Has not changing the timing belt in time ever caused a tundra motor to fail? - Page 2
+ Reply to Thread
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 64
Like Tree13Likes
Thread: Has not changing the timing belt in time ever caused a tundra motor to fail?
  1. #16
    Join Date
    Feb 2006
    Location
    Chrisney, IN
    Posts
    55
    Liked
    0 times
    Thanks
    0
    Rep Power
    10
    Default Re: Has not changing the timing belt in time ever caused a tundra motor to fail?
    Thanks for the info Shaffer.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Join Date
    Dec 2006
    Location
    columbus,oh
    Posts
    9
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by Shaffer View Post
    Not from what I have heard. I have heard that all of the V6 Toyotas are non-interference. At least the older 3.0L and 3.4L V6s were.
    I have a 1996 T-100 with the 3.4 V6, it has 61,000 miles. when saying it is a non indifference motor what does that mean?
  4. #18
    Join Date
    Nov 2006
    Location
    Ogdensburg,NY
    Posts
    29
    Liked
    0 times
    Thanks
    0
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by matt19540 View Post
    1994 3.0 V6 is not! That came from a Toyota certified mechanic to me! Not second hand! There seems to be alot of Toyota hype over this simple Pre-maintanence repair.
  5. #19
    Veteran Member Tennesseestorm's Avatar
    Join Date
    Feb 2002
    Location
    Northeast Tennessee
    Age
    39
    Posts
    909
    Liked
    4 times
    Thanks
    0
    Rep Power
    14
    Its non-interference. Meaning, if the timing belt breaks, the engine will not be damaged. On an interference engine, it damages the engine severely. The 96' T100 I was considering- the timing belt broke.... they replaced with a new one and all was fine.
  6. #20
    Join Date
    Mar 2010
    Location
    Tryon N.C.
    Posts
    1
    Liked
    1 times
    Thanks
    0
    Rep Power
    0
    GOD!!!No one has answered this mans question!! I am just a curious! I have not heard the first story of anyone saying.."Yep! My motor blew all to hell cause I didn't change the timing belt! I think it's...like a lot of religions..a rumor to generate money! I sold one Toyota truck with 260 K on it and another with 210K on it .Both had origional belts in them! I'm on my 3rd Tundra right now with 120K on it and I'm sleeping great at night. They are like Honda motors...Just keep the fluids changed ..let em breath clean air and they run for ever!.....but pleses.If anyone ..including mechanics..has seen a blown motor because of a busted timing belt...Post IT! Thanks Dale
    arptun likes this.
  7. #21
    Join Date
    Apr 2009
    Location
    Edgewood,KY
    Posts
    38
    Liked
    1 times
    Thanks
    0
    Rep Power
    6
    I've had 2 timing belts "break". Actually the first one just slipped due to age on a 89' Lemans. Just stopped dead in its tracks at idle coming out of the driveway. Replaced belt and all was well. Second one broke, 55 miles an hour rush hour traffic in a 87' civic, had traffic backed up for miles and felt like an ***, but even worse the engine was gone. Mechanic opened it up and it looked like a grenade went off, not good. Both went between 110,000 and 120,000 miles. Like said before get them changed its not a myth.
  8. #22
    Rookie t -150's Avatar
    Join Date
    Nov 2008
    Location
    Sperry okla.
    Posts
    16
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    I have a buddy who is a certified TOYOTA Mechanic 5yr. he told me the 3.0 & 3.4 v6 are non interference meaning if the belt breaks your stuck on the side of the road. The V8s are interference motors if the belt brakes get your wallet out $$$$$ top end valve train & pistons will be trash. Do you want to take that chance. Not me. Change the belt when toyota recomends do the water pump belt tensioner while your in there. Good luck.
  9. #23
    Join Date
    Mar 2010
    Location
    Poughkeepsie, NY
    Posts
    299
    Liked
    40 times
    Thanks
    0
    Rep Power
    3768
    Hello. This is my first post. I just bought a 01 V6 Tundra and the belt was not been replaced yet. It has 170 K miles, but I'm going to replace the T belt very soon. Is it true, that the 3.4 V6 is not an interference engine?
  10. #24
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,330
    Liked
    3124 times
    Thanks
    0
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by silet View Post
    As was stated earlier, the Toyota V6 uses a chain and is NOT an "interference" design.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  11. #25
    Goodbye '01 Tundra :( Intrepidyota's Avatar
    Join Date
    Apr 2005
    Location
    Fitchburg, MA
    Age
    33
    Posts
    167
    Liked
    0 times
    Thanks
    0
    Rep Power
    15
    I did my own timing belt with a friend at 95k miles or so and the timing belt was still in good condition. No real cracking or wear. I won't venture a guess how long it could last, but definitely more than the 95k I ran it.
    *edit-just realized this is a really old thread I responded to, haha.
    Even crime wouldn't pay if the government ran it...
    '04 Tundra DC 4WD---Alpine 9857/ Infinite Basslink/ Kumho AT's...its a DD/tow rig...what can I say.
    '85 used-to-be-4runner---chopped, tubed, abused
    NORTHEAST TOYOTA CRAWLERS
  12. #26
    90
    90 is offline
    Join Date
    Mar 2010
    Location
    Vanc BC
    Posts
    4
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    just wanted to clarify, somebody mentioned that "all Toy V6's are timing-chain motors", this is not technically correct, as 3vze motors like in 2nd gen 4runners are belt-driven.
    I know this is a Tundra forum but somebody uninformed may misinterpret what's being said.
  13. #27
    Veteran Member Geordybass's Avatar
    Join Date
    Oct 2009
    Location
    Sun Valley
    Posts
    544
    Liked
    18 times
    Thanks
    0
    Images
    3
    Rep Power
    237
    Damn i thought my 06' 4.7L V8 Tundra had a timing belt? I have 52k on it now so I'm not stressing it yet.
  14. #28
    Senior Contributor Barney_Fife's Avatar
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Thanks
    0
    Images
    216
    Rep Power
    7361
    Quote Originally Posted by Geordybass View Post
    it does. the new 5.7 doesnt but the 4.7 does. i think this thread is funny.....how many times does one have to ask if a certain motor is an interference motor or not hahaha
    and yes, they can and will destry a motor on an interference motor when they do break. some break right on time some go twice as far etc. but i'll be replacing mine when i shoudl so as not to worry about it.
    2007 Super White DC SR5 , TRD OffRoad; Sand Beige leather, 4.7, tinted windows, OEM running boards, tow mirrors with chrome covers, Armorlid tonneau, billet grille, aftermarket reverse sensors, flowmaster true duals with 3.5 rolled edge stainless tips, Sirius added via OEM module, 5000K HID lowbeams, KMC XD Hoss 20'' wheels in gloss black, Nitto Terra Grappler AT 285/55/20's, chrome door handle covers, smoothed and painted tailgate handle, 3 inch lift/levelling kit,1.5'' Rough Country lift blocks in rear, DVD headrest player/monitors, Rostra backup camera, SS bull bar with 6'' lights, Faux Carbon Fiber dash,console and door trim. Work stuff: red/blue LEDs in grille, headlight wig wag flasher, red/blue LED windshield light, red/blue LED deck lights in back glass, red/blue split 4 LED lights either side of license plate, wig wag backup and brake lamps. 100 watt siren and PA.
    Quote Originally Posted by steppy View Post
    what barney said sounds reasonable
    Quote Originally Posted by JMSinMD View Post
  15. #29
    Join Date
    Sep 2006
    Location
    Jersey
    Posts
    524
    Liked
    1 times
    Thanks
    0
    Rep Power
    24
    Fact of the matter is if you dont change it at the specific intervals it could be fine, might never break.
    HOWEVER:
    Rubber wears out, thats what the belts are made of. Eventually the rubber will begin to crack then begin to fall apart. If the engine is interference it could possibly bend the valves and then your in for more than 500-900 bucks worth of repair-more like 2-5k depending on what went wrong and even then they may not be able to fix it right and you need a new block.
    Ive seen plenty of cars, toyota and others with timing belts that literally were disintegrating. You really want to take the chance and save the cash fine by me. If it fails and causes damage im gonna laugh at you till I fall over from lack of oxygen.
    And yes the 3.0 and 3.4L V6 uses a belt and is non interference. 4cyl engines use a chain most of the time-not sure about interference.
  16. #30
    Rookie Thax's Avatar
    Join Date
    Nov 2008
    Location
    The Valley
    Posts
    9
    Liked
    2 times
    Thanks
    0
    Rep Power
    0
    I think we all agree what would happen to your motor if the T-belt breaks, but has anyone ever heard of it happening like the OP asked? The Service Manager at my local Toyota dealer said they change them all the time but he has never heard of one breaking.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Which BRAND of OIL?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 10-29-2007, 10:43 AM
  2. Replaced Timing Belt Last Week
    By devo in forum 1Gen-Tundra
    Last Post: 12-26-2006, 11:42 PM
  3. need advice on engine timing belt and h20 water pump (at once)
    By Tundrav8yamaha in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-29-2004, 07:32 PM
  4. When to replace timing belt on 4.7?
    Last Post: 03-28-2002, 01:48 PM
  5. Question about stock Tundra Foglights..Help!
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:13 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
