This is a discussion thread titled "fuel filter replacement?", within the 1Gen-Tundra forum, part of the Truck Forums category.
Old 12-31-2006, 09:05 AM
willy's Avatar
Dealer : Mic Mac Motors
- Other - '41 Chevy 1/2 ton,
2007 Toyota Tundra DC 4WD LB
willy's Photo Albums
Last Online: 11-11-2008 12:22 AM
willy will become famous soon enough.
Default fuel filter replacement?
It's too cold (9 F) and still dark to go outside and look, so I thought I'd ask. Does the fuel filter require special tools to change on a '00 V8 Tundra?
Old 12-31-2006, 09:31 AM
yspert's Avatar
Dealer : Rice Toyota
2006 Toyota Tundra,
2006 Toyota Camry LE
yspert's Photo Albums
Last Online: 05-30-2008 04:43 PM
yspert is on a distinguished road.
Default Re: fuel filter replacement?
unless you are having a "low power on accel" problem or know
something bad has been put in the tank, then replacing the
fuel filter is a waste of time and money. yspert
Graduated from Y to Z status.
Old 12-31-2006, 09:41 AM
willy's Avatar
I've had two vehicles that I neglected to get the fuel filters changed at their suggested intervals. Both filters ended up plugging and both times it caused the fuel pump to burn out, which is not uncommon when a filter plugs. So, on top of that filter cost, then I had to add on the cost of a pump, plus a towing. When it happened to my F-250 work truck this past summer with only 40,000 miles on the truck, I was in the middle of nowhere and need a 100+ mile tow. Including towing charges, a new filter, a new pump, and labor, it cost over $1000, all because the filter plugged.
So, does anyone know if I need special tools to change the filter on my '00 Tundra?
Old 12-31-2006, 10:26 AM
yspert's Avatar
2006 Toyota Tundra,
you will need flare wrenches. yspert
Old 12-31-2006, 12:21 PM
enlightened's Avatar
Dealer : Dunning Toyota Ann Arbor
2001 Toyota Tundra,
2006 Toyota Tacoma
enlightened's Photo Albums
Last Online: Yesterday 06:53 PM
enlightened is on a distinguished road.
I had the same thing possibly happen to the '01 Tundra three weeks ago. 144,000 miles on truck, fuel filter only replaced once at 62,000 miles, so I neglected it for 82,000 miles, and turn over the engine,,,no start....fuel pump failure (knew it right off) .... towing (4x4 dolly), parts (fuel pump and filter) & labor...total cost $855.00.
Rather ironic as I am known for doing ALL other maintenance items on the severe service schedule to a tee, but completely forgot about the fuel filter!!!
2001 Toyota Tundra 4x4 SR5 reg. cab, V-8 auto. imperial jade green with matching Astro-cap w/overhead racks
Hellwig rear ASB, Wheeler's poly ASB bushings, H&R 2" leveling progressive coils, Bilstein HD yellow/blue shocks, Husky liners, drop-in Toyota bed liner, TRD Dual Side exhaust, StubbsWelding rocksliders, red 48" Hi-Lift Jack, U-Haul hitch, receiver shackle, SkidRow front/trans/t-case skidplates, POR 15 and ChassisCoat Black frame restoration, 265/75QR16 Bridgestone Winter Dueler DM-Z2 on M/T Classic II wheels
2006 Toyota Tacoma reg. cab, 4 cyl. auto. silver streak mica with matching LED Astro-cap, Toyota rubber bed mat, Catch-all floor mats, SuperSprings
both trucks equipped with LED amber mini light bars for safety
Old 12-31-2006, 12:22 PM
Tones's Avatar
Dealer : Gullo Toyota Scion of Conroe
- Other - 2001 Tundra V8 AC
Tones's Photo Albums
Last Online: Yesterday 07:10 PM
Tones is on a distinguished road.
Willy, thanks for chiming in. I agree. I have also gotten stranded from a clogged fuel filter (on a vehicle that was not my own). I cannot see doing preventive maintenance and avoiding inconveniences a waste of time or money. I haven't done mine yet either, but plan to soon at around 50k on my truck.
I believe the fittings are like tubing fittings, so you will need wrenches and a bucket.
Old 12-31-2006, 12:25 PM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
shall36's Photo Albums
Last Online: Today 12:06 PM
shall36 is on a distinguished road.
Yah, it's kind of a PITA, but cheap insurance. Cut a used one open some time and see what kind of trash comes out. I once had a customer who bought gas at the same place all the time and he had a perpetual fuel filter clogging problem! That's rare, but it does happen.
Flare wrenches help but are not absolutely necessary. You will need a 17mm end wrench and a 15mm wrench, I believe....been a while since I did mine.
Hey, $15 every 15k miles....it's cheap maintenance.
Old 12-31-2006, 12:27 PM
TexasTornado's Avatar
Dealer : Uebelhor & Sons Toyota
TexasTornado's Photo Albums
Last Online: 12-01-2008 11:57 PM
TexasTornado is on a distinguished road.
Does anyone know if the 05-06 has one or is it in the tank.
Old 12-31-2006, 12:52 PM
Dealer : Heffner Lexus Toyota
xtc500's Photo Albums
Last Online: 06-12-2008 08:33 PM
xtc500 is on a distinguished road.
Hello all. New member here. Just took posession of a 06 Tundra double cab 4X4. Looking forward to putting some miles on it.
Not intending to disscourage anyone from doing reg maintenance, but I have to agree with yspert. The warning signs of a partially plugged fuel filter are easy to notice. Loss of power at acceleration or at highway speeds are very noticable when the filter plugs to the point it will not pass enough fuel to maintain the engine rev. you are requesting. This should be noticed before the fuel pump is starved long enough to cause damage. I have used this method for many years to determine when to change the filter. During my farming days when we took fuel from an older farm storage tank, the changes were yearly.
But in light of what the other members hear are saying about fuel pump failures, I think I will start including a fuel filter change as per the recomended schedule.
Old 12-31-2006, 12:59 PM
yspert's Avatar
2006 Toyota Tundra,
any thoughts on why toyota stopped recommending fuel
filter replacement fifteen years ago? yspert
Old 12-31-2006, 01:16 PM
rc846's Avatar
Dealer : Kearny Mesa Toyota Scion
2002 Toyota Tundra
rc846's Photo Albums
Last Online: 11-23-2008 02:35 PM
rc846 is on a distinguished road.
??? This should be noticed before the fuel pump is starved long enough to cause damage ???
The fuel pump is in the gas tank and pushes fuel through the filter then to the engine. So when the filter gets clogged up the pump has to push harder thus the pump burning up.
My 1985 Toyota Celica fuel pump burned up on my trip to Los Vegas and left me stranded it must be the long drive. I got all the way there parked it then it would not start.
The local mechanic in Los Vegas put a new pump in and it started. I drove for about six months and burned that one up. I tell the mechanic that I just replaced it and he asked me “Did you do the filter to?” ooops.
Old 12-31-2006, 01:19 PM
Tones's Avatar
Yes, I believe that Toyota has jumped on the "no maintenance required" bandwagon like every other auto maker. Good for them because your vehicle requires more parts and service from neglect after the first 100k miles, but bad for you $$$.
Old 12-31-2006, 02:18 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
RitcheyRch's Photo Albums
Last Online: Today 02:11 PM
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch
Replaced mine at 45K miles and was surprised at the junk that came out of it. Truck was acting weird so figured was being starved for fuel. Replaced the filter and problem solved. Was a royal PITA to replace since is so close to the frame rail and they have hard line going to it rather than some rubber hoses.
Old 12-31-2006, 03:36 PM
CHINKinatundra's Avatar
Dealer : Red McCombs Toyota
2002 Toyota Tundra
CHINKinatundra's Photo Albums
Last Online: 11-29-2008 02:50 PM
CHINKinatundra is on a distinguished road.
Send a message via MSN to CHINKinatundra
on an 02 tundra, is it just one filter to change out in the engine bay? or is there another one closer to the tank as well? i'm nearing 40K so i'll probably replace my fuel filters sometime this month just to be safe.
Old 12-31-2006, 04:12 PM
RitcheyRch's Avatar
Fellow Tundra Owner
2002 Toyota Tundra
There is only one filter and it is under the drivers door.
Similar Threads for: fuel filter replacement?
fuel filter on a 06 tacoma prerunner?? tacomaman06 Tacoma 3 12-08-2006 11:24 PM
'04 Sequioa Detonation/Pinging 04sequioa4x4 1Gen-Sequoia 23 11-17-2006 08:58 PM
ARG, HELP! (in-line fuel filter not sealing properly) DevinSixtySeven Engine & Drivetrain 4 06-29-2003 11:34 PM
Has anyone made a fuel door replacement yet?? 02tundra Interior & Exterior 6 10-20-2002 01:08 AM
Original oil filter versus replacement filters? TundraGuy Engine & Drivetrain 10 03-16-2002 12:32 AM
