra owner's up (grill latch) Tundrav8yamaha Interior & Exterior 2 10-03-2004 04:22 PM
Towing Weight And Overdrive Question ?? ZIGGY454 Engine & Drivetrain 17 01-28-2004 07:35 AM
